llopezaoval54 Samba Member
Posted: Tue Nov 04, 2025 8:51 pm Post subject: Early zwitter hood handle?? |
I recently get this hood handle.
In my knowledge, it's the same style as zwitter usual handles... solid.
But this one is cromed, however, it's a FRIVO one, that i think that it's earlyer than the Huf's ones that are more usual to find.
So, it's a zwitter handle or a early 53' oval one?
It's rare? Because i haven't seen one before whit the FRIVO stamp.
Thanks for any info!
https://imgur.com/crWquFb
https://imgur.com/wrIFpcl
https://imgur.com/9GnGwhz |
Zwitterkafer Samba Member
Joined: November 17, 2007 Posts: 1026 Location: Lanark County, Ontario, Canada
Posted: Thu Nov 06, 2025 1:42 pm Post subject: Re: Early zwitter hood handle?? |
Can you post a pic of the Frivo stamping? The 6-month Zwitter hood handle is solid Aluminum, and is stamped with the maker's emblem, plus a VW emblem, under the wider round base.
A chromed unit would most likely be made of pot metal, and therefore heavier. Without a VW emblem underneath it might not be OEM. It is probably not earlier because (1) pre-zwitter hood handles were also solid aluminum and (2) The trend was normally towards cost cutting, so pot metal eventually replaced aluminum. _________________ "Criticism comes easier than Craftsmanship"
- Zeuxius, 400 BC |
RUNKLE Samba Member
Posted: Thu Nov 06, 2025 3:55 pm Post subject: Re: Early zwitter hood handle?? |
llopezaoval54 provided imgur links, slightly hidden at the bottom of his post.
_________________ Type 1
Type 3
1968 Squareback |
Posted: Fri Nov 07, 2025 9:59 am Post subject: Re: Early zwitter hood handle?? |
Sorry, my mistake, I missed the links.
On my solid aluminum handle the VW emblem is slightly smaller, older looking, and stamped-in (incuse). A maker's script is also stamped in and is hard to read, could be Frivo as well.
On this cast zinc part, the mold was stamped with the script and with a much finer more open and modern looking VW emblem, resulting in raised features on the finished part. I will have to defer to the experts, but IMO this part is likely for immediately after March 1953. _________________ "Criticism comes easier than Craftsmanship"
- Zeuxius, 400 BC |
