53 0val Samba Professor
Joined: July 03, 2003 Posts: 11396 Location: Irvine, CA
Posted: Tue Mar 14, 2006 11:54 am Post subject: Sperrwolf Shifter Locks |
Anyone have a date for these?
http://www.thesamba.com/vw/forum/album_page.php?pic_id=36355
Glenn thinks '52 thru '55. Any other possibilities? _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
DaveM Mad Samba Scientist
Joined: June 11, 2002 Posts: 3010 Location: Dry side of Oregon
Posted: Tue Mar 14, 2006 12:00 pm Post subject: |
lol, make that a bit bigger and I'd say it's some funky VW toilet or something.
_________________ Sounding like a broken record as to why You should be measuring protein during harvest in order to better your agronomic practices. |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Tue Mar 14, 2006 10:27 pm Post subject: |
| DaveM wrote: |
| lol, make that a bit bigger and I'd say it's some funky VW toilet or something. |
That particular shifter lock has been refered to as "the toilet bowl" for a nick-name in the past. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Posted: Tue Mar 14, 2006 10:52 pm Post subject: |
| RareAir wrote: |
If it had a shorter neck, it'd be the earlier 1950-52 version. There was one in the classifieds a few days ago, sold for $125  |
Thanks.......I knew that there was a difference in years, but I couldn't pin it down. And the seller F#@ed up big time on that one.  _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Lind Samba Member
Joined: November 06, 2000 Posts: 10285 Location: idaho
Posted: Wed Mar 15, 2006 12:17 am Post subject: |
| 53 0val wrote: |
| RareAir wrote: |
Thanks.......I knew that there was a difference in years, but I couldn't pin it down. And the seller F#@ed up big time on that one.  |
I was number 7 to view that ad. I typed that I would take it as fast as I could and got lucky. the price was actually $120. I will be installing it onto my '61 bus later this week. I believe that it is period correct for that bus, but I will have to doublecheck. it is going on the bus either way.
I have a few technical bulletins which show different styles of sperrwolfs, and this one that I just got is the latest "toilet bowl" style from what I can tell. the later styles have flatter sides. I will scan the bulletins and post their dates and styles next weekend. I did a bit of research on these a few years back, and I even have the user id "sperrwolf" on ebay, although I rarely use it. to use a sperrwolf on a bus, you have to use a "quickshift" spacer under the sperrwolf unit. also, reproductions are still available through the aftermarket.
I had a short neck one a few years back which took a splitwindow beetle key. it was too early for my ghia so I sold it. (it is the first one pictured below)
here are the various styles that I have seen pictures of on the internet:
_________________ .
Wanted:
Posted: Wed Mar 15, 2006 7:01 am Post subject: |
Great information Lind..........keep it coming. More needs to be know about this accessory. What was Sperrwolf's relationship to VW? How long did it last? _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Posted: Wed Mar 15, 2006 8:19 am Post subject: |
| Lind wrote: |
| I will be installing it onto my '61 bus later this week. I believe that it is period correct for that bus, but I will have to doublecheck. it is going on the bus either way. |
That Sperwolf locker will NOT fit a Type 2 shifter without some modifications. You're going to need more than just a quick shift spacer under that locker to work with your Type 2 shifter.
Problem #1. It requires you to use a Type 1 shifter pedalstal as well. The Type 2 pedalstal is too tall to fit under the locker assembly. This will change the fulcrum poiunt of the shifter since the Type 2 pivot point is located higher up on the shift shaft when compared to a Type 1 shifter.
Problem #2. The mounting bolt (scene in the pic) is a hollowed bolt which allows the deadbolt mechanism to lock the shifter in place. It is only long enough for a standard Type 1 fitament. After installing the quick-shift spacer, the bolt will no lonbger be long enough to reach the threaded nuts on the shift rod hanger (under the car). You'll need to have a bolt custom made to length. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Posted: Wed Mar 15, 2006 8:21 am Post subject: |
| Lind wrote: |
| RareAir wrote: |
I was number 7 to view that ad. I typed that I would take it as fast as I could and got lucky. the price was actually $120. |
I was number 22 to view that ad. Damn it Lind..... _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Posted: Wed Mar 15, 2006 8:23 am Post subject: |
| 53 0val wrote: |
| Great information Lind..........keep it coming. More needs to be know about this accessory. What was Sperrwolf's relationship to VW? How long did it last? |
According to the birth certificate of my '54 sunroof, the SperWolf locker was option code M55.
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Lind Samba Member
Posted: Wed Mar 15, 2006 9:17 am Post subject: |
| RareAir wrote: |
| Lind wrote: |
| RareAir wrote: |
I was number 22 to view that ad. Damn it Lind..... |
LOL. the guy said that there were a few people wanting to buy it if I didn't want it. I was just praying that nobody offered more money and/or the seller stuck to the deal (like any ethical seller should). I got the paypal send as fast as possible. I guess it is karma for the times that I have sold things and turned down higher offers that came in later to sell the item as agreed.
| RareAir wrote: |
| Lind wrote: |
Problem #2. The mounting bolt (scene in the pic) is a hollowed bolt which allows the deadbolt mechanism to lock the shifter in place. It is only long enough for a standard Type 1 fitament. After installing the quick-shift spacer, the bolt will no lonbger be long enough to reach the threaded nuts on the shift rod hanger (under the car). You'll need to have a bolt custom made to length. |
the ones that I have fit before were the aftermarket reproductions which are a copy of the later style sperrwolf. (I believe that they are actually south american VW produced because they use VW logo keys). all they required was the quickshift kit and some longer bolts, but hardware is not an issue for me, as I have plenty of that. I will see if there are other mods required for the early unit and report back with my findings. _________________ .
Wanted:
racerx45 Samba Member
Joined: August 27, 2005 Posts: 169 Location: Santa Rosa, CA
Posted: Wed Mar 15, 2006 9:19 am Post subject: |
I have one like this and have a few questions about it.
1. I am planning on putting it in my ’64 Squareback, would it be correct for that year?
2. I believe the electrical connector is for an ignition cut-out. If so I am missing the part that plugs into the lock housing. Are there replacements for this or a wiring diagram?
3. Other than missing the flap that covers the key hole and the plug it is complete and working, what’s it worth?
Thanks, _________________ Early 64 1500S Variant (Red Needle and Push buttons)
1963 T34 |
Lind Samba Member
Posted: Wed Mar 15, 2006 9:32 am Post subject: |
| racerx45 wrote: |
Thanks, |
I believe that one is stock for mid '60s. I have seen one installed on a '65ish karmann ghia from back in the day (the car was being parted out fifteen years ago, so it was not a recent addition at that point) I don't know the differences between type I and type III shifters of that era, but there might be some incompatability in that department.
I will see if my technical bulletins have on this late. I can't remember offhand.
not exactly sure on the value of a later unit like that, but I would speculate that it is in the $200+ range in that condition if it works. I quit watching the ebay market on them a couple years ago when they would all go for more than I was willing to pay. _________________ .
Wanted:
Lind Samba Member
Posted: Wed Mar 15, 2006 9:35 am Post subject: |
| 53 0val wrote: |
I think that sperrwolf was just the name of the accessory and it was produced specifically for VW. they come in VW boxes. I have never heard of a sperrwolf for any other make of car, and I used to search ebay germany specifically for them. _________________ .
Wanted:
Posted: Wed Mar 15, 2006 2:54 pm Post subject: |
| Lind wrote: |
the ones that I have fit before were the aftermarket reproductions which are a copy of the later style sperrwolf. (I believe that they are actually south american VW produced because they use VW logo keys). all they required was the quickshift kit and some longer bolts, but hardware is not an issue for me, as I have plenty of that. I will see if there are other mods required for the early unit and report back with my findings.[/quote]
The SperWolf "toilet bowl" locker is a world apart from the recent production lockers. If you view the early SperWolf from the bottom, it is completely hollow. The way it mounts is simple. You remove the two 14mm bolts holding down the stock shifter. Do not remove any parts of the stock shifter, rather just simply place the locker over it. The original 14mm rearmost bolt can still be used to bolt down the locker. But the front bolt is now replaced with the special hollow bolt.
Instead of a curved arm to lock the shifter into reverse (ie Berg, late-SperWolf), the early locker has a deadbolt system which drives a hardened pin into the hollow section of the mounting bolt. It's very cool. Once you recieve the locker, you'll see what I'm talking about.
To mount it to your Type 2, is going to take some modifications & custom engineering on your part. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Nessy Samba Member
Joined: September 28, 2004 Posts: 424 Location: Wales,UK
Posted: Fri Mar 17, 2006 8:09 pm Post subject: |
Thought I'd post a few pics of my NOS Sperrwolf lock, guess it must be mid 1960's going by the info on this thread and the illustrations of VW's on the instruction leaflet.......
Its never been used, but am a bit puzzled by the seemingly Type 2 part number on the box ; 211 016 051 can anyone shed any light on this? Does this mean it could be fitted to a Type 2?
Lastly, having owned this for about 12 years now I don't really know what its worth (not that I'd sell it! ), can anyone give me an idea please?
Thanks!
 _________________ 1972 1302LS Convertible RHD |
Posted: Fri Mar 17, 2006 8:28 pm Post subject: |
Yes, you're particular shift lock was intended for use in a Type 2. That's why it is equipped with that spacer, to retain the fulcrum point as stock. If you plan on using that lock on a Beetle or Ghia, delete installing the spacer. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Nessy Samba Member
Posted: Fri Mar 17, 2006 8:30 pm Post subject: |
| RareAir wrote: |
| Yes, you're particular shift lock was intended for use in a Type 2. That's why it is equipped with that spacer, to retain the fulcrum point as stock. If you plan on using that lock on a Beetle or Ghia, delete installing the spacer. |
Thanks for that info, never intend fitting it though!
Lind Samba Member
Posted: Sat Mar 18, 2006 11:42 am Post subject: |
here are the scans of the installation instructions for type I and type II. I had a couple tech bulletins for each. (1958 and 1961) it looks like the later ones have the wires for the electrical portion airbrushed into the photos.
http://westfaliaregistry.com/literature/sperrwolf/ _________________ .
Wanted:
gabvwkey Samba Member
Joined: December 11, 2002 Posts: 423 Location: El Cajon, CA 92020
Posted: Mon Mar 27, 2006 1:29 pm Post subject: Sperrwolf lock |
| Nessy wrote: |
Thanks!
Wow! That is a beautiful example of a Sperrwolf lock!
We specialize on VW keys and locks, and the last one I sold in that condition, (minus the brochure & key fob) $500.00 it sold in a few hours!
Gabriel. |
