1960 double cab questions / 59-60 rear bumper
Braukuche
Braukuche is offline
PostPosted: Tue Mar 21, 2006 12:39 pm    Post subject: 1960 double cab questions / 59-60 rear bumper Reply with quote
This is my first double cab and it is a bit rustic, no interior etc. Do double cabs take different rear bumpers than a kombi or standard? Should the bumpers be pointed or slashed? Did double cabs have perforated headliners or board material like the door panels? Did double cabs have arm rests in the back? Is the rear seat pedestal much different from a '63 up pedestal? Are the engine lids different from a standard?
Thanks for any help. I looked at some pix in the gallery but couldn't find any info on these matters.
--Dan
Summary of bumper differences
Kommercial wrote:
Here is a normal bumper, 61-67truck/59-67bus:
Here is a "truck only" bumper, 59-60
Notice the distance between the blade edge and overrider tube. About half as wide on the 59/60 version. Basically the blade edge is just ground back for more body clearance.
Both of these bumpers are cross compatible/will fit through all years on both buses and trucks.
Note: Splash pans above should be black
D-train wrote:
just on claras info
After the 5th of Jan 1960, ALL rear bumpers were the same for every model.
Prior to that 59-60 was the slash ute bumper only, an prior to that was the pressed ute bumpers.
right hand side near the bottom states it.
from chassis 554147
see the difference between the normal n pick up
the white one is the elusive bar, the black one a normal slash bar
Aaron
Samba Luddite
Aaron is offline
PostPosted: Tue Mar 21, 2006 12:53 pm    Post subject: Reply with quote
Ok, as far as I know: rear bumper is different, so are the splash pans and it should be "slash" style on a '60, headliner should be fiber board, no arm rest in the back, not sure on the pedestal might be the same until '64?, engine lid is the same. Good luck with it....DCs are still my favorite style VW that were made.
MConstable
MConstable is offline
PostPosted: Tue Mar 21, 2006 12:56 pm    Post subject: Reply with quote
Another great site for truck info is dropgates.com...
Headliner is board material like the door panels,
Rear bumper is Truck-only, but near impossible to find.
1974 Thing
Clara Premium Member
Clara is offline
PostPosted: Tue Mar 21, 2006 1:01 pm    Post subject: Re: 1960 double cab questions Reply with quote
--Dan
What VIN? 59 though mid 60 had a truck rear that is very similar to regular rear... mid 60 & later (at VIN 554 147 in Jan 60) they standardise dthe rear bumper for all type IIs. Slash was used throuh mid(?)'65
No armrests. Grey masonite panels in rear, front and on ceiling. Strips of masonite between the 4 pieces of cab roof panel, not metal trim strips as in single cabs.
The only time the engine lid was special for trucks was for barndoors.
I dunno about rear seats in DCs
Long-roofs
Long-roofs is offline
PostPosted: Tue Mar 21, 2006 1:12 pm    Post subject: Reply with quote
I know the later (sometime around '63) double cabs had a flat rear seat bottom and base.
Trying to keep poor cool
People are talking, the greatness is coming, going to be greater than great, so great, greater than anything ever.
Braukuche
PostPosted: Tue Mar 21, 2006 1:55 pm    Post subject: Reply with quote
You guys are great! I'm at work so I don't have the VIN, but I'll post once I get home. So, what is the difference between a truck bumper and a standard? Is it impossible to use a standard bumper on a truck?
I've seen those repopped pedestals on this site and $500 is a lot of bones especially when there is a guy selling a used one for $185, but its for a "63 or later." I just wonder what the difference is??
Also, you say "flat seat bottom" I have what I beleive is a hump backed seat bottom for the back of mine. Is that correct then for '60?
Thanks again!
--Dan
matthew henricks
matthew henricks is offline
PostPosted: Tue Mar 21, 2006 8:58 pm    Post subject: Reply with quote
More tidbits.
Middle and rear headliner panels have no pattern in the material as with all three rear side panels. Only the door panels, front kick panels and front headliner panels have the pattern. (That means you can make all of them from 1/8" fiber board from Home Depot if you have ratty ones for patterns Smile )
Rear seat pedistal changes:
Sometime in 60 the rear mounts flipped from going inside to outside. (or is it the other way around.... don't remember)
64 the dip along the front went away and the seat no longer was the same as the front seat. (minus the re-inforcment bar of course)
Another 1960 items is cut down side gates and all early DC's (pre 64 i think) have unique rear pop out window frames with Barn Door style latches.
Clara is offline
PostPosted: Tue Mar 21, 2006 11:42 pm    Post subject: Reply with quote
It is a very small difference for the 59& later. Basically, don't worry about it unless you are doing a 100 point resto, just get a slash rear bumper, it fits fine.
DaveM
Mad Samba Scientist
DaveM is offline
PostPosted: Wed Mar 22, 2006 9:46 am    Post subject: Re: 1960 double cab questions Reply with quote
Clara wrote:
>snip>Grey masonite panels in rear, front and on ceiling. Strips of masonite between the 4 pieces of cab roof panel, not metal trim strips as in single cabs. <snip>
hmmm, I do believe my 59 dc had the metal strips between the two front headliner panels and the thin middle headliner piece. the masonite strips were between the middle and large rear panels.
Also note, there are different stamp patterns on the back of the masonite. Make sure you find the correct years.
Sounding like a broken record as to why You should be measuring protein during harvest in order to better your agronomic practices.
Clara is offline
PostPosted: Wed Mar 22, 2006 10:02 am    Post subject: Re: 1960 double cab questions Reply with quote
Really? Maybe that's a year thing... it is so hard to find good interior shots of DCs in the gallery... I looked through pages and pages and pages... eventually I found a few.
Yes there were different materials used as panels in different areas of the type IIs, it also changed depending on year of bus.
DaveM
Mad Samba Scientist
DaveM is offline
PostPosted: Wed Mar 22, 2006 10:10 am    Post subject: Re: 1960 double cab questions Reply with quote
Just grab 'n' different front headliner pieces and flip them over, there are three different types of masonite that I have found.
Kommercial
Kommercial is offline
PostPosted: Wed Mar 22, 2006 11:54 am    Post subject: Reply with quote
1960 headliner
http://dropgates.com/gallery/Double-cab/atk?full=1
Kommercial
PostPosted: Wed Mar 22, 2006 1:24 pm    Post subject: Reply with quote
Braukuche
PostPosted: Wed Mar 22, 2006 1:27 pm    Post subject: Reply with quote
Kommercial wrote:
1960 headliner
Thanks for the pix of the headliner and bumper. Makes it all clear, except what is that material along the seam of the headliner? Just headliner material I assume?
--Dan
Kommercial
PostPosted: Wed Mar 22, 2006 1:31 pm    Post subject: Reply with quote
yes
HappyTheMan
HappyTheMan is offline
PostPosted: Mon Apr 18, 2011 3:35 pm    Post subject: Reply with quote
matthew henricks wrote:
More tidbits.
Is this true? And if so what about the strips between the front and middle headliner pieces? Patterned or no?
thx,
Happy
IN2RUST
IN2RUST is offline
PostPosted: Mon Apr 18, 2011 3:41 pm    Post subject: Reply with quote
No
RUSTFARMER....I like anything old and rusty!
hsosa1
hsosa1 is offline
PostPosted: Tue Apr 19, 2011 4:47 pm    Post subject: Reply with quote
Question on the cargo door window frame. was the frame a only truck window frame or is it the same for all bus types. I know the latch came with black knobs and different size where it bolts to the window frame.
Just Cruzin Sur Califas VW Car Club est♤1998
View user's profile Send private message Visit poster's website Twitter Gallery Classifieds Feedback
IN2RUST
IN2RUST is offline
PostPosted: Tue Apr 19, 2011 4:50 pm    Post subject: Reply with quote
Truck only till 61
PostPosted: Tue Apr 19, 2011 5:25 pm    Post subject: Reply with quote
To generalize, it is similar to the 53 and earlier Bus pop-out frames as well.
