1958 Swedish Beetle - In a garage since 2007
jordiando
jordiando is offline
PostPosted: Thu May 15, 2025 3:10 pm    Post subject: Re: 1958 Swedish Beetle - In a garage since 2007 Reply with quote
I have been on an adventure to try and get semaphores back on the beetle. so far I am 50% of the way there.
I have issues with one as it is missing a few parts and was super bent. I spent the last 5hrs trying to rebuild and find a way to make it work.
Would any one know where I can get a cone spring that fits on shaft to hold the lens over so it doesn't move.
This is the spring I am after.
I swapped over the lens.
Trying to straighten out the mount and also it didn't catch with some sandpaper. The bore was extremely far out.
jordiando
PostPosted: Mon May 19, 2025 12:00 pm    Post subject: Re: 1958 Swedish Beetle - In a garage since 2007 Reply with quote
For a lot of early Swedish beetle's it was mandatory to have 2 reflectors on the back of the car. It is something my beetle has been missing. I was lucky enough to source some from the Netherlands recently.
I was basing the mount off a few pictures I have seen online and phots i have taken of other Swedish import cars.
I managed to knock up a few brackets this evening. I am yet to drill as I am waiting on the reflectors to gauge the height. The gauge is a bit thinner but seems to be quiet stiff.
If any one has some more information on them that would be greatly appreciated.
scarabee
scarabee is offline
PostPosted: Tue May 20, 2025 3:02 am    Post subject: Re: 1958 Swedish Beetle - In a garage since 2007 Reply with quote
Jeez, 65 Euros is a bit steep for what it is! They don't seem to be that scarce if I look at Beetles here in South Africa.
jordiando
PostPosted: Wed May 21, 2025 12:52 am    Post subject: Re: 1958 Swedish Beetle - In a garage since 2007 Reply with quote
Did South Africa have the same rules as Sweden in the 50s for the twin reflectors? It would be great to see some photos. `
I had been searching for the Swedish (mid-late50s) specific reflectors for the last 8 months and had not found any that were the same in UK & EU. Id id see some in the US but they were priced much higher.
Some of the early split beetles had them mounted on the rear fenders near the tail lights.
vwuberalles
vwuberalles is offline
PostPosted: Wed May 21, 2025 7:25 am    Post subject: Re: 1958 Swedish Beetle - In a garage since 2007 Reply with quote
Those look really similar to bicycle reflectors from the 60s or 70s, I'm guessing you can find something close enough for far less than 65 Euros. An NOS reflector for my 72 Schwinn Breeze was like ten bucks shipped on eBay and there were several to choose from.
jordiando
PostPosted: Tue May 27, 2025 2:15 pm    Post subject: Re: 1958 Swedish Beetle - In a garage since 2007 Reply with quote
I did have a look for some alternatives whilst I sourced the originals but nothing was exactly what I wanted. I was just lucky enough to be speaking with someone at the right time to get them. In terms of 65 EUR for the right part that is correct for my car I am happy with that.
I polished the fronts, rust converted and painted the backs so it doesn't deteriorate any further.
I will need to get some thicker gauge medal for the mounts but that will be a future project. At least i have some now I can use a s a template.
Redfox86
Redfox86 is offline
PostPosted: Sun Jun 01, 2025 12:56 am    Post subject: Re: 1958 Swedish Beetle - In a garage since 2007 Reply with quote
I’ve just caught up with this project having been absent for a little while. I’m really impressed with what you’ve done since I last viewed the thread. It is so good to see that in the world where we live now where a three year old cars are getting scrapped because of their unreliability, a 67 year old car not only looks good but is able to traverse to Europe without any problems.
It might be black, but in many ways it’s a green machine Very Happy
jordiando
PostPosted: Thu Jun 05, 2025 2:23 pm    Post subject: Re: 1958 Swedish Beetle - In a garage since 2007 Reply with quote
Thanks, I was super surprised when we made it to Belgium and back with little to no problems. Especially after it sat for so long not being used. Cant wait to get back over there for a few more shows and holidays.
jordiando
PostPosted: Thu Jun 05, 2025 2:32 pm    Post subject: Re: 1958 Swedish Beetle - In a garage since 2007 Reply with quote
Managed to get some 6v Flashing LED bulbs for the semaphores. Spent the evening fitting them. You need to remove the semaphore to place the bulb in as it wont fit through the original slot.
I am having trouble with one not working too well. I think it is not receiving the full 6v or the bulb needs to be put in a certain way. It was working fine with the normal globe. Is this a common issue when installing the LED bulbs?
I have a 80s Hella bulb holder that I keep all my spares in. This sits in the glovebox for emergencies.
Finished up the evening tightening the fan belt and doing some tidying up.
jordiando
PostPosted: Thu Jul 03, 2025 8:19 am    Post subject: Re: 1958 Swedish Beetle - In a garage since 2007 Reply with quote
It has been a while. The sun has been shining and thus I have been making the most of it in the UK and EU.
I managed to get the beetle out for classics at the clubhouse in late JUN. It needed a little polish so got that done and checked off some basic maintenance things.
On the way out in the morning we had a little breakdown/run out of fuel and needed to turn the handle to reserve. After checking all the vitals I managed to fiddle round with the tap and went straight to the petrol station.
After a long day of driving I noticed that my brake lights were not working. not a good thing. This week I ordered the parts and replaced the brake light switch.
The one that came out seems to be an original or super old. I had to re pin the ends as the new one needed spade terminals.
Back working again.
PostPosted: Thu Jul 03, 2025 10:53 am    Post subject: Re: 1958 Swedish Beetle - In a garage since 2007 Reply with quote
I've never seen that e-brake switch boot, I wonder how many car are missing that
finster
finster is offline
PostPosted: Thu Jul 03, 2025 11:46 am    Post subject: Re: 1958 Swedish Beetle - In a garage since 2007 Reply with quote
I was thinking those brake lines are looking a bit past their best...
mukluk
mukluk is offline
PostPosted: Thu Jul 03, 2025 12:01 pm    Post subject: Re: 1958 Swedish Beetle - In a garage since 2007 Reply with quote
Probably most are, but new ones are available: https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113945521
jordiando
PostPosted: Sat Jul 05, 2025 1:40 pm    Post subject: Re: 1958 Swedish Beetle - In a garage since 2007 Reply with quote
That is the next project. Tackling it bit by bit. The car is currently sitting on jack stands with the drums off.
jordiando
PostPosted: Tue Jul 08, 2025 3:05 am    Post subject: Re: 1958 Swedish Beetle - In a garage since 2007 Reply with quote
I had some time this afternoon to work on the front drums, I replaced the brake pads, one cylinder and both soft lines. I opted to keep the hardware as there was nothing wrong with it just needed a clean and re greasing.
I had one issue with the drivers side inner bearing staying on when I pulled the drum off. The use of heat and persuasion will get it removed and replaced in the near future.
Front Passenger:
Front Driver:
Still yet to get on to the hardlines this will be done with months paycheck. I have ordered some tie rod ends to get it steering a bit better.
jordiando
PostPosted: Wed Jul 09, 2025 12:04 pm    Post subject: Re: 1958 Swedish Beetle - In a garage since 2007 Reply with quote
Tonight I removed the wheel bearing with a little bit of fire. It wasn't damaged, just a small amount of corrosion on the spindle. Using some scotchbrite it was easily removed and good to go. I bent the wire back to stop it from rubbing on the inner seal before assembly.
All back together, brakes bled and adjusted.
I am in the process of replacing the tie rod Outer and it seems like they have a longer distance between the center point and where the thread starts. I then had to remove the whole arm to adjust for the extra 1cm of length. All good cleaned the arm and the inner tie rod was serviceable. It was cool to uncover a VW logo on the steering arm. Left the arm unpainted just coated it in some linseed oil.
I am about to start the other side but noticed the driver side has a more pressed style arm, is this common to see?
jordiando
PostPosted: Sun Aug 10, 2025 1:42 pm    Post subject: Re: 1958 Swedish Beetle - In a garage since 2007 Reply with quote
After passing on my fuel cap holder template to a good friend who does leather work a few weeks back, I got the finished product this weekend. Turned out amazing, super happy with it. Means I won’t loose the old one or I take it out and use it for fuel stops.
EVfun Premium Member
EVfun is offline
PostPosted: Sun Aug 10, 2025 5:15 pm    Post subject: Re: 1958 Swedish Beetle - In a garage since 2007 Reply with quote
Front Driver:
Looks good, except what are roller bearings doing in there? Laughing
Wildthings wrote:
jordiando
PostPosted: Mon Aug 11, 2025 1:12 am    Post subject: Re: 1958 Swedish Beetle - In a garage since 2007 Reply with quote
Front Driver:
hahah Yeah it is a strange place for it to be stuck. I used some heat to remove the bearing and cleaned the spindle so it dosen't happen again.
jordiando
PostPosted: Wed Aug 27, 2025 10:47 am    Post subject: Re: 1958 Swedish Beetle - In a garage since 2007 Reply with quote
I have been busy moving house and general life activities has meant slow progress on the beetle.
This is our old but new folding garage. I purchased it second had off Facebook market place and it seems to do the job. A few rain showers and we will see how it holds up. I am yet to bolt it down in the center.
Been meaning to replace the rear shocks, they are blown out and are way past there use by date. I purchased a pair of Wolfsburg West ones based off an original looking shock. They seem to be the same colour and style. I have previously removed the shocks when I was cleaning under the fenders, I was super thankful that I had anti seized the bolts so they were not a pain to get off.
I couldn't tell if the old pair were original or not but believe they must of been replaced at least once. One was painted over in black and I couldn't be bothered to remove it to read the part number.
I couldn't quiet understand why the hard brake line seems to be so high above the spring plate, might be something I fix later if I lower it. Right now it dosent contact the body or the shock so it is okay.
Page 4 of 6
