CB breather q's
Ipaintem
Ipaintem is offline
PostPosted: Tue Oct 25, 2005 4:42 pm    Post subject: CB breather q's Reply with quote
Just got one today and have a couple questions before installing it.
Directions say the bottom holes go to the valve cover and or as well as the fuel pump block off. If you run the bottom to the valve covers, wont the hose take most of the oil. I know that its all going to end up in the same place, but it this ok?
I want to hook up the valve covers and the fuel pump block off to the bottom of the unit. There are only two holes there. Is it ok to T the two valve covers into one and use one hole in the box for the two covers and the other hole to the fuel pump
THe top holes I will just vent to atmosphere as suggested. Will this work OK? Thanks!!
turboblue
turboblue is offline
PostPosted: Wed Oct 26, 2005 8:59 am    Post subject: Reply with quote
I use one of the bottom holes to drain back to the pump block off and the other is plugged.
I tee the valve covers and run them ito one of the top holes and plug the other.
Then I put a small K&N style breather on a 90* fitting in the hole facing the shroud.
Look close and you can see the hoses in this picture:
http://img276.imageshack.us/my.php?image=rich25tp.jpg
Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!"
RIS
RIS is offline
PostPosted: Wed Oct 26, 2005 11:44 am    Post subject: Reply with quote
Never been a fan of the CB Breather, but that's a nice looking set-up Gary. Might have to reconsider one in the future.
Richard Sedoris - VW Performance & Machine - Youngstown, OH
http://rismachine.tumblr.com/
YouTube: https://m.youtube.com/channel/UCfTBCG4I61iVm_ROc8OAuOQ
Instagram: @rismachine
turboblue
PostPosted: Thu Oct 27, 2005 8:29 am    Post subject: Reply with quote
The only problems I've had with them RIS is the gland nut holding the box to the stand.
Only engages about 3 threads.
Next one will get that area machined thinner to allow more engagement.
That and some blue loctite.
Gary
[email protected]
roy@mofoco.com is offline
PostPosted: Thu Oct 27, 2005 2:43 pm    Post subject: Reply with quote
make sure you use sealant along with the o-ring for the cover otherwise it will leak.
Tom N.
Tom N. is offline
PostPosted: Thu Oct 27, 2005 7:35 pm    Post subject: Reply with quote
I received my CB breather a few weeks ago. My motor has to be completed before I install it. I preferred the look of the Berg Breather, but I figured for <$40 I would try the CB. Your clues so far are helping, I will have mine machined for a better fit.
Thanks!
bill may
bill may is offline
PostPosted: Sat Oct 29, 2005 11:16 pm    Post subject: Reply with quote
it wont work as good as my 1985 gene berg breather.
Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
Alan Willis
Banned
Alan Willis is offline
PostPosted: Sun Oct 30, 2005 9:26 am    Post subject: Reply with quote
Thats because Gene PERSONALLY built yours,Bill! Wink
turboblue
PostPosted: Mon Oct 31, 2005 8:11 am    Post subject: Reply with quote
So I suppose you've had both and chose the Berg unit based on side by side comparisons.
Gary
lostinbaja
lostinbaja is offline
PostPosted: Mon Oct 31, 2005 8:42 am    Post subject: Reply with quote
I had to machine the gasket surface of the breather box to keep it from leaking. Since then it works very well.
Jerry...
bill may
bill may is offline
PostPosted: Mon Oct 31, 2005 10:12 am    Post subject: Reply with quote
tried all kinds, bugpack,cb and the one that works is the hexaginal berg one. have not tried the berg oval one tho' - no modifications needed,and it dont clog up or puke like others.
www.sv2s.com
SBS #100
Ipaintem
Ipaintem is offline
PostPosted: Mon Oct 31, 2005 12:13 pm    Post subject: Reply with quote
IMO Berg stuff is way over priced. There is no doubt that MOST of their stuff is good stuff and well thought out, but damn!! THe CB unit has baffles like the Berg and I have sence bought and installed the CB unit with no probs and no leaks. It should work just as good as the Berg and cost $150 or more less. Plus, ever wonder why only 1/3 or so of their parts on the internet have prices? And ever wonder why they put an MSRP price on there? Arn't they the acutall manufacturer? Just something to think about.
a_67vdub
a_67vdub is offline
PostPosted: Mon Oct 31, 2005 12:22 pm    Post subject: Reply with quote
Quality costs. I have a CB breather. It's nice, but the quality is nowhere near that of the Berg breather.
