wind 1, squareback 0
ddare
ddare is offline
PostPosted: Mon Jun 20, 2005 11:35 pm    Post subject: wind 1, squareback 0 Reply with quote
Granted my little shark-nosed beauty isn't the most aerodynamic thing on the road, and given that I live in one of the windier parts of the world (hence all the dang windmills outside of palm springs!), what can I do to improve the handling in the wind? Obviously tire pressure, alignment, perhaps a very large passenger, but is there a sway bar or something that can be added to improve control? My car hasn't been lowered to my knowledge, though I may if that'll keep some of the wind resistance down. BTW, approximately what height would a '72 be at, stock?
Kenaneu
Kenaneu is offline
PostPosted: Tue Jun 21, 2005 2:01 am    Post subject: Reply with quote
Nothing super-scientific or expensive here, but you could try tossing some snow chains or anything 25-75 lbs in the front trunk on windy days.
The extra weight in the front makes all the difference in helping my square not get tossed in the wind. It also helps to move the center of gravity forward a bit, which improves handling. I used to do this in the SF area until I finally built a decent sized subwoofer that sits in my front trunk. Smile
josh
josh is offline
PostPosted: Tue Jun 21, 2005 4:18 am    Post subject: Reply with quote
When I bought my square it was lowered with worn out shocks.
I raised it back to stock height, rebuilt the front end and installed KYB gas adjust shocks and it handles much better in the wind. The shocks are very stiff but it still rides better than it did when it was lowered.
There are some who say the stiffer shocks will cause the other front end components more stress. I don't know if it's true but it makes sense. I feel the improvement in handling is worth the risk. I keep good fresh grease in the beam. It is certainly easier on the suspension than lowering. Lowering the front end is extremely hard on it with a possible exeption for the use of drop spindles.
Air_Cooled_Nut
Air_Cooled_Nut is offline
PostPosted: Tue Jun 21, 2005 10:40 am    Post subject: Reply with quote
Lowering the car is not "extremely" hard on the suspension Rolling Eyes It depends on how much it's lowered as to the amount of additional wear it will see. From what I've seen it's the ball joints (a replaceable item) that get most of the abuse.
Anyway, stock tires help more than wider tires because the footprint is long instead of wide. This helps make the car want to go straight.
Weight in the car helps. Heck, I think the cars ride better with a load in them!
Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion
PostPosted: Tue Jun 21, 2005 10:45 am    Post subject: Reply with quote
Make sure your ball joints/tie rods/steering damper are all in good shape.
Make sure you have good tires (sidewalls not cracked)
Inflate the tires to the proper pressure. The front tires are low compared to a modern car, only 17-20 psi depending on what year your car is.
73notch
73notch is offline
PostPosted: Tue Jun 21, 2005 1:38 pm    Post subject: Reply with quote
cool, an aerodynamics thread
lower it
how about a front lip? i remember reading somewhere that a older golf or gti one could fit on with a lil massaging. can anyone confirm this or supply us with more info?
-Ryan
SubyNotch.com is back up!
ddare
ddare is offline
PostPosted: Tue Jun 21, 2005 1:52 pm    Post subject: Reply with quote
yeah, the sad part is I had my baby loaded up to the gills with stuff as we're moving back to the OC. Granted, not much in the trunk, but I checked my tire psi at 18 psi in the front and 28 in the back. Tires are in *fair* shape, and I need an alignment and I could probably stand to tighten the steering (there's an inch or two of slack, and it pulls to the right, though my tire wear is normal). I suppose what I was looking for was some kind of vendor for a sway bar.
Or I'll just do what I did in my old '69 el camino and load it up with sand bags Smile
blankmange
Type 3 Darksider
blankmange is offline
PostPosted: Tue Jun 21, 2005 2:26 pm    Post subject: Reply with quote
ask, and ye shall receive:
http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=SSS0002&cartid=
póg mo thóin
Certified DHS Technician
Samba Member # 24517
PostPosted: Tue Jun 21, 2005 3:20 pm    Post subject: Reply with quote
I've driven through the windmill area a bunch of times and never had much trouble with the wind so I suspect there is something wrong with your car.
Sounds like maybe the steering needs adjustment
jaransonT3 Premium Member
jaransonT3 is offline
PostPosted: Tue Jun 21, 2005 4:51 pm    Post subject: Reply with quote
lower it
-Ryan
I have some Type 3 specific aerodynamics stuff on my website. Go here to check it all out.
http://mywebpages.comcast.net/jaransonT3/jaransonT3/AeroPage.html
As for the front lip idea, here is the chart from my webpage that shows the influence of the front lip.
All that being said, I wouldn't worry about a front sway bar (your tpye 3 already has one built into the front suspension anyway) until you figure out why it pulls to one side, tighten the steering up and get it aligned.
Later,
John Jaranson
'66 Square (Sophy)
'67 Type 34 Karmann Ghia
'70-1 Fasty (Jane - the Lead Sled project)
'71 Westy (Sialia)
https://www.carartbyjohn.com
https://www.carartbyjohn.com/2026Invasion/
Air_Cooled_Nut
PostPosted: Tue Jun 21, 2005 5:05 pm    Post subject: Reply with quote
John sent me the aerodynamic text and it's available on my web site:
http://www.icbm.org/erkson/gallery/Aerodynamics
The First Invasion
Russ Wolfe
Russ Wolfe is offline
PostPosted: Tue Jun 21, 2005 7:29 pm    Post subject: Reply with quote
That picture is one on a T-1, I would like to see a pictur of one on a T-3. Besides, T-3's have a factory built in front sway bar.
Check the free play in your front upper bar. Grab the front wheels at the top, and rock them in and out while you watch the front suspension. The upper bar should not move in and out. If it does, use your Bentley and adjust the end play on the upper bar.
I drive severe cross winds all the time, and Yes, somedays are worse than others, but nothing worse than I get when I am driving my high profile 4x4 truck. Front tire pressure at 18-20, and rears at 28-30 psi. Higher rear pressure if heavily loaded.
Gary: OK. Ima poop.
ddare
ddare is offline
PostPosted: Tue Jun 21, 2005 8:36 pm    Post subject: Reply with quote
yeah, IIRC, Iowa can be pretty windy. I lived in Cedar Rapids for a while and I thought it was colder than when I lived in Montana, mostly because of the wind Sad
My Bentley is packed up, but I'm going to check my play in the wheels and steering. Once again, thanks for all the tips Smile
-doug
Russ Wolfe
PostPosted: Tue Jun 21, 2005 8:42 pm    Post subject: Reply with quote
Looks like John J. had another boring engineering meeting and "doodled" another T-3 avatar. Laughing
Gary: OK. Ima poop.
PostPosted: Tue Jun 21, 2005 9:46 pm    Post subject: Reply with quote
If you mean Toby's (air_cooled_nut) avatar, yup that is one of mine. I have another 3 hour offsite boring meeting tomorrow morning. Any requests? Very Happy
Later,
John Jaranson
'66 Square (Sophy)
'71 Westy (Sialia)
Anniehum
Anniehum is offline
PostPosted: Tue Jun 21, 2005 10:40 pm    Post subject: Reply with quote
One of my first road trips in Savanna, I hit a known cross wind spot. I was ready to be hit with wind but I was knocked over 2 lanes. Thank goodness there wasn't any traffic. I got the car home only to discover it wasn't just the wind, I had the front end rebuilt and the steering box tightened an lo and behold life on a windy road was much better. I carry my chains in the spare tire well and a case of oil for all my friends. Oh yeah , floor jack, jack stands and a few spare parts. I guess I have a bit of weight in the frunk.
Cheers
Ho'oponopono
kokomo808
kokomo808 is offline
PostPosted: Wed Jun 22, 2005 1:27 am    Post subject: Reply with quote
every onces in awhile on the freeway there are strong gust of wind that swoop down from the mountains & mother nature decides its time to change lanes Wink
but with a 90lb bag of cement in the front trunk that rarely happens now Shocked Laughing
What's more then chicken shit then f**king with another man's automobile? Don't f**k with another man's vehicle it's just against the rules.
- Vincent Vega(Pulp Fiction)
blankmange
Type 3 Darksider
PostPosted: Wed Jun 22, 2005 3:04 am    Post subject: Reply with quote
sure - black square with a white roof, late model, with early bumpers, painted white...
póg mo thóin
Air_Cooled_Nut
PostPosted: Wed Jun 22, 2005 8:58 am    Post subject: OT: Avitars by John Reply with quote
John made that for me outta the blue a while back. Going thru the posts here I saw your's and John's avitars together and thought I should use mine as well to keep the theme going Very Happy
The First Invasion
Russ Wolfe
PostPosted: Wed Jun 22, 2005 11:35 am    Post subject: Re: OT: Avitars by John Reply with quote
I still have my Fasty one, that John did for my web site, then the jave script broke. Crying or Very sad Crying or Very sad
Gary: OK. Ima poop.
