Stock 1973 Muffler Clamps and Nuts and Bolts
amishman
amishman is offline
PostPosted: Mon Nov 28, 2005 4:30 pm    Post subject: Stock 1973 Muffler Clamps and Nuts and Bolts Reply with quote
I purchased a stock style (made in Denmark) exhaust setup for my Thing from someone selling here on The Samba.
http://www.thesamba.com/vw/classifieds/detail.php?id=235521
Arrived safe and looks real nice. Much better than what I had. It came with all the pieces for both side including the gaskets but no of the bolts, nuts, or tailpipe clamps.
So, not sure if the old non stock exhaust I remove has the nuts and bolts needed but probably not or they are real rusty.
Does anyone here know what size and style of nuts, bolts, washers, and tailpipe clamps I would need and where can I get them. Certain grade of bolts? Not sure about the clamps also as I am a first timer on this.
Thanks for any advise. I figure I will need to get generic items but wanted to make sure I get the right generics.
tj
MedicTed
MedicTed is offline
PostPosted: Mon Nov 28, 2005 4:49 pm    Post subject: Reply with quote
Most suppliers should have the clamps. They are the same clamps used on the Beetle's tailpipes.
Ted Wojton
70 VW Bus Westfalia camper
2003 GMC Sierra
amishman
amishman is offline
PostPosted: Mon Nov 28, 2005 5:20 pm    Post subject: Reply with quote
Looking at my Thing Parts Manual, section 19, item # 15, called a
111 251 267 Clip, Exhaust Pipe
Looks to connected the muffler to the tailpipe. Hard to tell from the image it has but it does not look like a typical C style clamp but something special. Looks like one bolt and nut along with this clip holds the muffler and tailpipe together.
Is this a special part to the Thing only. Just looks unique from the image in the manual. Not ever seeing one before I can't tell.
Maybe someone here has this same style muffler and can confirm.
tj
MedicTed
MedicTed is offline
PostPosted: Mon Nov 28, 2005 5:50 pm    Post subject: Reply with quote
tj
I don't have a parts manual, so I cannot look at your item. However a Thing only part would have a "181" part number. Here is a link to tailpipe clamps that will work. They may not be correct for a concourse restoration.
www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D111%2D298%2D051%2DGR
Ted Wojton
2003 GMC Sierra
kubelmann
kubelmann is offline
PostPosted: Mon Nov 28, 2005 6:12 pm    Post subject: Reply with quote
All of the hardware that connects air cooled exhaust parts to the heads are common to all T-1 models and many others. Saying that when ever I redo an exhaust system I eliminate all of the exhaust clamps and replace them with welded flanges, gaskets and bolts. I NEVER reuse any exhaust hardware. There are a number of hardware materials that are best for exhaust systems. Copper nuts, stainless steel bolts. This hardware is available from folks like CB performance. I have a big box of exhaust hardware and none of it is stock VW stuff. Any muffler shop can add flanges that will allow the elimination of the exhaust clamp. But also remember that I do not use stock VW exhaust systems They do not offer the performance that I seek.
kubelmann
PostPosted: Wed Nov 30, 2005 11:08 am    Post subject: Reply with quote
http://www.cbperformance.com/catalog.asp?productID=403
is the link to purchase a complete stock VW muffler installation kit from CB performance. It is product # 3650 and sells for $6.95
[email protected]
mpb181@aol.com is offline
PostPosted: Wed Dec 22, 2021 1:30 pm    Post subject: Re: Stock 1973 Muffler Clamps and Nuts and Bolts Reply with quote
https://www.thingparts.com/exhaust-tail-pipe-clamp-fits-73-or-74-original-style-muffler/
Michael Basso
http://www.thingparts.com
New and Used VW Thing Parts Free advice
CALL 518 630 0173
