4 wheel/all wheel drive beetle?
John Burkett
John Burkett is offline
PostPosted: Sun Feb 27, 2005 5:25 pm    Post subject: 4 wheel/all wheel drive beetle? Reply with quote
Just wondering if anyone out there has ever seen or has built a four wheel drive bug/buggy using a vw trans/engine combo. I really do not care to have low range, but a high speed four wheel drive baja would be cool if it could be done without getting extremely heavy. I'm kinda new to vw's and just aquired a couple back in december. Just an idea. Thanks
'66 bug
'68 baja
'80 jeep cj-5
Its not what you buy, its what you build!!
Kubel Nick
Kubel Nick is offline
PostPosted: Sun Feb 27, 2005 5:37 pm    Post subject: Reply with quote
http://www.geocities.com/monsterbus/bugs2.html
HamburgerBrad
Je suis Napoléon!
HamburgerBrad is offline
PostPosted: Sun Feb 27, 2005 5:47 pm    Post subject: Reply with quote
i could see it being possible if you have a good sized budget and great fabrication skills
OGST | CU05 | OGJHC
1970 baja|1953 oval
Wanted: two beat up, ugly, curb rashed 6" phone dial wheels
Rudy's Ride
Rudy's Ride is offline
PostPosted: Sun Feb 27, 2005 8:48 pm    Post subject: Reply with quote
I think a twin engine 4wd would be cool Cool
vwclass11
vwclass11 is offline
PostPosted: Mon Feb 28, 2005 8:11 am    Post subject: Reply with quote
I agree with HBB, if you had the the resources and good fab skills anything is possible. I have thought of using a tube chassis, with a vanagon synchro drive train. My buddy has a synchro and I have seen that thing do some amazing things. But than again my baja goes more places than most 4x4s go.
I personally think a properly set up baja can go pretty much anywhere. I live in AZ and most of the trails are rock,dirt,dried up washes, and sometimes mud. I am using a 1600sp with a stock 4.12 trans, this set up has enough power to get me where I want to go,but not too much to break anything. Well hope this helps, by the way do you have the "How to build Baja Bugs and Buggies" book, it has a lot of useful information, later Mitch.
www.lowlifeaz.com
Vanhag wrote:
On a scale from 1-10 I see a class 11.
hotratz wrote:
I hold a level 2 certification in Tribology
http://images.thesamba.com/vw/gallery/pix/194538.jpg
[email protected]
mdetro4660@aol.com is offline
PostPosted: Mon Feb 28, 2005 11:37 am    Post subject: Reply with quote
There a 4WD one here in FL that pretty cool piece of engineering, but I question its abilities offroad. its kinda hard to explain but a motor/tranny sits in the stock location. the flanges off the tranny were replaced with sprockets. directly under is another tranny that has been machined that the chain/sprockets run to. He somehow basically turned it into a diff/transfercase. This also gives alot of lift to the car! A driveshaft runs to the front and it has a crazy modified beam that houses a front diff. I have no idea what the front is but from what I have heard, its pretty much all VW stuff. When I saw it it was on like 36" swampers. It had another "shifter" in it so it had either hi/low or maybe it disenguaged the front diff or both.
I never met the guy but I was told he is a machinest (and a darn good one) and the car is put together really well. I would imagine that if he was able to do what he did with the trannies he also had put in some pretty stout gears too.
Markus
Chewbacca
Chewbacca is offline
PostPosted: Mon Feb 28, 2005 2:51 pm    Post subject: Reply with quote
Sure has been 4wd bugs.
Factory VW made in 1941 - 44 during the war.
The type 87, 92 and 98s.
Used a type of swingaxle tranny as the forward transfer case.
There was around 1000 made all up if Im not mistaken.
4x4EATR
4x4EATR is offline
PostPosted: Mon Feb 28, 2005 5:12 pm    Post subject: Reply with quote
My boss' dad built a 4x4 "Jeetle" out of a '67 Beetle and a '67 CJ5. Ugliest piece of machinery ever built, as it uses the jeep front and back ends with the beetle grafted in between. Actually very well built. AMC 360 V8 and assorted goodies as well.
dunewolf
dunewolf is offline
PostPosted: Mon Mar 07, 2005 10:40 am    Post subject: 4 wd beetle Reply with quote
an idea that would work is to use hydrolic motors on the front wheels i saw it done before and it would take up like 4-5 horsepower for the motor and then you can turn it on and off a will. if interseted i can draw up some plans for it.
John Burkett
PostPosted: Mon Mar 07, 2005 5:25 pm    Post subject: Reply with quote
Dunewolf, It sounds like a good idea, what would be done to gear it. I do not want to run the same size tires front and rear, so thet could not be geared the same for fear of alot of extra stress on the car. Whatever you can think of would be helpful.
Also, does anyone have a link to any technical drawing of the 40's model factory a wheel drive. I would be interested in seeing how the come off the rear swingaxle to get power to the front end. Thanks, John
'66 bug
'68 baja
'80 jeep cj-5
FGB
FGB is offline
PostPosted: Tue Mar 08, 2005 9:04 pm    Post subject: Reply with quote
You Bet ... Ken Tranga In Sacramento Built 4 Play .... a 4x4 Manx powered by a B. Bergman . it uses a 4x bus trans …..In 2003 it won best of show at the Sac. Bug In and was covered in several 4x publications It can viewed as an avatar at the RBC Dune Buggy Forum at Ez Board.com…. and as a Buggy of the Month winner at Manx Club.com
Chris Dotson
Chris Dotson is offline
PostPosted: Mon Mar 14, 2005 8:12 pm    Post subject: Reply with quote
The 4x4 bug idea is cool and all but I take quite a bit of pride in kicking the big heavy stupid 4x4 trucks ass. Twisted Evil
At the same time when I saw the famous rock crawler called "TINY" I was very happy and proud. Shocked
"TINY" is an air cooled type 1 VW powered rock clawler that has won most all of the major awards in that field.
If you havent seen this master mind 4x4 VW you must try to look it up out there on the web. I dont rember which web site I saw "TINY" on but he is for sure out there. If I find any pictures of "TINY" I will post them in the off road section.
BAJA BUGS RULE!!!!
vwguy65
vwguy65 is offline
PostPosted: Mon Jul 24, 2017 8:13 pm    Post subject: Re: 4 wheel/all wheel drive beetle? Reply with quote
Not sure where I saw the info? I do know what you mean a 4x4 system that works off the aircooled tranny and engine...I would be interested too and I swore I saw that info on here some where and it could be Facebook.
View user's profile Send private message Send e-mail Yahoo Messenger Facebook Classifieds Feedback
Third
Third is offline
PostPosted: Mon Jul 24, 2017 8:44 pm    Post subject: Re: 4 wheel/all wheel drive beetle? Reply with quote
Kind of interesting.
Ran across this:
http://www.azbaja.com/ForumsPro/viewtopic/t=7845.html
Third
Third is offline
PostPosted: Mon Jul 24, 2017 9:08 pm    Post subject: Re: 4 wheel/all wheel drive beetle? Reply with quote
I knew I'd seen it somewhere as well.
LOL, right here in the Samba ads...
https://www.thesamba.com/vw/classifieds/detail.php?id=2024196
weasel_ugs
weasel_ugs is offline
PostPosted: Tue Jul 25, 2017 6:15 pm    Post subject: Re: 4 wheel/all wheel drive beetle? Reply with quote
Thats not VW like the original 12yr old post was inquiring about
Third
Third is offline
PostPosted: Tue Jul 25, 2017 7:45 pm    Post subject: Re: 4 wheel/all wheel drive beetle? Reply with quote
I know.
I was replying to the necromancer. Wink
He only specified engine and power plant (in which case the link applies).
