Bullet turn sig. seals
aa390392
aa390392 is offline
PostPosted: Wed Aug 10, 2022 4:48 pm    Post subject: Bullet turn sig. seals Reply with quote
Curious, I’ve been attempting to install new seals on my project, I purchased WCM. Seals, I’ve literally spent the past 3 plus hours chasing just the 1st seal.
Totally frustrated..help please.
Thanks
Thomas
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet
Blue Baron
VW Aficionado
Blue Baron is offline
PostPosted: Thu Aug 11, 2022 6:20 pm    Post subject: Re: Bullet turn sig. seals Reply with quote
Part of the issue is you are often sold bus bullet seals for use on an oval, and the oval housings are larger. If you stretch out the bus seal, eventually it will crack apart. Be sure they're not selling you a one-size-fits-all.
If the part number starts with a 211, it's definitely the wrong seal.
Heinz Nordhoff
aa390392
aa390392 is offline
PostPosted: Fri Aug 12, 2022 10:44 am    Post subject: Re: Bullet turn sig. seals Reply with quote
I initially purchased ftom WW, as you can see they sell them for both the bug and the bus as the Description: TURN SIGNAL SEAL, bullet style, seals housing to fender on Beetles, housing to nose on Buses, Mid'55-1957 U.S. Beetles, Mar'55-1961 Bus, made by Wolfsburg West, set of 2
So now I will contact WCM.
SEALS, FRONT TURN INDICATOR, BUG 1954-57, BUS 1955-62, GHIA 1956-59 *MADE IN USA BY WCM*
Part #: 111-191F-L/R
VW#: 111-953-165
If you have a source other than those please feel free.
Appreciate it
55 ragtop
56 delux sedan
56 Kabriolet
lardawge
lardawge is offline
PostPosted: Fri Aug 12, 2022 1:26 pm    Post subject: Re: Bullet turn sig. seals Reply with quote
I recently installed a set from WW with no issues.
11/2/54 L227 Strato Silver Ragtop - Build Thread
1/7/55 L275 Light Beige - Build Thread
9/1/56 (57 model) L331 Horizon Blue - For Sale
yakob
yakob is offline
PostPosted: Sun Aug 14, 2022 5:47 pm    Post subject: Re: Bullet turn sig. seals Reply with quote
I recently installed a set from WW also. Mine were not the same thickness around the entire seal. I also thought they were the same thickness. Didn't know which way to rotate them on the housing. They fit fine other than the orientation of the seal on the housing.
