mikeb Samba Member
Posted: Sun Feb 12, 2006 6:43 pm Post subject: square back towing |
i need to know if the regular tow bar for a bug will fit the square back?? i am thinking of purchaseing one in salt lake and i don`t want to rent a dolly to get it home. Thanks Mikeb |
FASTBACKDON The other insensitive jerk like Neil
Joined: October 08, 2004 Posts: 3592 Location: TORRANCE CALIF
Posted: Sun Feb 12, 2006 6:50 pm Post subject: |
bug tow bars DO NOT FIT type 3's rent the tow dolly if it is an automatic car tow it by the rear tires better yet get a full car trailer _________________ FUCK CANCER FUCK CANCER FUCK CANCER!!
Mom 25 months of standing up to Cancer R.I.P I miss you so much.
Buy my best friends stuff
http://www.thesamba.com/vw/classifieds/search.php?username=56TIMOTEO
(21:10:42) Jennepher: Russell is our proudest achievment. I feel like Samba created him from a little nugget of crap into a full blown adult. |
mikeb Samba Member
Posted: Sun Feb 12, 2006 7:00 pm Post subject: tow bar |
thanks, it is a standard transmission, so it is a tow dolly.MikeB |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sun Feb 12, 2006 7:02 pm Post subject: |
If it is an automatic, and you plan on towing with the rear wheels on the ground, you will have to drop the rear axle shafts.
Make sure the lug nuts and axle nuts are tight and the axle nuts have cotterpins in them. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
rloaircool Samba Member
Joined: January 21, 2004 Posts: 304 Location: Idaho Falls, Idaho
Posted: Sun Feb 12, 2006 7:23 pm Post subject: Re: tow bar |
mikeb wrote: |
It's usually only $5-$10 more to rent a trailer vs. a dolly. You can drive faster, don't have to worry about the tires falling off, and you can actually back the thing up. |
Posted: Sun Feb 12, 2006 7:46 pm Post subject: Re: tow bar |
vwlowryda wrote: |
mikeb wrote: |
very good point I forgot about backing up _________________ FUCK CANCER FUCK CANCER FUCK CANCER!!
dodger Samba Member
Joined: February 03, 2006 Posts: 15 Location: Yuba City, California
Posted: Sat Feb 18, 2006 6:06 pm Post subject: Tying down a square for transport |
Picking up my square tomorrow and trailering it home. I've never trailered a square (or a VW for that matter). Are there specific points that are good for connecting the ratchet ties to and others that are absolute "do nots"? |
Posted: Sat Feb 18, 2006 6:14 pm Post subject: |
Easy to tie down.
Around the axle beam in the front, and depending on the year, around the rear axle tubes in the rear on an early, or the IRS swing arm on an late models.
Watch that you don't pinch any brake lines. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop.
The rear axles you can strap and the front should be just as easy just dont strap the bumper it will twist cool post pictures _________________ FUCK CANCER FUCK CANCER FUCK CANCER!!
jashv Samba Member
Joined: September 01, 2004 Posts: 442 Location: Shepherdsville, KY
Posted: Sun Jul 09, 2006 7:30 pm Post subject: |
I hate to play dumb here, I almost lost my 05 Xterra and the 71 automatic squareback I was towing home on a 2 wheel dolley. I had to force it to drive 500 miles. All the way back home I passed motor homes towing new cars, 4wd drive cars, most of them HAD to be automatic.
Why can you not just put it in neutral? |
Posted: Sun Jul 09, 2006 7:32 pm Post subject: |
4wd drive cars typically have a transfer case with a Neutral in it. that disengages the transmission from the wheels.
On most modern automatics, there is no oil circulating when just the drive shaft is spining. And a lot of the cars you see being towed are front wheel drive, so once they are on the dolly, they are cool. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
notchback Insensitive Jerk
Joined: December 16, 2003 Posts: 7024 Location: Behind the Zion Curtain
Posted: Mon Jul 10, 2006 9:25 am Post subject: |
Most of them have a driveshaft disconnect or an axel lock copuling on them that allows them to flip a switch and it disconnects the driveshaft from the transmission and allows flat towing.
http://www.drivetrain.com/remco.html _________________
zeen wrote: |
Arguing with johnnypan is like mud-wrestling a pig. After a while you realize he just enjoys playing in the mud, winning the contest is not the point. |
FU#3 |
yona_usti Samba Member
Posted: Mon Jul 10, 2006 9:43 am Post subject: |
my pop's tow car has an external transmission pump that circulates the fluid while being towed. |
Posted: Mon Jul 10, 2006 4:19 pm Post subject: |
Back in the '50's, automatic transmissions actually had a rear pump that spun with the drive shaft. You could actually push start an automtic car. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
