Tune up parts for 034 distributor
walter kandetzki
walter kandetzki is offline
PostPosted: Sat Feb 04, 2023 9:04 pm    Post subject: Tune up parts for 034 distributor Reply with quote
Hi folks I need to get condenser and points for my 034 distributor.I was reading blue streak is a pretty good brand.is there a way to cross reference the Bosch number to blue streak?thanks
Jimbug57
Jimbug57 is offline
PostPosted: Sun Feb 05, 2023 3:59 am    Post subject: Re: Tune up parts for 034 distributor Reply with quote
I recommend sticking with Bosch purchased from here - https://www.vwnos.com/
- Jim
Repeat after me "I am smarter than metal!"
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Feb 05, 2023 6:26 am    Post subject: Re: Tune up parts for 034 distributor Reply with quote
If i remember correctly, Blue Streak are made by SMP and SMP makes quality parts.
points GB-4173P
condenser GB136
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Al Capulco
Al Capulco is offline
PostPosted: Sun Feb 05, 2023 10:45 pm    Post subject: Re: Tune up parts for 034 distributor Reply with quote
Blue Streak is made by SMP, ( Standard Motor Products ). They have 3 different grades of points and condensers. Blue Streak is their top of the line.
The part number for their Blue Streak points that should fit your distributor is:
GB-4173XP. The X denotes the Blue Streak. Without the X are still very good points. Depending on what kind of 034 distributor you have (German or Mexican) will determine what condenser.
heimlich Premium Member
VWNOS.com
heimlich is offline
PostPosted: Mon Feb 06, 2023 10:52 am    Post subject: Re: Tune up parts for 034 distributor Reply with quote
Here's a list of parts filtered for the 034 distributor. It has everything you would need on it:
https://www.vwnos.com/Catalog/DistributorSearch?distributor=043%20905%20205%20
