joemicari Samba Member
Joined: September 15, 2017 Posts: 32 Location: New York
Posted: Tue May 11, 2021 1:15 pm Post subject: Re: My baja build |
Car is complete. Thought I would post one last time with some pics. There are a lot of knowledgeable people on this form. To help others, please feel free to comment on what you would suggest doing different. Maybe I will even update my car based on your comments.
A few of my comments. The front skid plate is all show. Does not connect to the frame and is aluminum. The rear skid plate is steel, protects the engine, gearbox and connects to the frame. All corners have 90 degree welded gussets, including the cage to the chassis. The submarine belt should be back under the seat farther and I will probably update this soon. The front spindles have 2 degree camber which I missed when I bought them. Since I will never be in the dirt/sand, I wish I did not have this. The rear still has positive camber but I will adjust this out once the shocks break in a little. Will see after the summer. Once it is adjusted out, I will lock in the spring plate to the trailing arm. I have the rear shocks very tight right now.
Purposely used a draw through turbo with a 350TP carb and am very happy. Only running 8# boost which is perfect. No need to trash my gearbox. Gearbox was built by Geno in Pittsburgh. Wish I went with narrower tires but I do love the rims and this was the narrowest rim available from DST which dictated the tire size. Might add power steering this winter.
The oil cooler fans kick in at 190 degrees and off at 210. Not sure I will ever reach this temp. Been cool in the NE and the little driving I have done, the oil only reached 140. 7.1 quarts in this motor with the large sump for the turbo. But the cylinder heads have hit 280. Will need to watch these.
This is note worthy. I bought many 3AN fittings from Summit Racing for my brake and clutch lines. One of them was NOT drilled through. If I did not catch this, I would have been trying to trouble shoot why my peddle did not depress and I can tell you my last thought would have been a bad AN fitting. Check all your fittings before installing.
Hope this build and all your comments and feedback help others on this site
Daddy o's 67 Samba Member
Joined: November 25, 2008 Posts: 121 Location: Lancaster, SC
Posted: Tue May 11, 2021 3:20 pm Post subject: Re: My baja build |
| Looks Great! Good Job! |
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3255 Location: Left of everywhere
Posted: Tue May 11, 2021 7:31 pm Post subject: Re: My baja build |
| Fricken awesome wow. |
dustymojave Samba Member
Joined: January 07, 2007 Posts: 5846 Location: Lake LA, Mojave Desert, SoCal
Posted: Tue May 11, 2021 11:09 pm Post subject: Re: My baja build |
Very nice build. AS an off road racer, and fabricator of off road play and winning race cars, there are some things I would do VERY different.
I know that your Bug is a car show Baja for the north east. It's not likely to EVER actually be driven in the desert. The way you built the tunnel out of sections of curved tube, which weighs probably 3 times as much as the stock VW tunnel, while probably not any stronger, if as strong, told me that it was intended for car shows.
OK.
There are reasons why I didn't criticize such frivolous design as it was being done. I'm not saying that it's "wrong", it's simply car show stuff, not working offroad car stuff. Not structural engineering.
But your workmanship all through the build has been quite fine and I have NO criticism for that.
I just posted in a couple of threads a couple days ago about why I don't recommend wide tires on the front of a VW based off road Bug, Baja or buggy. I won't repeat it again here. Your choice of tires and wheels was for the aesthetics of the wheels, not for functional considerations. So function is compromised for form.
OK, Again.
The placement of the fire extinguisher on the rear bumper cage is another show feature. A couple of the offroad race organizations require a fire extinguisher on the rear of a car. On an offroad race truck, that puts a fire bottle near the fuel cell...potential source of fire, in a buggy, it's near the fuel cell and the engine. Again, potential sources of fire. But... In offroad racing, one makes a pass by tapping the back bumper of the car one wants to pass so they get the idea that you're coming through. That fire extinguisher would be gone in a second. And IF there is fire in the area where the extinguisher is mounted on the car, then one has to reach into the flames to fetch a fire bottle. NOT exactly a good place for a fire bottle. So, again...a show car thing.
OK.
The diamond plate aluminum front skid plate, you seem to apologize for. But my Baja, my old Baja, Bajas I build for others, my race buggy, etc. ... ALL have aluminum front skid plates. Often aluminum REAR skidplates too. But the skidplate should protect the beam at least. Otherwise, it's just bling on the front like a hood ornament.
The beam supports are way inboard. That beam would bend more easily than a stock one due to the leverage on the outer ends of the beam when hitting bumps. ESPECIALLY with those severe offset rims and wide ass tires.
Nice car show Bug. _________________ Richard
SoCalBajas Member
Posted: Wed May 12, 2021 3:05 am Post subject: Re: My baja build |
Thanks for the comments. Will be helpful to others. Keep them coming
You are correct, Cruse nights and ice cream store trips. No racing.
With regards to the fire extinguisher, there is another bottle in the cab in front of the driver seat. I wanted one on the back as well. Did not know about tapping to pass and this was the best spot to put it in the back.
The rear bottle is not just for show, although I do realize it might not be accessible. I have an electric fuel pump that is keyed and switched. I also had an inertia crash switch but it was so sensitive I removed it. I am looking for one that is not that sensitive. I am worried about that fuel pump continuing to push fuel and I am not in a position to turn the key or shut the switch, so, the rear bottle.
This form has been helpful, especially the post on seat belt mounting.
Thanks to all who take the time to post and share. |
21golden007 Samba Member
Joined: May 11, 2020 Posts: 112 Location: Grand Rapids Michigan
Posted: Wed May 12, 2021 7:25 am Post subject: Re: My baja build |
| Looks awesome. After 3 years of work Im sure it feels great to have a finished project (if there is such a thing) |
JWHracing Samba Member
Joined: September 17, 2008 Posts: 252 Location: Mesa, AZ
Posted: Wed May 12, 2021 9:45 am Post subject: Re: My baja build |
Looks great, very unique and sure to turn some heads.
Based on your temps and fan settings, I would make it so the fan stays on above 210. Once you really run it long enough with a turbo motor it will get above 210 pretty easy. 240-250 although probably rare in your driving conditions will happen at some point and that is okay. On the hottest of days, my car can see 240* temps when wide open at 4000+ rpms during a 200+ mile race.
As for your cylinder head temp, 280 is no issue, in fact that's about perfect. You don't want it any higher than 350, as that's the point where the valve seats will fall out of the head castings, or the valve guides begin to melt. _________________ 65 Baja - Class 5 Unlimited Race Car
2021 STORR Pro Air Cooled Buggy Champion
2019 AZOP Unlimited Buggy Champion
2017 SADR 1300 Class Champion
2016 AZOP Limited Buggy Champion
Currently "retired" from racing |
Posted: Wed May 12, 2021 10:25 am Post subject: Re: My baja build |
| Thanks for the temperature comments. I actually misspoke. Fan goes on at 210 and off at 195. That’s how it is set up. |
I Ride Sand Samba Member
Posted: Wed Jun 09, 2021 2:23 pm Post subject: Re: My baja build |
Id bet good money that the bump steer is HORRID. The rack is in completely the wrong location for the arc of the tie rod to match the arc of the trailing arms, if fact with it angled forward like it is, its the opposite of what was needed. I wouldn't recommend that location for the rack and pinion even on a street car. _________________ Just a dirty coyote playing in the desert.
now where'd that dirty badger run off to? |
Wulfthang Samba Member
Posted: Wed Jun 09, 2021 2:41 pm Post subject: Re: My baja build |
| joemicari wrote: |
| Thanks for the comments. Will be helpful to others. Keep them coming I have an electric fuel pump that is keyed and switched. I also had an inertia crash switch but it was so sensitive I removed it. I am looking for one that is not that sensitive. I am worried about that fuel pump continuing to push fuel and I am not in a position to turn the key or shut the switch, so, the rear bottle. . |
Use the oil pressure light circuit. Put in a relay connected to the light. As long as the light is OFF, the pump will run. As soon as the light comes on, the pump will stop pumping fuel. The light is on when the engine is off. |
Posted: Fri Jun 11, 2021 6:52 am Post subject: Re: My baja build |
Yes, the bump steer is a slight problem, not terrible but probably because my travel is never fully utilized on the road. I never checked this and just mounted to the rack mount as it came on the new front beam. Lack of knowledge on my part and missed reading about this.
I will be adjusting this mount.
Interesting idea to connect the fuel pump to a relay with the alternator lamp. Thanks for this suggestion, and all the comments.
So far, it has been fun and handling and running well. These do not exist in Rochester NY so cruise nights have been fun. Need to research changing my coil springs. Ride is stiff but going to get some miles on it first. |
Posted: Mon Jun 14, 2021 5:02 pm Post subject: Re: My baja build |
Actually the steering rack location is just the norm for offroad VW beam cars. One can work with the mount to adjust the bump steer to as close to zero as feasible before welding the mounts in place on the beam, but the rack location is as good as it gets on a VW beam. Adjustments from how it is would be only fractions of an inch to reach optimum.
My son Warren is quite good at setting rack location in an offroad Baja Bug, due to his years of building play and race Bajas professionally at Crumco. He won't get on forums because he hates dealing with those who seek to be internet geniuses from a standpoint of ignorance. So he won't be telling us how much bump steer he typically gets with similar rack positioning. But I know that it's less than 1/4" total in 15" of wheel travel with +4 arms. He does build cars with substantially wider beams, which makes for slightly less bump steer than the beam on this car.
I'm really NOT sure where IRS feels the rack SHOULD BE mounted. _________________ Richard
SoCalBajas Member
