Searched with no luck, so....HELP!!!
meinvw
meinvw is offline
PostPosted: Sun Nov 13, 2005 6:42 pm    Post subject: Searched with no luck, so....HELP!!! Reply with quote
Hi all, I just picked up a 71 914 without an engine. I saw a few posts similar to my question but none that answered it. So here goes, what VW engines will bolt in without any adapters? Reason I ask is I have a T-3 Square that I thought about using the engine from, as well as a 74 bus engine that I can get. Also how about the trans from the t-3? How much modification is there to put the engine and trans in? Not worried about wiring, just mounting. Thanks in advance.
Heres a shot of her!
The memories of a man in his old age, are the deeds of a man in his prime.
Quando Omni Flunkus Moritati !
73 High roof, 91 Carat, 87 Weekender, Mr magoo buggy, 88 LT 28, 98 R32,81 Diesel double door, 73 tin top, 72 HR.
Bleyseng
Bleyseng is offline
PostPosted: Sun Nov 13, 2005 10:41 pm    Post subject: Reply with quote
Why not install the proper W code motor in it. It is very similar to the 411 motor with different heat exchangers. Different tranny? not many 5 speeds are set up for a mid engine layout not the shift rod set up a 914 has.
Used 80 hp 1.7L can be had for pretty cheap and use a 914 type flywheel so the starter works. A 74 bus engine has what 65hp? I guess it would be fun to drive around in sort of.
70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles
Rescue912
Ferdinand Sanford
Rescue912 is offline
PostPosted: Thu Nov 17, 2005 7:46 am    Post subject: Reply with quote
I have a '71 914 engine in the barn complete with D-Jet harness and brain. PM me if you are interested.
Beauty is in the eye of the key holder ...
meinvw
meinvw is offline
PostPosted: Sun Nov 20, 2005 6:57 am    Post subject: Reply with quote
pm sent!
collingsworth
collingsworth is offline
PostPosted: Wed Jan 04, 2006 10:48 pm    Post subject: Reply with quote
I have a great 1.7 with new dual carbs complete with heat exchangers and tranny from a 1973 year 914. I live in TN. I'll take $800 for everything. Bill 423-626-7977
meinvw
meinvw is offline
PostPosted: Thu Jan 05, 2006 4:25 am    Post subject: Reply with quote
Thanks, at the moment the car is on hold until I find another daily. Just bought one on e-bay and it needs more work than was stated so as soon as I get tat one straightened out will get back to you all.
