baldessariclan Samba Member
Joined: October 14, 2016 Posts: 2186 Location: Wichita, KS
Posted: Sat Oct 25, 2025 6:37 pm Post subject: Re: Sending unit recommendations |
Thanks guys! Fuel level sender testing not all that hard to replicate, if you want to try it yourself. I just drew lines at 1 inch intervals on a piece of cardboard, and cut a slot on one end so sender and its wire would fit in it:
Then I grounded the body (flange) of sender via a separate wire, turned on ignition, and marked where the sender arm sat, corresponding to fuel gauge needle positions — e.g.:
Etc.
Finally, I disconnected the sender from its wires, reconnected it to my multimeter, and recorded the resistance readings for those various arm positions, as shown in my earlier pics.
The results aren’t necessarily super-precise of course, but they should at least give a reasonable ballpark for what the sender’s resistance levels are at corresponding fuel tank levels.
Note that the fuel tank itself isn’t “uniform” in cross-section either. It’s got a lot more volume at top end of the tank, and a reduced volume area at bottom of tank. So the sender arm positions and resistance levels won’t be strictly linear either. _________________ 1971 Standard Beetle — fairly stock / driver
Last edited by baldessariclan on Sun Oct 26, 2025 4:11 pm; edited 3 times in total |
2type2 Samba Member
Joined: June 02, 2002 Posts: 1210 Location: SW Colorado
Posted: Sun Oct 26, 2025 7:35 am Post subject: Re: Sending unit recommendations |
All this info is great. The techniques for testing, the expected parameters, the possible tweaks and fixes....... But thr real question is:
After all these years, why is there not an accurate aftermarket drop-in eplacement that actually works?
Undoubtedly there is a market. I've whined about this before. I'm tired of writing down all my gas and mileage.At the very least it would be nice to be able toget a decent reasonably priced manual mileage counter for the dash! _________________ "A life of peace and happiness depends on your own gratefulness" |
viiking Samba Member
Joined: May 10, 2013 Posts: 3435 Location: Sydney Australia
Posted: Sun Oct 26, 2025 3:36 pm Post subject: Re: Sending unit recommendations |
| 2type2 wrote: |
There is! Just search for a VDO gauge like the original. You may have to search for it in Europe if not available in North America.
I bought one a few years ago and it was 99% identical to the 1968 original. The only difference was that the white float colour and shape was different to the black original.
The external metal was the same. The internal movements were identical. They obviously used the same metal pressings. Why change something that worked over 60 years? The critical resistance levels were exactly as prescribed.
I was so impressed with how identical it was that I pulled it apart and rebuilt it onto my original sender unit. Why? Because the original top part had the 1/68 date imprinted on it and I could maintain its look of originality even though the internals were all new. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
bugger-off Samba Member
Posted: Mon Oct 27, 2025 5:56 am Post subject: Re: Sending unit recommendations |
That's the same VDO that I have just tested yesterday but not yet installed.
My results are within 1-2 ohms as Baldy's reported on the previous page. I didn't bother taking pics since they were basically the same as his. Again, thank you for your awesome testing/pics!
Next step is to install it. That'll probably be another few days and I can report back then. Fingers crossed. |
Posted: Mon Nov 03, 2025 1:02 pm Post subject: Re: Sending unit recommendations |
Installed new VDO unit. Basically the same issue with the fuel gauge as with the previous sending unit.
So my next question is do I throw a new fuel gauge and vibrator at this thing? And, if I do, does the gauge need to be tweaked?
Should I just go back to filling the tank every two hundred miles? Definitely the easiest route to go. |
2type2 Samba Member
Posted: Mon Nov 03, 2025 1:36 pm Post subject: Re: Sending unit recommendations |
I feel ya, my experience was the same -- all new stuff, no improvement. My '71 is way off, my '65 has inaccurate reading with mechanical sender also. Paper and pencil saves the day. My question is -- why is this still not fixed by the offering of an aftermarket IMPROVED part?
Usually an upgraded replacement gets created to fill the need _________________ "A life of peace and happiness depends on your own gratefulness" |
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7569 Location: Houston, Texas
Posted: Mon Nov 03, 2025 1:37 pm Post subject: Re: Sending unit recommendations |
| 2type2 wrote: |
Usually an upgraded replacement gets created to fill the need |
I have a part coming this week that fixes it. I'm just waiting on the package to land. _________________ www.vwnos.com [email protected]
Posted: Mon Nov 03, 2025 3:12 pm Post subject: Re: Sending unit recommendations |
I said this a few posts back. Have you actually measured the resistance that the gauge receives. If you have added high resistance in the wiring from the sender to the gauge for whatever reason, then you may get a premature and inaccurate low gauge reading (high resistance). It however does not explain why the tank is apparently reading full (low resistace). It appears that you have a number of sender units that are working correctly but the gauge is not receiving the correct information. Before you think of a new gauge and/or vibrator or wait for heimlich's solution you should check this. It would be a shame if you replace all the hardware only to find out there is some problem with the wiring.
| viiking wrote: |
The only other thing I can think of before you do too much else is to actually measure the resistance being received at the meter.
It appears you have done a great job measuring with a combination of rulers in the tank and the resultant resistance. Not knowing how you did this but I assume you never reinstalled the meter along with the grounds every time you changed the level in the tank? It would be ideal if you could reproduce the "real life" situation.
It would just be simple to at least measure the resistance at the fuel sender with the wiring disconnected and compare that to the end of line resistance being received at the meter when it is connected. At least that way you can discount any resistance issues with the wiring. |
Posted: Tue Nov 04, 2025 6:45 am Post subject: Re: Sending unit recommendations |
| bugger-off wrote: |
So my next question is do I throw a new fuel gauge and vibrator at this thing? And, if I do, does the gauge need to be tweaked? |
Ok, so just to be clear, with the new sender installed you’re saying that the fuel gauge reads “full” when you’ve completely filled the tank, but when the gauge is reading near/at “reserve” or “empty”, it’s still got 4 or more gallons in the tank, right? (i.e. it only takes about 5-6 gallons to completely refill the tank at that point - ?)
If so, then yes it sounds like your sender is ok, but the fuel gauge itself is probably off / malfunctioning. As mentioned before, I’d recommend looking for a good used or NOS stock unit, over an aftermarket one. Old/junk speedometers are often a good source for fuel gauges, as well as The Samba classifieds, Bug City, VWNOS, etc.
The vibrator (voltage regulator) is probably ok — I’d leave it be for the time being. Usual indications for one of those going bad is a wandering, jumping, and/or oscillating fuel gauge needle. Or sometimes the fuel gauge needle remaining fully pegged at top or bottom of the gauge.
Recommend you check and clean/replace (if and as necessary) all the wiring & connections to the system, as viiking mentioned above. Also recommend that you refrain from attempting to adjust the new fuel gauge unit, unless absolutely necessary — the original stock ones almost never need it, in my experience. Any required adjustments can usually be more easily accomplished on the sender unit (e.g. by bending/moving the stop tabs a bit, and/or bending the float arm). _________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
Posted: Wed Nov 05, 2025 5:19 am Post subject: Re: Sending unit recommendations |
| viiking wrote: |
| viiking wrote: |
I had to go back over my posts and realized that I had NOT mentioned measuring the resistance at the gauge. I did so a few days back and found that the reading/resistance up at the gauge was 1-2 ohms off of the reading at the sender itself. So it seems there is nothing goofy going on with the brown wire from gauge to sender. |
Posted: Wed Nov 05, 2025 8:17 am Post subject: Re: Sending unit recommendations |
| bugger-off wrote: |
In the stock fuel gauge system, there are only two wires involved -- the black wire running between the fuse block (power source) and the vibrator, and the brown wire running between the fuel gauge and the fuel sender's central male tab. Both of those wires and their end tabs should have close to zero resistance when tested by themselves.
Likewise, there needs to be close to zero resistance between the fuel sender body and ground. As mentioned in earlier posts, in the stock configuration this grounding path is from the fuel tank to the body. And some people like to use a separate grounding wire as well, as noted earlier. Either way, when testing the grounding path between the fuel sender body and a known good grounding point on the body/chassis, there should be next to no resistance measured.
All connection points (i.e. male tabs on fuse block, vibrator, fuel gauge, and sender, and female tabs on the wire ends and vibrator) should be relatively clean and free of corrosion as well. _________________ 1971 Standard Beetle — fairly stock / driver
Posted: Wed Nov 05, 2025 8:26 am Post subject: Re: Sending unit recommendations |
| So you are saying that the wires themselves need to be checked and NOT have the sending unit hooked up at the other end? |
Posted: Wed Nov 05, 2025 8:36 am Post subject: Re: Sending unit recommendations |
Yes -- you tested the sender separately earlier, so you already know what its resistance values are, right? You just want to make sure you don't have a bunch of unintended resistance somewhere else in the system (e.g. bad/dirty connections, corroded wiring, etc.). _________________ 1971 Standard Beetle — fairly stock / driver
Posted: Wed Nov 05, 2025 8:48 am Post subject: Re: Sending unit recommendations |
Another idea to consider -- at your next gas tank refill, might be helpful if you could take and post some pics of your fuel gauge reading and how many gallons it took to top off the tank. May help us to better figure out exactly where and how any "inconsistencies" are occurring...
E.g. here are some I took recently:
Tank refill with fuel gauge needle resting on the "R" line. Took 9.2 gallons to refill the (nominal) 10.5 gallon tank. So about 1.3 gallons should have been left in the tank when the needle was on the "R" line. Seems reasonable/consistent w/ the measurements and pics of gauge & sender I posted earlier:
And here' a tank refill with fuel gauge needle resting on the "1/4" line. Took 8.0 gallons to refill the (nominal) 10.5 gallon tank. So about 2.5 gallons should have been left in the tank when the needle was on the "1/4" line. Once again, seems reasonable/consistent w/ the measurements and pics of gauge & sender I posted earlier:
Posted: Wed Nov 05, 2025 11:34 am Post subject: Re: Sending unit recommendations |
| Yes, good idea, I will give that a shot. I probably have a couple gallons right now and the gauge is pegged all the way to the left, well below the "R". I'll fill and record/photograph the different positions. |
Posted: Wed Nov 05, 2025 1:11 pm Post subject: Re: Sending unit recommendations |
Sounds good! If you fill it slowly, you should be able to periodically pause, let needle stabilize for a minute, and then snap a pic of needle position and corresponding gallons filled at the "R" line, "1/4" line, "1/2" line, and finally the "1/1" (full) line.
From that last reading (i.e. gallons it took to get to tank completely full), should then be able to work backwards, computing how much fuel was in the tank at each of those points. _________________ 1971 Standard Beetle — fairly stock / driver
Posted: Fri Nov 07, 2025 8:40 pm Post subject: Re: Sending unit recommendations |
I ran the tank down to damn near empty, maybe an eighth of a gallon. I put exactly three gallons in and the gauge needle did not move from being pegged all the way to the left, way past “R”. Bottomed-out. Didn’t budge at all. I didn’t take a pic, no reason to.
I added two more gallons for a total of five, damn near half tank. The needle barely moved.
I put in another 2.5 gallons, conceivably three quarters of a tank with only an 1/8 full gauge reading.
I then topped the tank off with 2.6 gallons (10.1 gallons total) giving me a tad below half tank.
I waited fifteen minutes between each addition of fuel for the needle to “catch up”.
These unacceptable readings from the new VDO sending unit are actually worse than those of the two cheap ones previously used. $60 for the VDO and $15 for the Chinese specials. Wow, screwed the pooch on that one!
So, yeah. Good times. I’ve had a few bugs and never had such inaccuracies. This has to be the gauge. |
Posted: Sat Nov 08, 2025 3:41 pm Post subject: Re: Sending unit recommendations |
You have three possible causes that I see. The symptom is that you have a lower reading than you should across all of the readings. You don't show full at any time when the sender is fitted and the tank full of fuel.
1. The gauge or vibrator has failed.
2. You have a higher resistance than you should for a given level in the tank.
3. Someone has been in the gauge and actually bent the gauge needle.
The last one is unlikely but possible but I added it for completeness.
I've suggested you check the resistance in the wiring. I strongly urge you do it but it looks like you haven't done so. There are a number of posts on the SAMBA where people have had issues and have urged the cleaning of the connections or the complete replacement of the wire from the tank to the gauge.
If it were me I would:
1. Check the wire resistance.
2. If higher than expected run a new temporary line from the sender to the gauge. Do this after checking the resistance of the temporary line is very close to zero. If this improves the operation of the gauge, you have your solution.
3. If the resistance proves ok from 1, then and only then start replacing your gauge. Better still see if someone can lend you a known functioning gauge. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Posted: Mon Nov 10, 2025 7:10 am Post subject: Re: Sending unit recommendations |
I have checked the resistance in the wire and it is okay. I also cleaned all of the connections and dabbed Stabilant 22 on them.
No one has messed with the gauge. When I acquired the vehicle five years ago the gauge was working properly. After driving it for about a year, the gauge evidently stuck at 1/2 full-- I wasn't paying attention to the gauge OR the miles I had driven because I ran out of gas.
I then replaced the sending unit because of the erroneous gauge reading and the gauge moved off of half but I have had issues with accuracy ever since.
I have to believe the gauge has to be faulty. |
