Official lazy person's stupid question thread
Page: Previous  1, 2, 3 ... 205, 206, 207, 208, 209  Next
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Wed Mar 05, 2025 1:24 pm    Post subject: Re: Official lazy person's stupid question thread Reply with quote
Wildthings wrote:
bobbyblack wrote:
Anyway, my O2 is functioning correctly. My Temp 2 is a problem, perhaps I have (as my spare) ECT sensor (Temp 2) that is from a different year as I believe I see on a vendor listing '86-'87, then '88-'91 for which sensor to purchase.
I believe the TSII sensors for the Digifant are all the same excepting on the Syncro. You are likely thinking the sender for the gauge which is a different elephant.
I am so confused (and somewhat embarrassed) that I often do not even ask stuff, sorry. The one I have for the dash has a round plug wire end (well, almost round anyway) I think, and that is not the one I am trying to see if I am correct about going to the ECU is a rectangular connector, and new ones from various vendors are blue plastic, they used to be black.
Am I right that the blue one with the rectangular plug is for the ECU, and if so, is it called temp 2 (TSII)? Like this (and now I see '86-'91)?
https://vancafe.com/coolant-temp-sensor-86-to-91-2wd/
I have three of these, and they all behave differently Sad
I have two of these and have not tried the second one yet:
https://vancafe.com/coolant-temperature-sensor-for-1986-87-vans-w-o-ring/
Thanks again,
-bobby
E1
E1 is offline
PostPosted: Wed Mar 05, 2025 1:45 pm    Post subject: Re: Official lazy person's stupid question thread Reply with quote
Blue is Temp II.
Black is for the gauge.
I do not think they’re interchangeable. The design is awful, and one reason we went to an aluminum thermostat housing that uses the screw-in Temp II that were used on 1.9s.
1984 Westfailure/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
— Colin Chapman
PostPosted: Wed Mar 05, 2025 2:16 pm    Post subject: Re: Official lazy person's stupid question thread Reply with quote
E1 wrote:
Blue is Temp II.
E1,
Thanks, thought so, but now doubting myself more than ever before.
The aluminum T-stat housing is on my 'needs it' list, and likely it will be going up in price after stock on hand is depleted Sad
-bobby
Wildthings
Wildthings is offline
PostPosted: Wed Mar 05, 2025 5:23 pm    Post subject: Re: Official lazy person's stupid question thread Reply with quote
These FI temperature sensors just need to fall within the range given in the Bentley so can vary quite a bit from each other and typically are working well enough if they cause they O2 system to go closed loop by the time the coolant exceeds 160°F.
There are the sending units for the gauge on the dash and are not the TS2 (Temperature Sensor II).
PostPosted: Thu Mar 06, 2025 10:38 am    Post subject: Re: Official lazy person's stupid question thread Reply with quote
Good, thanks. Trouble is this; The TS2 I have in there now is showing between 30 and 50 deg F above actual coolant temps at ambient temp coolant at startup, and almost 100 deg F high on the warmed up engine, so the O2 starts doing its "thing" way too early.
Luckily, I have a brandy new TS2 (thanks for confirmations) arriving by tomorrow afternoon.
Still hopeful to find a workable extension tube to allow me to get the AFM airbox a few more inches away so I can get at the injector and spark wires under it while running the engine. ---I believe though, that the AFM signal is depricated once the engine reaches full temp--- let me know in the comments Wink . Maybe I have some close sized hoses that I can duct tape in place somewhere in my mayhem of hoards. (My hoard is NOT the only hoard at my home, I suffer from multiple generations of family members that seem to have left the building, but their hoards of crap are still in situ.)
PS. the backfiring seems to be getting worse, I must certainly have a bad ignition wire, or plug --- I certainly have had brandy new spark plugs be bad out of the box. I don't think I would have a locked closed or clogged injector that would cause a backfire. I guess it could be stuck open? I did run several types of injector cleaners through a number of tanks with no resolution. Other possibilities exist, but I don't want to guess at several of them that could give me nightmares. It is entirely clear I am down one cylinder at all times as of this morning.
Thanks,
-bobby
PostPosted: Fri Mar 07, 2025 5:43 pm    Post subject: Re: Official lazy person's stupid question thread Reply with quote
Well, okay. I'm realizing that my #2 cylinder is not making fire.
So, after swapping in a known good ignition wire for #2, with same results, I went to the injector wire, having gotten my noid test light on arrival home tonight. Confirmed that the wires are all functioning properly.
Means tomorrow will be injector test/swap on right side rail. I did get a spare Gold Mansi injector for such a problem, but sure wish I'd gotten some number more than one, as it would make the work of swapping the entire rail + injectors so much more convenient. Oh well, some day I'll order another 5 injectors for the 'spare bus' and life will start working out a tad bit more easily...
BTW, thanks for all of the help, and patience with my dimness.
PostPosted: Sat Mar 08, 2025 2:13 pm    Post subject: Re: Official lazy person's stupid question thread Reply with quote
Fixed stupid part, just had to not be lazy.
E1
E1 is offline
PostPosted: Sat Mar 08, 2025 4:47 pm    Post subject: Re: Official lazy person's stupid question thread Reply with quote
Replaced the injector?
(Full Disclosure: I cheated)
— Colin Chapman
PostPosted: Sat Mar 08, 2025 7:20 pm    Post subject: Re: Official lazy person's stupid question thread Reply with quote
Well, it seemed stupid enough to try. But I was convinced that the stock plastic rail would probably try to kill me if I didn't replace it with a modern solution. The spare injector needed was literally stashed in the last place I would have ever looked... Hence everything out, and also digging in my other stash locations, it took 4 hours to get everything together enough to 'do the job'
Thanks E1, you've been awesome help on this obviously stupid and lazy trek !!!!!!!
Cheers!!
-bobby
E1
E1 is offline
PostPosted: Sat Mar 08, 2025 7:28 pm    Post subject: Re: Official lazy person's stupid question thread Reply with quote
You’re welcome Bud, you’ve certainly helped us before!
Nothing stupid about this issue, they can never be easy!
— Colin Chapman
uberaudi
uberaudi is offline
PostPosted: Sat Mar 15, 2025 8:09 am    Post subject: Re: Official lazy person's stupid question thread Reply with quote
Does anyone know the dimensions of the hollow dowel pins that mate the diesel block to the bellhousing?
'84 Adventurewagen 1Z TDI, '08 Audi Avant Quattro 6spd BHW TDI
AndyBees
AndyBees is offline
PostPosted: Sat Mar 15, 2025 9:57 am    Post subject: Re: Official lazy person's stupid question thread Reply with quote
When this storm passes, I'll go to my garage and measure! Right now it is raining cats & dogs in my neck of the woods.
'84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
1983 Air-cool, 225k miles, 180k miles mine, seven trips to Alaska from 1986 thru 2003. 1975 Bay hopeful.
uberaudi
uberaudi is offline
PostPosted: Sat Mar 15, 2025 10:05 am    Post subject: Re: Official lazy person's stupid question thread Reply with quote
Thanks Andy! Stay dry!
AndyBees
AndyBees is offline
PostPosted: Sat Mar 15, 2025 11:15 am    Post subject: Re: Official lazy person's stupid question thread Reply with quote
Okay, both the two holes in the bell housing measure 16mm as well as the two dowels on the engine.
uberaudi
uberaudi is offline
PostPosted: Sat Mar 15, 2025 11:36 am    Post subject: Re: Official lazy person's stupid question thread Reply with quote
Thank you Andy!
PostPosted: Tue Mar 25, 2025 6:26 am    Post subject: Re: Official lazy person's stupid question thread Reply with quote
Question of the day, stupid or lazy, or not;
Can a small amount of water, perhaps having gotten into the filter and freezing, break a hole in the filter that could lead to injector clogging? I think I got some water in my gas somehow in the middle of the winter. (No, it's not cracked evap tanks, or failed roll over valve seals)
Reason for the stupid question is that now that I have found and fixed the no-fire issue in my #2 cylinder, my #3 is now starting to display the same symptoms (no heat at the exhaust port header, until the engine is entirely warmed up). This time I don't have a spare injector on hand though... I guess I need to order some number more of them... Sad
I did go through multiple bottles of various injector cleaners, they sure did not fix the #2 cylinder issue.
-bobby
dhaavers
dhaavers is offline
PostPosted: Tue Mar 25, 2025 7:03 am    Post subject: Re: Official lazy person's stupid question thread Reply with quote
Bobby, I have a whole handful of used spare injectors available…how soon you need them?
- Dave
"The WonderVan"
PostPosted: Tue Mar 25, 2025 7:46 am    Post subject: Re: Official lazy person's stupid question thread Reply with quote
Dave,
Thanks for the offer. I too, have multiple sets of used. I could go back to stock, yes. But what I have are the specialized higher flow units offered by a favorite vendor of ours Wink
Again tho, the problem mysteriously goes away when the engine gets warmed up. I don't have any understanding of how an injector could go from not working below 40F on cold start to working just fine by the time I get 6 miles down the road.
-bobby
Wildthings
PostPosted: Tue Mar 25, 2025 8:46 am    Post subject: Re: Official lazy person's stupid question thread Reply with quote
bobbyblack wrote:
Dave,
-bobby
After my 91 sat for three years with a full tank of ethanol lace fuel in it, the injectors tended to stick when they sat for a while. Whether over night or just for 10 minutes at a gas station. It took 70 tanks of fuel before the gum that had formed in the tank finally cleared up completely.
PostPosted: Tue Mar 25, 2025 10:35 am    Post subject: Re: Official lazy person's stupid question thread Reply with quote
Wildthings, thanks!
I think my plan for now is to wait for the one new injector to arrive (I think by this weekend) and replace the #3, along with the plastic rail on driver side.
Further steps will have to include robbing my stash; I've got a new fuel tank, new pump, new filter, fuel tank reseal kit, and sundries. But, maybe that will wait a couple more weeks. I can't see doing the pump and filter if the tank is full of crap, but maybe I am not looking at everything from a high enough level to have my brain process the path properly. Suggestions welcome.
I planed to order a full injector set + a spare for the 'spare' Westy, which gets driven only a fer days a week, and 5 to 6 big trips a year (my kids love borrowing it). Anyway, when I get the new set, I can send this now 6 year old set of Gold injectors in for cleaning, then I can put that old set in the spare bus...
Man, having multiple T3's gets to be big money fast. And I was already flipped out about having/paying for just one!
-bobby
Page 206 of 209
