912E engine rebuild
jhuis
jhuis is offline
PostPosted: Thu Mar 09, 2006 7:11 pm    Post subject: 912E engine rebuild Reply with quote
Need advice on an easy 912E engine rebuild on an engine with 82000miles, low power, one cylinder weak, and would like advice on obtaining a big bore kit 69mm german, having the heads worked, using the current fuel injection or webbers (what size?) no change in the cam. I don't need the emissions equipment so would like that to go, so probably webbers. Also, is there a good repair manual out there, Bentley or similiar? John.
Bleyseng
Bleyseng is offline
PostPosted: Thu Mar 09, 2006 10:14 pm    Post subject: Reply with quote
Send your good cylinders to Jake Raby to be bored out to 96mm and he will send you the correct pistons. This gives you a 2.1L engine
Send the heads to Hoffman Auto Machine in GA to have the heads rebuild. He is the best in the USA.
Keep the Ljet but change the cam out to a Raby 9550 to cool off the heads and oil temps as the stock cams run hot.
Running right, this 2.1L is good for about 115-120hp up from the 95hp.
You can use the Bus book for most of the engine repairs, I am not sure about a Bentley book for 912E's.
70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles
Rescue912
Ferdinand Sanford
Rescue912 is offline
PostPosted: Fri Mar 10, 2006 6:15 am    Post subject: Reply with quote
Keep the FI if you can. You'll get more mpg, better throttle response and save yourself $500 that you can use on a cam and those 96's.
Beauty is in the eye of the key holder ...
Jake Raby
Jake Raby is offline
PostPosted: Fri Mar 10, 2006 8:59 pm    Post subject: Reply with quote
I gotcha covered no matter which route you take....
I drive a RAT powered 912e everyday!
Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell"
