Overheating Help
Page: Previous  1, 2, 3, 4, 5, 6, 7  Next
1600man
1600man is offline
PostPosted: Tue Aug 05, 2025 1:19 pm    Post subject: Re: Overheating Help Reply with quote
Does the timing mark look too advanced to anyone else?
Maybe a little rich also but that helps keep it cool.
I still think it's a lack of airflow issue. You need the doghouse shroud with the bigger fan. The stand off decklid will allow more air to the fan. It's a big motor with high compression.
1970 VW beetle
(1973 1600DP)
1972 Cutlass
(1970) 455
vamram Premium Member
vamram is offline
PostPosted: Tue Aug 05, 2025 1:27 pm    Post subject: Re: Overheating Help Reply with quote
I'd have to agree. I don't think there's much sense in spending much more time on this until he gets the proper shroud for the motor. I mean, is the doghouse cooler just sitting outside in the open air in front of the shroud?? Or does he have a single-port case w/the old style cooler inside the shroud?
'75 Super Le Grande...we hardly knew ye. Sold 2025 for peanuts.
Click to view image
Save the Supers!!
Eric&Barb
Eric&Barb is offline
PostPosted: Tue Aug 05, 2025 1:29 pm    Post subject: Re: Overheating Help Reply with quote
He has old style single port "H" case engine with non-DH cooling system.
Snoopy1971 wrote:
Yes I have a non-doghouse. Would going up in displacement only 94 CCs have this effect? I know Ive seen plenty of 1600s and a little over in displacement that still have non-doghouse systems, and they didnt have my issues ... hmmm totally interesting theory!!
In Stereo, Where Available!
chrisflstf
chrisflstf is offline
PostPosted: Tue Aug 05, 2025 2:27 pm    Post subject: Re: Overheating Help Reply with quote
Snoopy1971 wrote:
chrisflstf wrote:
I would put an oil pressure gauge on it. If its too high, it will bypass the cooler. Bad/wrong springs can cause this
What range is it supposed to be in?
10 PSI for every 1000 rpm seems to be the norm
bsairhead
bsairhead is offline
PostPosted: Tue Aug 05, 2025 4:05 pm    Post subject: Re: Overheating Help Reply with quote
Snoopy1971 wrote:
vamram wrote:
When i use this method, i rev it to 3.2k+ and set it between 28-32. 26 is too low.
Yes thats the way I understiod it ... I just didnt follow what Mr. Bsairhead was trying to convey.
I pulled my throttle all tge way back ... about 3200 was the max I could get out of it.
Mr. Bsairhead here. But you can call me bsairhead, The rpm is not the factor the all in advance is. Plugs look a little lean but not bad. Got a spot you can hot rod it, shut down and coast to a safe spot to pull your plugs for a reading? Make sure your at 28-30 even 32 if it runs better. 26* is to low.
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Tue Aug 05, 2025 5:15 pm    Post subject: Re: Overheating Help Reply with quote
Sounds too lean.
Back a few, you reset the basics and fattened up the idle mixture and brought the temps down. Why would you not try another 1/4 turn or 2 or 3 or 4? I am betting you set the basic idle mixture too lean. I bet you have never checked the float level and the main jet is too lean?
You need to find a way to measure the mixture and then make adjustments based on actual measurements.
Your plugs are too lean. I would step up one size on the main jet and idle jet. Then reset all of the basics. Then go for a drive. Once you return, let it cool down and pull the plugs. Read them. Then make adjustments, if needed.
Remember, it is better to be too rich, then too lean. Lean burns valves and pistons, you run a chance for preignition and overheating the poor engine. Too rich and you get worn rings, worn cylinder walls and worn main bearings (if the oil gets saturated).
So, you gotta get this quickly. Get a set of jets and start learning to read plugs or take it to a tuner!
Jimbo
TDCTDI wrote:
67rustavenger wrote:
Snoopy1971
Snoopy1971 is offline
PostPosted: Tue Aug 05, 2025 6:32 pm    Post subject: Re: Overheating Help Reply with quote
What timing mark? I didn't post a pic with a timing mark
Yeah Im still waiting for the standoff shipping confirmation ... been 11 days and no word yet.
1968 Bug
Snoopy1971
Mr. V ... yep I have a single port case with older cooler inside the shroud
1968 Bug
Snoopy1971
PostPosted: Tue Aug 05, 2025 6:33 pm    Post subject: Re: Overheating Help Reply with quote
VW_Jimbo wrote:
Sounds too lean.
Yeah I am a super newbie at carb adjustments. Another 1/4 turn on which one, the volume control screw or the bypass screw? If I turn it more, it messes with the idle speed.
My main jet is a 135 ... not sure why somebody put such a big one in there
The plugs look lean?? I though lean is covered in white/light gray ash? ... These plugs look neutral colored/ tannish to me.
1968 Bug
Snoopy1971
PostPosted: Tue Aug 05, 2025 6:34 pm    Post subject: Re: Overheating Help Reply with quote
Max Welton wrote:
Well, VW went to the DH configuration for a reason and just because others appear to be getting away with non-DH ... doesn't count for much.
Well true ... I ran a 1600 DP with non-doghouse for the 5 years Ive owned it, and many friends have done the same ... I guess my time was up!! Shocked
1968 Bug
Snoopy1971
PostPosted: Tue Aug 05, 2025 6:35 pm    Post subject: Re: Overheating Help Reply with quote
1968 Bug
Snoopy1971
PostPosted: Tue Aug 05, 2025 6:45 pm    Post subject: Re: Overheating Help Reply with quote
So a list of everything I need to convert to a doghouse ... let me make sure I have everything ... I would need:
- Doghouse fan shroud
- The 2 tins that go on the back of the shroud
- The front engine tin
- Fan
- The captive nut on the drivers side
- Doghouse oil cooler and the adapter and correct seals
Is this everything?
Also, would it behoove me to decrease my compression ratio? How so? My deck heights are all between .049 and .053 already ... I thought I read somewhere that between .040 and .050 was the optimal deck height ... so two of my cylinders are in there already. If I want to get my CR down from 8.5 to 7.5, I would need .060" in shims that would make the CR 7.5.
Would another option be to have a machine shop machine out my heads to make the combustion chambers bigger? I would need the CCs increased from 48 to 57 to make the CR 7.5.
1968 Bug
1600man
1600man is offline
PostPosted: Tue Aug 05, 2025 8:06 pm    Post subject: Re: Overheating Help Reply with quote
The timing mark on the grounding strap of the plugs. The closer it is to the threads the more timing it shows. You want it at the 90 bend.
The plugs look black to me but if they are tan you are good.
I'd leave the compression and get the doghouse fan and shroud setup. You could always add a oil filter for more oil capacity after getting the bugs worked out.
1970 VW beetle
(1973 1600DP)
1972 Cutlass
(1970) 455
Eric&Barb
PostPosted: Tue Aug 05, 2025 8:43 pm    Post subject: Re: Overheating Help Reply with quote
- Fan
Is this everything?
The exhaust shell and tube for the hot air coming off the oil cooler, those go on the front of the fan shroud.
The thermostatic flaps for DH.
Foam tape from your local hardware store to seal the DH cooler exhaust tubes. Plus to seal the DH oil cooler tot he inside of the DH shroud.
The two rubber seals for the cooler exhaust tins.
VW_Jimbo is offline
PostPosted: Tue Aug 05, 2025 11:13 pm    Post subject: Re: Overheating Help Reply with quote
Those plugs are lean. Fix that first.
Good luck.
Jimbo
vamram is offline
PostPosted: Wed Aug 06, 2025 4:38 am    Post subject: Re: Overheating Help Reply with quote
Here are the DH cooling tins Eric&Barb mentioned above:
Click to view image
Save the Supers!!
Snoopy1971
PostPosted: Wed Aug 06, 2025 5:11 am    Post subject: Re: Overheating Help Reply with quote
- Fan
Is this everything?
Oh yes yes, these are what I meant by the 2 tins ... I mistakenly said back of the fan shroud, I meant front.
Are the flaps and thermostat needed? Mine never had them in since Ive had the car. I know some guys run them and some dont.
1968 Bug
Snoopy1971
PostPosted: Wed Aug 06, 2025 5:14 am    Post subject: Re: Overheating Help Reply with quote
Is this some sort of special foam tape to resist higher temps or just regular sticky foam weather stripping used for like windows you can get at Home Depot?
1968 Bug
vamram is offline
PostPosted: Wed Aug 06, 2025 5:27 am    Post subject: Re: Overheating Help Reply with quote
Yes, weather stripping foam from HD would work fine. I used some leftover foam from a window AC unit I installed this summer. The electrical tape was on there temporarily to keep the foam from peeling off until I was ready to install the fan shroud.
Also, I probably used foam that was a 1/2" too thick, but it held and crushed nicely when I installed the shroud over it.
And yes, IMO, you need the flaps and thermostat. I have them in all my cars, they make a big difference in warm up and especially in cold weather. Mine is a year-round driver so flaps & thermostat are a must-have.
Click to view image
Save the Supers!!
Snoopy1971
PostPosted: Wed Aug 06, 2025 7:16 am    Post subject: Re: Overheating Help Reply with quote
Good luck.
Sounds good. I'll clean the plugs up and back the mixture screw out a little and see what it does. Or would you suggest a bigger main jet? I already have a 135 in there, not sure what size my idle jet is, I have to look.
1968 Bug
Page 5 of 7
