Top mounting front sway bar on standard bug
sprbxr
sprbxr is offline
PostPosted: Fri Feb 15, 2019 9:16 am    Post subject: Top mounting front sway bar on standard bug Reply with quote
Anyone have pics of front sway bars mounted on top of the control arms on a standard?
I am looking for more sway bar ground clearance and heard from various sources that this is a common method to gain clearance.
Thanks
1957 Oval Ragtop
1974 Thing
1966 Deluxe
1959 Panel
1967 Vert
1959 Semaphore Ragtop
johneliot
johneliot is offline
PostPosted: Fri Feb 15, 2019 9:53 am    Post subject: Re: Top mounting front sway bar on standard bug Reply with quote
I have dropped spindles on my 69 and this is my set up:
I don't think I've ever seen them start on the top of the control arm and then wrap around. And yes, those bolts have been turned up.
John
There is no distinctly American criminal class - except Congress.
Mark Twain
69 bug - "The Grey Ghost"
Kafer_Mike
Kafer_Mike is offline
PostPosted: Fri Feb 22, 2019 10:49 am    Post subject: Re: Top mounting front sway bar on standard bug Reply with quote
Whiteline makes an adjustable swaybar that mounts above.
Kafer_Mike
Build 'em fast...or let 'em sit.
sprbxr
sprbxr is offline
PostPosted: Sun Feb 24, 2019 3:11 pm    Post subject: Re: Top mounting front sway bar on standard bug Reply with quote
Unfortunately, Whiteline told me they stopped making that sway bar due to lack of demand.
1957 Oval Ragtop
1974 Thing
1966 Deluxe
1959 Panel
1967 Vert
67rustavenger
67rustavenger is offline
PostPosted: Sun Feb 24, 2019 4:05 pm    Post subject: Re: Top mounting front sway bar on standard bug Reply with quote
Keep an eye on that clamp bolt nearest the shock. Over time they settle a bit on the lower control arm and may come in contact with the shock body.
Mine did. I turned it back to the down position.
Good Luck.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
johneliot
PostPosted: Sun Feb 24, 2019 6:00 pm    Post subject: Re: Top mounting front sway bar on standard bug Reply with quote
Thanks for the heads up. I'll keep an eye on it..
John
Mark Twain
kangaboy
kangaboy is offline
PostPosted: Mon Apr 04, 2022 8:33 am    Post subject: Re: Top mounting front sway bar on standard bug Reply with quote
So was there any resolve to this? I have an issue with dropped spindles on my standard beetle that the bottom mounted sway bar is hitting the rim when I turn the wheel a bit. Can the sway bar (same as pictured above) be mounted on the top of the bottom trailing arm? Didnt wanna take it all apart and try if this wasnt a thing.
-74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
skills@eurocarsplus wrote:
Shocked
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out Laughing
vwfreek61
vwfreek61 is offline
PostPosted: Mon Apr 04, 2022 10:57 am    Post subject: Re: Top mounting front sway bar on standard bug Reply with quote
On Formula Vees one of the set of torsion leaves is replaced with a solid rod. So the sway bar is inside the front beam. On a full body VW, you might need to add coilover shocks to make up for the stiffness of the missing leaves.
Kenneth
1964 Bug with Saxomat
1976 VW/Harley Trike Autostick
1987 Vanagon Westy w/Subaru EJ25 and reversed 4EAT
VeeDubability on YouTube
View user's profile Send private message Instagram YouTube Gallery Classifieds Feedback
