Turn signal switch?
donald.lemay
donald.lemay is offline
PostPosted: Thu Jan 07, 2021 2:32 pm    Post subject: Turn signal switch? Reply with quote
Got a question about the Wolfsburg West turn signal switch. I have all the wires hooked up and there is an extra wire. Bus is a 66 deluxe with the 66-67 switch-all the colors match my 66 diagram but confused buy the extra wire. Anyone experience this? Haven’t checked to see if it works yet. I’m going to test it out tomorrow.
66 13 window deluxe
2085cc
9to1compression
ported polished heads 40x36 valves
010 distributor
VS 42mm exhaust
40 IDF carbs
BarryL Premium Member
BarryL is offline
PostPosted: Thu Jan 07, 2021 6:57 pm    Post subject: Re: Turn signal switch? Reply with quote
Do you already have the high-low dip switch wire wired and operational when you test it?
Almanor23
Almanor23 is offline
PostPosted: Thu Jan 07, 2021 8:55 pm    Post subject: Re: Turn signal switch? Reply with quote
What color is the 'extra' wire? If it's the blue wire, it goes to the turn signal indicator on your speedo. The brown wire is for the head light flash feature. All the other colors probably found mates of similar color.
donald.lemay
PostPosted: Fri Jan 08, 2021 4:52 am    Post subject: Re: Turn signal switch? Reply with quote
Ok found out where “extra” wire went, kind of embarrassing I was looking at my 6 volt diagram and 8 have a 9 prong box and 12 volt system. Everything works except flasher switch screws everything up. I noticed the switch is bad(have to wiggle it and then the knob flashes and not lights) so I’ll give that a go later.
Thanks for your help
66 13 window deluxe
2085cc
9to1compression
010 distributor
VS 42mm exhaust
40 IDF carbs
donald.lemay
PostPosted: Sat Jan 09, 2021 9:59 am    Post subject: Re: Turn signal switch? Reply with quote
OK nine pin question. If I short -S to ground the flasher should work correct. Also the flashers should work with the key off in the key on. Mine only flashes the relay not the lights with the key on, with the key off I only hear the relay click once. Also I know my emergency switch I believe is no good. Just trying to see if I need both. Trying to rule out nine pin relay but I think it’s bad as well. Thanks for any suggestions ahead of time
66 13 window deluxe
2085cc
9to1compression
010 distributor
VS 42mm exhaust
40 IDF carbs
donald.lemay
PostPosted: Sat Jan 09, 2021 10:03 am    Post subject: Re: Turn signal switch? Reply with quote
Just wanted to throw it out there new WW harness and turn signal switch. Old nine pin relay.Everything working properly except emergency circuit.
66 13 window deluxe
2085cc
9to1compression
010 distributor
VS 42mm exhaust
40 IDF carbs
donald.lemay
PostPosted: Fri Jan 22, 2021 3:46 pm    Post subject: Re: Turn signal switch? Reply with quote
Problem solved new 9pin from WW and new to me emergency switch .
66 13 window deluxe
2085cc
9to1compression
010 distributor
VS 42mm exhaust
40 IDF carbs
