Swing lever arm
Ragtop
Ragtop is offline
PostPosted: Fri Jan 26, 2024 8:28 pm    Post subject: Swing lever arm Reply with quote
Anyboby know if the swing lever arm from a spit is the same as an early bay?
sub-hatchtim
sub-hatchtim is offline
PostPosted: Sat Jan 27, 2024 9:49 am    Post subject: Re: Swing lever arm Reply with quote
It's not
58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S
Stocknazi
Stocknazi is offline
PostPosted: Sat Jan 27, 2024 12:03 pm    Post subject: Re: Swing lever arm Reply with quote
I believe you are thinking about the Pittman arm for early bay being the same.
They are the same, correct?
WANTED:
Thomas Jefferson
Ragtop
Ragtop is offline
PostPosted: Sun Jan 28, 2024 9:13 am    Post subject: Re: Swing lever arm Reply with quote
Stocknazi wrote:
I believe you are thing about the Pittman arm for early bay being the same.
I'm talking about the arm that connects to the center pin on the beam and the other end to the drag link. Is it the same on a 69 bay beam to a split beam
Thanks
also just noticed that I put spit not split Embarassed Laughing
Busstom
Busstom is offline
PostPosted: Sun Jan 28, 2024 9:44 am    Post subject: Re: Swing lever arm Reply with quote
The Bay swing lever has larger holes for the bigger, later rod end tapers.
cory464 wrote:
Ragtop
Ragtop is offline
PostPosted: Sun Jan 28, 2024 9:38 pm    Post subject: Re: Swing lever arm Reply with quote
Thank you 😊🙏
