mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Thu Jun 24, 2021 6:23 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
dgsaz wrote: |
quartermilecamel wrote: |
Just took off the thunderer ranger r101 tires 195r15c 8 ply off the front of my 64 bus that had pressure at 30 and it was like white knuckle driving. put on my other prospector suv tires 205 75 15 load 1609. I think its much better.
https://simpletire.com/brands/thunderer-tires/rang...Zip=49501. I think the rangers are just too heavy a tire for a split bus. At pressures above 30 it seems not all the tread even contacts the road. Was afraid to run them with less than 30. Havnt run across anyone else using them and or pressures under 30 just to get them to be stable...........68 front end with new ball joints, center pin, drag link, tie rods ok, steering box rebuilt. |
I'm running the T-Rangers on my 1966 Sundial. 30 psi front 34 psi rear, Bilstein
shock and Addco swaybars fron and rear. These tires are white knuckle driving, especialy at freeway speeds. (65 mph).
I'm thinking this tire is too heavy for the bus. The drive feels "skatey", as if the tire is not in full contact with the road. I had a set of Hercules tires in a slightly different size and the drive tracked straight, didn't get blown around and handled well. Should have kept them.
I'm now looking at the Grabber ATX tire. Same height, in the 1600 lb range rather than the T-Ranger on the 2000 lb range. Now I'm thinking the bus doesn't weigh enough to make a good connection, tire to road.
What's the latest opinion on the Grabbers? 205-75-15
BTW- I'll have a set of T-Rangers with about 200 miles on them for sale soon.
$200 p/u in San Diego.
dgsaz |
maybe your tire pressure is too high? i would give that a shot. something in the 20s up front and maybe 30 in the back. try it as low as you can go without the tire sidewall bulging too much at the bottom. buses were built for bias ply tires. much more compliant than a radial _________________ regards
Uli
MrWhoopee Samba Member
Joined: October 24, 2005 Posts: 177 Location: Shingletown, CA
Posted: Fri Jun 25, 2021 9:23 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
https://www.performanceplustire.com/products/ts:tiresizeshort-lt195-70-15:ty:Tire/
Tire Size
LT195/70R15 104/102R 8 Ply
Manufacturer Part Number: WSC25
See Other Fitments
Tire Specifications
Speed Rating [?] : R
Sidewall Style [?] : Black Side Wall
Load Index : 104/102
Section Width : 195
Diameter : 15
Construction : 8 Ply Rated
Tire Construction : Radial
Speed Rating : 106 mph[/img] _________________ Craig ('51 WASP)
Rosie ('63 Double Cab) |
dgsaz Samba Member
Joined: November 04, 2008 Posts: 579 Location: Phoenix / San Diego
Posted: Mon Jun 28, 2021 4:59 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Almost the same specs as the T-Ranger. Are you running these? What psi?
dgsaz |
Posted: Mon Jun 28, 2021 5:08 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
dgsaz wrote: |
dgsaz |
I am not, I just found the listing. Not easy to find this size in LT rated tires. _________________ Craig ('51 WASP)
Lind Samba Member
Joined: November 06, 2000 Posts: 9917 Location: idaho
Posted: Mon Jun 28, 2021 5:23 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
mandraks wrote: |
dgsaz wrote: |
dgsaz |
maybe your tire pressure is too high? i would give that a shot. something in the 20s up front and maybe 30 in the back. try it as low as you can go without the tire sidewall bulging too much at the bottom. buses were built for bias ply tires. much more compliant than a radial |
I have driven my Achilles 195R15s (same specs as the thunderer rangers) for hours on end at 75mph. I have had them up to at least 82mph, and probably 85-86mph, and they feel solid as hell. I run them at 35psi. I have basically the same specs tires on five different buses and they all feel great. I run old boge shocks, and a stock bus sway bar, and all my steering is tight. _________________ .
Wanted:
BonTonRoulet Samba Member
Joined: September 29, 2020 Posts: 368 Location: Mississippi
Posted: Mon Jun 28, 2021 8:16 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Lind wrote: |
mandraks wrote: |
dgsaz wrote: |
dgsaz |
I have driven my Achilles 195R15s (same specs as the thunderer rangers) for hours on end at 75mph. I have had them up to at least 82mph, and probably 85-86mph, and they feel solid as hell. I run them at 35psi. I have basically the same specs tires on five different buses and they all feel great. I run old boge shocks, and a stock bus sway bar, and all my steering is tight. |
Obviously your parachute system worked after the bus free fell from being pushed out the back of an airplane at 30,000 feet? |
Lind Samba Member
Posted: Mon Jun 28, 2021 10:08 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
BonTonRoulet wrote: |
Lind wrote: |
nope, just a Porsche engine. Real speeds, with the GPS.
In the '80s, bugorama in sacramento advertised the fastest bus in the world, and they lifted a split panelvan up with a helicopter and dropped it. Seriously. _________________ .
Wanted:
iamdonquixote Samba Member
Joined: January 28, 2003 Posts: 2041 Location: M*ssholia
Posted: Tue Jul 06, 2021 7:00 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
having the same experience with the achilles tire. They seem to "hunt" way too much compared with the 10+ year old michellins ..
The bus has rebuilt spindles and I plan on doing the center pin , so the front end is not perfect but the difference was night & day when I switched to the achilles.
I'm considering going to something else. I have a set of vancos on 14" for another bus build that I may try on this bus (its a 67' that I have 15" wheels ). |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4574 Location: St Charles, MO
Posted: Tue Jul 06, 2021 8:24 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Lind wrote: |
Lind wrote: |
In the '80s, bugorama in sacramento advertised the fastest bus in the world, and they lifted a split panelvan up with a helicopter and dropped it. Seriously. |
When they did that publicity stunt, I was pissed, and placed them at the top of my "do NOT shop at" list!
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
scarceller Samba Member
Posted: Wed Jul 21, 2021 11:01 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
I just found this tire, it's a 195R15 that's 8 ply commercial rated at 2000lb
Triangle TR645 195R15C Load D 8 Ply Commercial
https://www.ebay.com/itm/303945337320
Super strong stiff sidewall.
Thoughts? |
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2358 Location: In the woods, Ontario
Posted: Fri Jul 23, 2021 7:52 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
scarceller wrote: |
Thoughts? |
I would think they would be just fine. |
dgsaz Samba Member
Posted: Tue Aug 10, 2021 10:26 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Mixing Tires
I'm not a big fan of A/T tires on the front of a bus. I would prefer to run a C or D rated truck tire on the front and an all terrain tire on the rear for traction.
Dirt road, not off road. I could run the BFG A/T or the Grabber A/T. Is there an issue with mixing tires? These tires are 250 lbs load rated less than the fronts.
I have always thought highway tread was best on pavement with regards to tire/road contact and handling in general. Long held belief (from my Uncle John who had a retread shop)
Have things changed and a/t tires are fine on the front, on 2WD. Obviously the a/t tires look cool. Does it still make a difference? |
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4533 Location: Cedar Falls, Iowa
Posted: Tue Aug 10, 2021 10:48 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
dgsaz wrote: |
Mixing Tires
I guess you can try anything you want. But, you would do well to do a very good job of feeling out your handling characteristics in a variety of circumstances.
The front of all T1's and T2's have vastly less weight than the rears. The easiest way to get balanced handling is to use tires the same size, then lower the inflation pressure in the front to even up the contact patch. Having all 4 tires the same certainly makes it easier to control the variables. Not to mention, adding in the spare tire to the equation. _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3450 Location: San Diego
Posted: Tue Aug 10, 2021 11:44 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Interesting idea about contact patch vs tire pressures, but how do you measure contact patch? |
Posted: Tue Aug 10, 2021 12:35 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
chrisflstf wrote: |
Oh, I'm VERY scientific: I read the owner's manual. Part about tire inflation.
I've driven near a million miles in these cars, more Vanagons than the early ones, but a goodly number of miles in 1970, 1969 double cab, 1971 Dormie, 1973, 1978 CEII.
Every one of these I could feel if one of my rear tires was low about as soon as I got to highway speed.
I'm in Iowa. Windy here! _________________ Al Brase
Vanagons:
Erik G Samba Member
Joined: October 16, 2002 Posts: 13285 Location: Tejas!
chrisflstf wrote: |
chalk. line of chalk across the tire. drive it straight. see how it scrubs the chalk off. change the pressure, repeat until you like your contact patch |
Posted: Tue Aug 10, 2021 1:27 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
I think finger printing ink would be better than chalk to get a full contact patch picture. I assume you could figure it out also, assuming tires and wheels are all same size on 4 wheels, by knowing the weight diff front to rear and adjusting that way. I always run less pressure in the front anyway |
Lind Samba Member
Posted: Mon Nov 07, 2022 7:41 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
I absolutely love the look of these tires. I have not yet bought a set to test their handling and longevity, but I plan to. They are a bit more than twice the price of the other radials that fit buses, but they look way better, and they look better than the Firestone bias plys, which have a low load rating and tend to wear pretty fast.
_________________ .
Wanted:
Posted: Mon Nov 07, 2022 8:15 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Lind wrote: |
agree on all counts. price is real high to be sure , but if i had a high dollar pressed bumper bus I'd be all over these. |
