Fish Samba Member
Joined: December 05, 2000 Posts: 5868 Location: OB. It's beside the point.
Posted: Sat Aug 10, 2019 3:12 pm Post subject: Re: '55 Baja Barndoor Single Cab |
I've loved that truck ever sense I first saw it getting air in that "How to Off Rode your VW" book. It was my inspiration back in the 70's. _________________ Prosit!
# 303 and #156
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9828 Location: Exit 7, New Jersey
Posted: Sat Aug 10, 2019 9:52 pm Post subject: Re: '55 Baja Barndoor Single Cab |
Good news!
Pulled the engine, and while there is ample evidence of oil leaking, The clutch, flywheel, and interior transmission bell are dry as a bone!
Gonna mount it up on an engine stand and fire her up, looking for leaks.
I'm thinking it's just excessive case pressure. It only has a small mushroom air outlet at the oil fill neck.
I know that on anything bigger than a 40 horse, and even on most of those, VW routed a pressure line back to the interior, vacuum-side air cleaner to suck the excess crank gases back into the intake.
How do you big engine folks recommend lowering crankcase pressure in a 1914 with dual carbs? Ported inlet manifolds feeding a breather box, then connected to the case with a line from the oil fill? _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all!  |
LAGrunthaner  Samba Member
Joined: March 18, 2007 Posts: 5575 Location: 1st Coast
Posted: Sun Aug 11, 2019 7:00 am Post subject: Re: '55 Baja Barndoor Single Cab |
Easy does it on your back, I've lost many years with my bad back now I just try to take it easy. I love this photo! Curious why you don't buy a Gene Berg engine, I don't need one but I'll buy theirs if I ever do.
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
Posted: Thu Jun 08, 2023 5:17 pm Post subject: Re: '55 Baja Barndoor Single Cab |
Got the oil leaks sorted.
Hoping to roll this beast all summer.
New MT's installed. Check out the triple shocks.
aa390392 Samba Member
Posted: Fri Jun 09, 2023 11:29 am Post subject: Re: '55 Baja Barndoor Single Cab |
Wow! Saw this bus run Parker 500 race back in the 70’s, friend of mine wanted to make it “center steer”…
Opps don’t mind me, jus a flash back. _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
Posted: Fri Jun 09, 2023 9:43 pm Post subject: Re: '55 Baja Barndoor Single Cab |
aa390392 wrote: |
Opps don’t mind me, jus a flash back. |
Anything you remember from the race would be appreciated! _________________ Founder and Chairman Emeritus, ECMSAS
Fish Samba Member
Shoyrtt Samba Member
Joined: August 21, 2010 Posts: 1092 Location: Redlands, CA
Posted: Mon Apr 07, 2025 2:55 pm Post subject: Re: '55 Baja Barndoor Single Cab |
Any updates on the Baja Barndoor? |
