zozo Samba Member
Joined: October 15, 2005 Posts: 5216 Location: South of Ol' San Antonio
Posted: Tue Jan 01, 2019 5:42 pm Post subject: Re: Front disc brake conversion |
| It’s the dual that came in the kit, and nope, no fitting. |
dlicious Samba Member
Joined: September 07, 2006 Posts: 245 Location: Spring(pronounced Sprang), TX
Posted: Tue Jan 01, 2019 7:07 pm Post subject: Re: Front disc brake conversion |
| zozo wrote: |
I’m getting zero bubbles and have bled via the pumping, the one man method, and the MityVac at least a dozen times. I’m getting no bubbles at all, but I still don’t feel like I’m getting the pedal I should have. I adjusted the rears all the way out, etc etc.
How can I measure the pushrod clearance? When I push/pull it manually, there’s a very slight movement and a click that I assume is the rod making contact. Very minimal movement, but I can’t say for certain it’s 1mm.
Thoughts?
(And no, I didn’t bench bleed the MC.) |
It sounds like you don't have there push rod adjusted properly. If the master cylinder isn't allowed to return all the way it blocks a fill port. It is 1mm of play at the pedal. That equates to 1/2 a cunt hair at the end of the rod.
That's where I would start looking....
You asked how to measure:
I crawl under the bus and grab the brake pedal arm and move it manually. You can then see where all the slop and movements are. The push rod is set with a lock nut. Crack it free and screw it in while moving the brake pedal arm. You will see/feel really fast if its set properly or not. It should not touch the plunger in the MC while at rest. _________________ '63 Caravelle Camper
dLk |
66uno Samba Member
Joined: December 05, 2006 Posts: 604 Location: maryland
Posted: Wed Jan 02, 2019 1:36 pm Post subject: Re: Front disc brake conversion |
Just curious if there is a handy conversion somewhere for millimeters to cunt hair?
Asking for a friend. |
zozo Samba Member
Posted: Wed Jan 02, 2019 1:54 pm Post subject: Re: Front disc brake conversion |
| 66uno wrote: |
Given the age of these buses, I'd assume one would have to factor in the coarseness that comes with age. |
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1399 Location: So. Cal
Posted: Wed Jan 02, 2019 2:12 pm Post subject: Re: Front disc brake conversion |
zozo,
What wheels are you running? If stock 14" any fit issues? |
zozo Samba Member
Posted: Wed Jan 02, 2019 2:41 pm Post subject: Re: Front disc brake conversion |
| matthew henricks wrote: |
zozo,
Yes, sir, stock 14". No sir, no fitment issues at all.
I am curious if I should put a bit of loctite on the studs. When I remove the lug nuts, they either come out or turn to be loose. Thoughts? |
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1795 Location: Cleveland, Ohio
Posted: Wed Jan 02, 2019 3:57 pm Post subject: Re: Front disc brake conversion |
| Bruce Amacker wrote: |
| zozo wrote: |
Thoughts?
I'm pretty sure you have that wrong, I think it's 1mm at the pushrod. |
I stand corrected. It is 1mm clearance between pushrod and piston.
B-2, page 4 in the big blue book _________________ '63 Caravelle Camper
dLk |
zozo Samba Member
Posted: Wed Jan 02, 2019 6:03 pm Post subject: Re: Front disc brake conversion |
Mort's looks correct.
Yours had 10mm? _________________ '63 Caravelle Camper
dLk |
zozo Samba Member
Posted: Wed Jan 02, 2019 6:07 pm Post subject: Re: Front disc brake conversion |
| dlicious wrote: |
Yours had 10mm? |
Yup. It was at least 10mm, likely more.
BTW, I am Mort, aka Zozo, aka John (real name). |
Posted: Wed Jan 02, 2019 6:16 pm Post subject: Re: Front disc brake conversion |
| zozo wrote: |
| dlicious wrote: |
Yours had 10mm? |
I'm sure our paths will meet someday.
Did adjusting the pushrod fix your problem? _________________ '63 Caravelle Camper
dLk |
zozo Samba Member
Posted: Wed Jan 02, 2019 6:32 pm Post subject: Re: Front disc brake conversion |
| dlicious wrote: |
| zozo wrote: |
| dlicious wrote: |
Yours had 10mm? |
Did adjusting the pushrod fix your problem? |
The pedal is exactly what I’d hoped for. The $64,000 question is what will the pedal be like once it’s on the ground and I start to drive it. I’m getting real used to disappointment, but for the moment, confidence is high. |
Z Samba Member
Joined: June 15, 2003 Posts: 2517 Location: galveston, tx
Posted: Sun Jan 06, 2019 2:40 pm Post subject: Re: Front disc brake conversion |
| FWIW, I had terrible luck bleeding my brakes until I did it with the front end raised about a foot. Read that trick on some non VW forum and it worked great. |
zozo Samba Member
Posted: Sun Jan 06, 2019 3:02 pm Post subject: Re: Front disc brake conversion |
| Z wrote: |
It worked for me as well. I finally got to drive it on Friday and they work great. They feel so odd compared to stock, and feel considerably different from modern power disks, but I’ll get used to it. I can’t argue with their performance. Safety first. |
Z Samba Member
Posted: Wed Jan 09, 2019 10:56 am Post subject: Re: Front disc brake conversion |
| zozo wrote: |
| Z wrote: |
Cool...good to know, & glad to see you're happy with it. I'm really encouraged at the good results with this kit. |
zozo Samba Member
Posted: Wed Jan 09, 2019 1:06 pm Post subject: Re: Front disc brake conversion |
| Z wrote: |
| zozo wrote: |
| Z wrote: |
I am as well, and have recommended the same kit to others. |
Posted: Thu Jan 10, 2019 8:45 am Post subject: Re: Front disc brake conversion |
Thank you for the reports Zozo. Your report and a recent sale price tipped the scale and i now have a AC Industries disc brake kit for my 65 in the garage.
Now the hunt for the same for my 60 w/ stock 15" rims. EMPI "quality" or German (CSP) price. As far as i can tell these are the only two options for stock 15" crows feet rims. |
Posted: Thu Jan 17, 2019 3:02 pm Post subject: Re: Front disc brake conversion |
I installed my second AC set and had a minor problem I thought I'd tell you about. The rear check valve was stuck closed, not allowing the rear brakes to bleed. I removed the line and check valve (left valve in the picture), bled it at the MC port with my finger, and put the check valve back in. I then bled it at the valve with my finger, then connected the line. It bled easily at the rear wheels from there. No biggie, 10 minutes max.
_________________ '66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263 |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19893 Location: Land of Whine and Phonies
Posted: Wed Jan 23, 2019 3:04 pm Post subject: Re: Front disc brake conversion |
I didn't see a listing for 63 and earlier disc brakes from AC. Is there not one available for the early spindles? _________________ Your Vanagon sucks, Stop waving at me.
| HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
