FPGT72 Samba Member
Posted: Mon Jul 17, 2023 4:27 am Post subject: Trouble finding tranny mount |
I am having an issue finding this tranny mount, likely I am just stupid and am missing it, but I have tried a couple places and am not sure what to get to replace this.
Any help would be great.
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6490 Location: 37.5N 77.1W
Posted: Mon Jul 17, 2023 6:13 am Post subject: Re: Trouble finding tranny mount |
look at where it was. You can find the other half that's part of it. Best photo I could find
_________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires |
thomas. Samba Member
Joined: July 31, 2010 Posts: 1384 Location: South West (Pa.)
FPGT72 Samba Member
Posted: Tue Jul 18, 2023 4:15 am Post subject: Re: Trouble finding tranny mount |
What confused me was the original was "square" where the new one I have is "oval". It made me think I had ordered the wrong thing. Why did the design of the mount change?
RUNKLE Samba Member
Posted: Tue Jul 18, 2023 7:59 am Post subject: Re: Trouble finding tranny mount |
| FPGT72 wrote: |
| What confused me was the original was "square" where the new one I have is "oval". Why did the design of the mount change? |
Nothing changed. There’s two sides to the mount, the chassis side, and transmission side. The oval piece you speak of is the chassis mount, it had broken off over time, and what you were left with is the square transmission mount. The two pieces are molded together by rubber, so they can flex independently.
Also, if you haven’t already, you will need to get a transmission mount bushing, #8 in the diagram below.
_________________ Type 1
Type 3
1968 Squareback |
FPGT72 Samba Member
Posted: Wed Jul 19, 2023 8:29 am Post subject: Re: Trouble finding tranny mount |
| RUNKLE wrote: |
| FPGT72 wrote: |
Yes I have that as well. Just odd how it broke the "ears" off.
Thanks for your help. |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7452 Location: Clyde, TX
Posted: Wed Jul 19, 2023 8:37 am Post subject: Re: Trouble finding tranny mount |
| FPGT72 wrote: |
It's not odd at all, in fact that's the most common mode of failure for the front transaxle mount. The rubber "square" bolted to the transaxle nose cone is bonded to the metal plate which is bolted to the chassis. Over time the rubber tends to either tear or disbond from the metal and eventually ends up separating into two pieces as yours has done. It's useful to know that the bolts attaching the mount to the nose cone do not attach to the metal plate -- the only thing holding the mount together is the bond between the rubber and metal. _________________ 1960 Ragtop w/Semaphores "Inga" |
FPGT72 Samba Member
Posted: Thu Jul 20, 2023 6:40 am Post subject: Re: Trouble finding tranny mount |
| mukluk wrote: |
| FPGT72 wrote: |
It's not odd at all, in fact that's the most common mode of failure for the front transaxle mount. The rubber "square" bolted to the transaxle nose cone is bonded to the metal plate which is bolted to the chassis. Over time the rubber tends to either tear or disbond from the metal and eventually ends up separating into two pieces as yours has done. It's useful to know that the bolts attaching the mount to the nose cone do not attach to the metal plate -- the only thing holding the mount together is the bond between the rubber and metal. |
Learn something new, I have had this old girl for a very long time, it is an on again off again project. Hopefully this time I will get it finished.
I understand how to screw cars together, this is not my first rodeo, but I am new to VW. I did not know this was a common failure.
Thanks for the tips, I am sure I will have many more....well duh.....questions to come. |
