redstuffus Samba Member
Joined: December 30, 2005 Posts: 4 Location: santa clara ca
Posted: Thu Apr 06, 2006 8:20 pm Post subject: tar paper removal |
| any tricks on getting tar paper up from the floor.some say heat it,some say not to.anyone done this recently.need advice.thanx to all |
McGuirk Samba Member
Posted: Thu Apr 06, 2006 9:35 pm Post subject: |
I think it depends on the condition of the tar boards--if they're really bonded to the pan or not. Luckily on mine, I was able to pull off a good portion of them by hand. I found it easiest to not heat them or use any kind of solvent. I used a heavy duty scraper tool to chip off the remaining pieces. It took a while, but I think the other way would be a lot messier.
During
After
Posted: Thu Apr 06, 2006 10:40 pm Post subject: |
| about the same condition,most of it came up,just minor peices that will scrape off,just taking a long time,which solvent would you recommend if any is needed.very nice by the way and thanx |
Matt Miller Samba Member
Joined: October 24, 2005 Posts: 282 Location: Costa Mesa, California
Posted: Thu Apr 06, 2006 11:21 pm Post subject: |
| knock off the major chunks of the tar board with a hammer and cold chisel or an old large flathead screwdriver. then use a 4 inch angle grinder with a wire brush on it to get the left left over tar tidbits and old paint off with major ease. |
renderit Samba Member
Joined: October 09, 2005 Posts: 1155 Location: Austin, TX
Posted: Fri Apr 07, 2006 3:46 am Post subject: |
Used a very stiff putty knife (scrapper) and a hammer. Came off relatively easy. _________________ Tomorrow I tested the theory that cooking instant grits in the microwave makes you go back in time. |
SuperDave63 Samba Member
Joined: September 23, 2005 Posts: 282 Location: Chicago Area
Posted: Fri Apr 07, 2006 6:49 am Post subject: |
| Ditto on what they said. Use a cheap chisel to scrap most of it and an angle grinder with a wire wheel to clean it the rest of the way. Heat might just make a mess of it by softening it up and causing it to smear all over. |
suburbiana Samba Member
Joined: July 10, 2005 Posts: 23 Location: Langley, BC Canada
Posted: Fri Apr 07, 2006 8:15 am Post subject: |
DO NOT use heat! My boards looked the same as McGuirk's, except they had a cheapo piece of Dynamat-wannabee produt under each seat area - the first thing I did was hit it with heat gun and scraper, what a mess! Spent the next day with a can of aircraft stripper trying to undo the mess I made (BTW, that stuff will get your floors down to bare metal pronto, which makes it really nice to clean up the surface rust). For the rest of the project I simply used a scraper and finessed as much as I could off manually, the little bit left all came up after I used the stripper/brush/wire wheel.
Craig |
vwoval.com Samba Member
Posted: Fri Apr 07, 2006 8:18 am Post subject: |
Manual Labor. Some I have simply pulled up.. others have taken the hammer and flat wide driver to peal it up one row at a time. _________________ chris
>[email protected]<
www.vwrides.com, check it out. |
KantDriveFast Samba Member
Joined: January 08, 2005 Posts: 4293 Location: Caldwell, Id.
Posted: Fri Apr 07, 2006 6:10 pm Post subject: |
Agreed...in fact, get the car as cold as possible...the tar will be more brittle, crack in bigger pieces, and separate from the floor cleaner. Hot tar is, well, HOT TAR...kinda messy. |
67 Florida Deluxe Samba Purist
Joined: June 21, 2005 Posts: 7990 Location: Gainesville and Tampa, Florida
DominoTree Samba Member
Joined: February 13, 2006 Posts: 96 Location: Bakersfield, CA
Posted: Thu Apr 20, 2006 11:03 am Post subject: |
| Good old fashioned gasoline will totally dissolve that stuff. |
Hakka Samba Member
Joined: November 21, 2004 Posts: 624 Location: PNW or Norway
Posted: Thu Apr 20, 2006 11:06 am Post subject: |
| I use the end of a file to get the chunks off. Then that go-jo orange hand cleaner seems to help get alot of it off as well. But I guess gas might get desolve it like stated above. |
66topdown Samba Member
Posted: Thu Apr 20, 2006 5:26 pm Post subject: I used heat successfully |
| I did some by scraping first and getting everything off as well as possible. Then I used the torch and some paper towels to heat and wipe a small area at a time. Then I used some solvent to finish it off. It was very clean when I finished. |
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9016 Location: Portland, OR
Posted: Thu Apr 20, 2006 5:46 pm Post subject: |
I did it cold with a chisel and then used solvent.
Heat is not good. |
jaymie Samba Member
Posted: Thu Apr 20, 2006 5:57 pm Post subject: |
I used heat with no problem, yes it was a little messy but not that bad and it did the job. _________________ If you can't beat 'em, join em'!!
Slowest Time Ever!!!
Northern United Transporter Society - Founding Member
1/4 Mile Kittens
www.commercial-air.com
www.nuts.commercial-air.com |
D'sBUG Samba Member
Joined: October 29, 2005 Posts: 133 Location: South of Seattle WA
Posted: Fri Apr 21, 2006 10:04 am Post subject: |
| I did it cold, chisel, elbow greese, wire wheel and most of all tender love and care. |
stinger381 Samba Member
Posted: Sun Apr 30, 2006 11:09 am Post subject: |
| I took mine off with an air compressor and an air hammer with a cold chisel attached. |
VeeDubya Samba Member
Joined: April 18, 2006 Posts: 76 Location: Nederland, TX
Posted: Mon May 01, 2006 7:41 am Post subject: |
I wouldn't rcommend using gasoline. Brake parts cleaner get the stuff off very well, and is safer than gasoline. And possibly cheaper! I used scrapers and a 4" grinder with heavy steel cup brush to remove the stuff from my 914 and finnished up with brake parts cleaner.
I'll be doing the same project soon to my '65. What do you guys recommend I gho back with? New tar boards, dynomat??? |
Schnitzelfuss Samba Member
Joined: September 18, 2024 Posts: 188 Location: North Alabama
Posted: Mon May 19, 2025 9:06 am Post subject: Re: tar paper (board) removal |
No heat, just makes a sticky mess. And using a wire wheel will generate heat and leave a sticky mess and a ruined wire wheel. Unless you don’t mind leaving tar residue on everything the wire wheel touches after you’re done with this job.
I found using a large scraper gets all the big stuff and for any sticky reside that is just smearing around Oil Eater worked great. Spray the residue, let it sit a minute, then scrape. It turned the tar residue into a consistency similar to that clear rubbery adhesive that holds the cardboard labels on plastic lunch meat containers. Scrapes right off and leaves a clean surface underneath. BTW Oil Eater is paint safe and works very well on the engine, trans, etc. as well.
