Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1663 Location: Marshallville Ohio
Posted: Sun Jan 04, 2026 1:35 pm Post subject: Re: Draw through DCOE won't idle |
Hey, I have built and tuned many drawthru setups. You should be able to get a stable idle.
What is your jetting setup?
They seem to like 65 idle jets and then tweak mixture screws.
If mixture screws have no effect, then you can open up the air bypass screws, and slow down the idle rpm, then the screws will start to have effect.
I can definitely help you... |
slayer61 Samba Member
Posted: Sun Jan 04, 2026 4:29 pm Post subject: Re: Draw through DCOE won't idle |
Thank you for your kind offer sir. I think i have 50s or something in it now. I have some larger ones to try tomorrow. I will let you know. Thanks again Tom. _________________
| Cusser wrote: |
... Most folks are idiots when it deals with electrical !!! |
| 67rustavenger wrote: |
3/4 race cam? What's missing, one of the lobes?  |
Paul
'68 Manx clone... Sears??
RLR/Strange brakes
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo
Tim's stage II turbo heads
MSD Box and distributor
Car Craft turbo header |
madmike Samba Member
Joined: July 11, 2005 Posts: 5302 Location: Atlanta,Michigan
Posted: Mon Jan 05, 2026 7:07 am Post subject: Re: Draw through DCOE won't idle |
Hey Paul, On my 45 doce, I had this jetting : F11 & a F7 I know ,,lol,, 55 idles, 180 mains & 155 airs,.300 Neddle & seat,, keep an eye on fuel pressure!!
I could not get the results I wanted(cruising) until i swapped to a 4 barrel QuickFuel, now 28-26 mpg !! runs 11's in the 1/4 w/15 lbs pumpgas!
hope ya get it sorted Paul!,cheers,mike _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Posted: Mon Jan 05, 2026 9:19 am Post subject: Re: Draw through DCOE won't idle |
Thanks for your input Mike. Much appreciated  _________________
| Cusser wrote: |
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo
Posted: Mon Jan 05, 2026 10:20 am Post subject: Re: Draw through DCOE won't idle |
Hey Mike, what cam did you have in your 2276? _________________
| Cusser wrote: |
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo
VdanielW Samba Member
Posted: Mon Jan 05, 2026 10:28 am Post subject: Re: Draw through DCOE won't idle |
| Just to clarify: When setting your idle air fuel mixtures are you setting for what the engine wants and ignoring the afr gauge? Even one point (hell, half a point) from where the engine is happy at idle can cause it to hunt and or stall. |
Posted: Mon Jan 05, 2026 10:43 am Post subject: Re: Draw through DCOE won't idle |
| VdanielW wrote: |
Daniel, I've yet to get it to idle well enough to do any adjustments on the mixture screws  _________________
| Cusser wrote: |
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo
Posted: Mon Jan 05, 2026 3:45 pm Post subject: Re: Draw through DCOE won't idle |
Thanks everyone for the suggestions. Seems like I just need to add more fuel to the idle. Just keep adding jets until it idles!
| Cusser wrote: |
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo
Bugsy61 Samba Member
Joined: March 20, 2011 Posts: 272 Location: Peoria, Illinois
Posted: Tue Jan 06, 2026 8:59 am Post subject: Re: Draw through DCOE won't idle |
Carbs have two very different systems built in that make them operate. High speed relies on velocity to evaporate fuel. The low speed and idle part of the carb relies on vacuum to evaporate fuel. You don't have any vacuum to speak of, so the fuel is not going to evaporate. You don't have much vacuum because your camshaft is way to big for a draw through set up, so there is nothing to evaporate the fuel. The power you would make under the curve would probably be greater with an Engle 100 on 112 LSA than that monster cam you have in there now. Extreme to go that small, yes, but a better choice.
Your cranking compression indicates that your dynamic compression is way, way to low. What is your static compression? With that cam, you need at least 9.5 to 1 for it to run right, and that is a compression that will limit your boost to about 6 psi boost.
You can band-aid the low compression by running 24 degrees timing at idle and adjust the rest of the curve as needed, but not the best solution.
Pull out the big cam, and put in a much smaller cam, or go blow through with dual carbs. Gravity helps dual carbs idle because the fuel will "fall into" the cylinder where combustion chamber heat will help it evaporate. Also, you will need a couple small holes in your throttle plates, but you are a long way from that. |
Posted: Wed Jan 07, 2026 8:21 pm Post subject: Re: Draw through DCOE won't idle |
FK 10 ,small motors I like fk 8..cheers,mike _________________ 'Black Ice'Drag Buggy 'Turbo'
Posted: Yesterday 4:49 pm Post subject: Re: Draw through DCOE won't idle |
| madmike wrote: |
| FK 10 ,small motors I like fk 8..cheers,mike |
Thanks Mike. So you aren't afraid to run a cam with some duration to it, in your draw through motor. _________________
| Cusser wrote: |
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo
NJ John Samba Member
Joined: September 21, 2007 Posts: 3064 Location: HdG, MD & NJ
Posted: Yesterday 5:40 pm Post subject: Re: Draw through DCOE won't idle |
And, one of the west coast turbo builder’s told me that small cams don’t need to be 112. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
BFB Samba Member
Posted: Yesterday 5:47 pm Post subject: Re: Draw through DCOE won't idle |
| NJ John wrote: |
| And, one of the west coast turbo builder’s told me that small cams don’t need to be 112. |
That makes complete sense when talking about duration _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Most experts aren't. |
