Another no start starter problem. SOLVED! Bad hard start relay!
Page: Previous  1, 2, 3, 4
tikiman71
tikiman71 is offline
PostPosted: Thu Feb 27, 2025 10:14 pm    Post subject: Re: Another no start starting problem. SOLVED! bad hard start relay! Reply with quote
The original relay in question in this thread, a 12 year old "weatherproof" relay with a seal, was just briefly tested. I got a satisfying click when powered across 85 and 86 using a 12V power supply. So I tested continuity between 30 and 87 when powered, and got continuity.
I then checked resistance across 30/87 when powered. Our fellow nerd friends on a TDI forum said that anything greater than 0-0.002 ohms across this connection would indicate a bad relay. I measured 5 ohms. Then I was having fun clicking across 85/86 again, because it's satisfying and that is how I have fun on a Thursday night. I checked resistance across 30/87 again: 2+ ohms. More fun clicking, more resistance checking, more clicking, more resistance checking: 0 ohms.
So it appears (to me at least) that possibly the contacts had some grime, poop, corrosion, or burnishing that got "cleaned up" with all my rapid happy clicking, and now measure little to no resistance across 30/87. I'll plug it back in tomorrow and see if it fires the starter up.
I would pop the relay open to see the internal condition, but these weatherproof relay cases are glued or fused shut. If it doesn't work tomorrow, I'll cut it open and take a look, but I expect it will likely work. I don't think I would want to rely on it as a spare, so I'll probably cut into it anyway.
Will report back in the morning...
1987 Westfalia GL
do.dah
do.dah is offline
PostPosted: Thu Feb 27, 2025 10:53 pm    Post subject: Re: Another no start starting problem. SOLVED! bad hard start relay! Reply with quote
I like cleaning stuff with this, deoixt d5;
https://caig.com/deoxit-d-series/
Sodo
Sodo is offline
PostPosted: Thu Feb 27, 2025 11:51 pm    Post subject: Re: Another no start starting problem. SOLVED! bad hard start relay! Reply with quote
Tikiman I gotta admit I was feeling a little guilty prescribing a diagnostic task that appeared to challenge your ability.
Now I’m a little puzzled that you didn’t embrace the task right away.
Especially considering that you have the proper equipment on-hand,
and full comprehension to do it easily.
It takes all kinds I guess. I enjoy the “the why”, and the puzzle
much more than the parts-cannon.
....KTMs, GasGas, SPOT mtb
Abscate Premium Member
Abscate is offline
PostPosted: Fri Feb 28, 2025 12:10 am    Post subject: Re: Another no start starting problem. SOLVED! bad hard start relay! Reply with quote
If you fix your wires, you dont need to add a hot start relay.
If you cant fix your wires, you have no business putting in a hot start relay.
Sodo
Sodo is offline
PostPosted: Fri Feb 28, 2025 8:29 am    Post subject: Re: Another no start starting problem. SOLVED! bad hard start relay! Reply with quote
And if you're gonna have problems, look for solutions involving the positive side. Ignore the negative side.
You newYorkers have a way of cutting to the chase Wink
Like Yogi Berra said "nobody goes there anymore, it's too crowded"
tikiman71
PostPosted: Fri Feb 28, 2025 8:46 am    Post subject: Re: Another no start starting problem. SOLVED! bad hard start relay! Reply with quote
So the original relay that I repeatedly cycled last night is now working in the van. I'm still using the new replacement that I had on hand, and keeping the old as a backup.
My theory is that the sticky starter solenoid (which I bench tested, cleaned, re-lubed, and re-tested) contributed to the relay's fouled contacts after repeated attempts to start. All that current that was not able to activate the sticky solenoid might have resulted in carbon buildup, along with corrosion from 12 months of infrequent use outside in our moist coastal climate. While the relay is "sealed", I'm sure it is not immune from the long term effects of humidity and condensation.
I never needed the hard-start relay, on the old 2.1 or the EJ22, but I do appreciate alleviating the electrical stress on the ignition switch. As the description says:
"With this relay installed, your ignition switch will only be used to trigger the relay, it will no longer have to carry the starting current to the starter solenoid. This provides a shorter path from the battery to the starter, which ultimately provides more juice to the starter."
I still think this makes sense, even if you are introducing another potential component to fail (the relay).
So that is all from me for now. Thanks to all who helped, and are still reading. What an interesting thread this turned out to be.
Cheers,
Adam
1987 Westfalia GL
Sodo
Sodo is offline
PostPosted: Fri Feb 28, 2025 11:50 am    Post subject: Re: Another no start starter problem. SOLVED! Bad hard start relay! Reply with quote
With this relay installed, your ignition switch will only be used to trigger the relay, it will no longer have to carry the starting 10A ign switch current to the starter solenoid. This provides a shorter path from the battery to the starter solenoid , which ultimately provides more juice could increase milli-amps by “the hundreds” to the starter solenoid ."
Agree?
Disagree?
DanHoug
DanHoug is offline
PostPosted: Fri Feb 28, 2025 12:14 pm    Post subject: Re: Another no start starter problem. SOLVED! Bad hard start relay! Reply with quote
Sodo wrote:
With this relay installed, your ignition switch will only be used to trigger the relay, it will no longer have to carry the starting 10A ign switch current to the starter solenoid. This provides a shorter path from the battery to the starter solenoid , which ultimately provides more juice could increase milliamperes by “hundreds” to the starter solenoid ."
Agree?
Disagree?
first sentence, agree. it off loads the solenoid current from the switch to a relay.
second sentence, whatever. milliamperes in the solenoid circuit are nearly meaningless unless you're talking thousands of mA, then just say amps. the relay, if properly wired with adequate wire gauge, can in fact increase voltage to the pull in winding, which in turn will allow more amperage to flow. this increased power could make a sticky solenoid armature move.
also, off loading the solenoid current, a highly inductive load, puts the kickback EMF on an easily replaceable relay vs tearing into the switch. to make the relay points last longer, this would be a good application for a resistor-capacitor snubber network. overkill but stinkin' easy to do. did i do it? naw, i just carry a spare for the solenoid relay.
-dan
www.thefixitworkshop.com
kamzcab86
kamzcab86 is offline
PostPosted: Fri Feb 28, 2025 12:19 pm    Post subject: Re: Another no start starting problem. SOLVED! bad hard start relay! Reply with quote
Abscate wrote:
If you fix your wires, you don't need to add a hot start relay.
If you can't fix your wires, you have no business putting in a hot start relay.
Blanket statement that may be true for Vanagons, but not for all vehicles. Case in point: A1 chassis VW's with automatic transmissions. Their starters are next to the exhaust manifold; these do, in fact, suffer from heat-soak. It was a big enough problem that VW issued a TSB for them and the factory fix is to add a hot-start relay/solenoid.
DanHoug wrote:
bottom line: some relays live on the ragged edge of design specs.
Indeed. I dare say, VW's poor electrical engineering is also a factor.
Sodo wrote:
Kamz I bet that relay woulda failed the “simple click test” too.
Yep. Just tested and failed.
~Kamz Anxious
2016 Golf GTI S
Sodo
Sodo is offline
PostPosted: Fri Feb 28, 2025 12:49 pm    Post subject: Re: Another no start starter problem. SOLVED! Bad hard start relay! Reply with quote
Dan I could have used “tenths of amps” instead of “hundreds of milliamps”.
0.2A is the same as 200mA.
Which 0.2A or 200mA,,,, is an acceptable drop on 10 amps (2%) for a wire as long as from the ign to the solenoid.
A feller could do a “voltage drop test” and qualify that whole circuit.
Voltage drop test is da bomb!
I tellya! A superpower for 40yr outdoor vehicles.
vDrop test will quantify the losses, that the hard start relay can improve upon.
If theres no (significant) losses, there is no (significant) opportunity for improvement.
However there is the “$12 ign switch” headache.
I do have a theory on that though…if anyone is interested.
But I have no proof because my van hasn’t been an ign. switch eater.
For that I’d need a switch gobbler who’s also an “anti-parts-cannon” type,
who want's to solve the problem once and for all,
but "OG" style.
Or just curious.
Rorke
Rorke is offline
PostPosted: Sat Jun 14, 2025 8:15 am    Post subject: Re: Another no start starter problem. SOLVED! Bad hard start relay! Reply with quote
Man did I learn a ton from this thread.
I sure wish I had an assistant who could turn a key today.
wesitarz
wesitarz is offline
PostPosted: Sat Jun 14, 2025 9:24 pm    Post subject: Re: Another no start starter problem. SOLVED! Bad hard start relay! Reply with quote
So order a 2-pack of relays from Amazon and keep one as a spare. Lesson learned. (not learnt)
Busfixer
Busfixer is offline
PostPosted: Wed Jun 25, 2025 7:28 pm    Post subject: Re: Another no start starter problem. SOLVED! Bad hard start relay! Reply with quote
Rorke - I just had very similar symptoms on my ‘88. Finally narrowed it down to the two #53 relays in the little waterproof box above the coil on driver’s side of engine compartment. Intermittent crank but no start issues over the last 3 days. Also died in the middle of a 4 lane highway - started on the 10th try! After driving back to my garage, I wiggled the relays and it died. Wiggled again and it started. Replaced both 53 relays and it’s starting first time every time and no dying on the highway. Took it down a jeep road to give it the shake test and all’s well!
I carry a sack full of various relays as these Vanagon wiring systems are prone to gremlins.
Good luck, Busfixer
Page 4 of 4
