2tonedug Samba Member
Joined: November 11, 2005 Posts: 26 Location: calimesa
Posted: Thu Jan 05, 2006 9:29 pm Post subject: |
i just bought the 1500.00 micro stub kit from them two days ago. ouch... i bought a set of their front disc brake kits used. four piston calipers on all fours.. OH YAH!! |
DoDaBaHa Samba Member
Posted: Sat Jan 07, 2006 7:22 am Post subject: |
I have the beanie boy kit and Jamar rear disc and we had to cut the corner off the trailing arm to get clearance for the rear bolt connectting the bracket to the caliper. We cut it as a triangle off the corner and fit and welded a plate on it. We also had to get a spacer from Moore parts to get the caliper in line. We are doing final assembly today and will post results. |
USMCord1 Razorback
Posted: Sat Jan 07, 2006 9:50 am Post subject: |
2tonedug wrote: |
Go large or go home, Should do the trick for you. Now I have to go home. _________________ For a Good time |
UKbillybob Samba Member
Joined: August 20, 2005 Posts: 128 Location: Somerset, United Kingdom
Posted: Sun Jan 08, 2006 1:46 pm Post subject: |
We found that mounting the caliper bracket and the caliper upside down cleared the 3x3.
Anyway thanks for the help guys.
Heres a picture of the buggy in progress.
It's not mine but a customers who uses the name "cheeky Monkey" on thesamba
Skidmark Samba Member
Joined: June 17, 2005 Posts: 2988 Location: Minden, NV
Posted: Sun Jan 08, 2006 2:06 pm Post subject: |
Do you mean the caliper is at the bottom, or 6 o'clock position? If so I would be worried about the caliper getting hit by rocks or other ground clearance issues... _________________ "It's not complicated, it's just expensive!"
WARNING! This person has been consumed by the Dark Side.
www.socalbajas.com
http://i135.photobucket.com/albums/q148/bajaskidmark/SCBaja.jpg |
Posted: Sun Jan 08, 2006 2:18 pm Post subject: |
The caliper will actually be at 4 o clock but running the 35" tyres it is still a long way up.
And over here in the UK ours are all street buggies as we have nowhere to drive them off road. |
USMCord1 Razorback
Posted: Sun Jan 08, 2006 3:46 pm Post subject: |
No off-road! Well that just plain sucks, Man besides sex what the hell do you guys do for fun. _________________ For a Good time |
bajaherbie Samba Sooner
Joined: November 27, 2003 Posts: 2985 Location: altus, oklahoma
Posted: Sun Jan 08, 2006 4:34 pm Post subject: |
doesn't the bleeder valve of the caliper need to be on top???? _________________ blank |
Posted: Sun Jan 08, 2006 5:34 pm Post subject: |
We have alot of sex
Yes the bleed valve will be the wrong way up. You just bleed the caliper before mounting. Not a problem and often done on custom cars. |
