iprangen Samba Member
Joined: December 10, 2007 Posts: 474 Location: Centerport, NY
Posted: Mon Apr 21, 2008 9:10 pm Post subject: Metal-dash Bay Windows? |
I see metal-dash Bay Windows for sale in Europe once in a while. What is the deal? What do they look like? Can I convert my '71 to look like that? Also, the area behind the front seats...can I just take off the black plastic material so that it looks clean and factory intended?  |
baywndwjunkie Samba Member
Joined: August 28, 2007 Posts: 336 Location: El Dorado Hills, Ca
Posted: Mon Apr 21, 2008 9:16 pm Post subject: |
the dash is a euro dash..not found here much in the states...might try a vw yad..i have seen one before. don't know about the black plastic stuff though bro..i'm sure you could do it if you wanted too!  _________________ \m/ (^_^) \m/
1977 Chrome Yellow Westy aka "Charlie Brown" |
EZ Gruv King of Plaid
Joined: December 10, 2002 Posts: 8577 Location: Las Vegas
Posted: Mon Apr 21, 2008 9:24 pm Post subject: |
You dont want to take the black padded stuff off. There are a lot of extra holes in the metal under there.
_________________ Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page. |
NinetyEight Samba Member
Posted: Tue Apr 22, 2008 12:08 am Post subject: |
If I am correct the holes on the corner are only on the late bays. However, I do believe the holes in the lower section of the dash are in all models. There are a ton of threads on here if you use the search.
If you can live with the holes on the corners, or can weld them closed, there are a couple options I can think of for filling the other holes. You could possibly makes plates out of steel that fit right in the section over all of the holes, and drill the holes out for the ones you need. Or With as many modern features as most people are putting into their busses, you could easily fill the holes with switches and buttons. _________________ Otto Bus - 1978 Daily Driver
Rico - 1975 Bay
http://www.FromTheEyesofABus.Blogspot.com |
NASkeet Samba Member
Joined: April 29, 2006 Posts: 3238 Location: South Benfleet, Essex, UK
Posted: Tue Apr 22, 2008 6:42 am Post subject: Metal-dash Bay Windows? |
| EZ Gruv wrote: |
| NinetyEight wrote: |
If you can live with the holes on the corners, or can weld them closed, there are a couple options I can think of for filling the other holes. You could possibly makes plates out of steel that fit right in the section over all of the holes, and drill the holes out for the ones you need. Or With as many modern features as most people are putting into their busses, you could easily fill the holes with switches and buttons. |
I have never before seen any 1968~79 VW Type 2 dashboards, with vertical slots close to the outboard "corners"! Perhaps it is only a feature of padded dashboards (concealed behind the padding), which were not available for right-hand drive vehicles and a relative rarity for European specification vehicles. _________________ Regards.
Nigel A. Skeet
https://vwt2oc.co.uk |
Posted: Tue Apr 22, 2008 10:37 am Post subject: Re: Metal-dash Bay Windows? |
| NASkeet wrote: |
I have never before seen any 1968~79 VW Type 2 dashboards, with vertical slots close to the outboard "corners"! |
Posted: Tue Apr 22, 2008 10:37 am Post subject: |
| Thanks for the info. Anyone have a pic. of a Euro spec. metal dash Bay Window ? |
420GOAT Samba Member
Joined: March 31, 2006 Posts: 3342 Location: Wilmington, CA on a nice quiet street but still in the 'hood
Posted: Tue Apr 22, 2008 10:49 am Post subject: |
the guage pod is plastic and so is the upper pad so i think it looks better with the padded face. it's not a split. _________________ once you realize im not impressed we will get along just fine |
rjonas Samba Member
Joined: July 24, 2004 Posts: 644 Location: Chandler, AZ
Posted: Tue Apr 22, 2008 10:52 am Post subject: |
_________________ 1979 Type-2 Westfalia “Sandy”
1973 Type-181 Thing "Velma"
1956 Type-1 Beetle Patina Project “Rosie”
www.azbusclub.org |
krautwaggen Samba Member
| It may have blended better painted black. I'm planning on doing this to my 68 sc unless someone can tell me the secret to restoring a padded dash with many many cracks. Euro dashes had the padded top part with the handle didn't they? I wonder if speakers would work nicely behind the corners of the dash (near the door) or if the sound would be distorted excessively. |
dwill49965 Samba Member
Joined: August 08, 2005 Posts: 1405 Location: Dartmouth, Nova Scotia
Posted: Tue Apr 22, 2008 11:00 am Post subject: |
More views of this Euro metal dash in my gallery - page 7.
_________________ Darryl
'78 Westy, Boston Bob built 2.0 L, FI, MSD 6A
jah_B Samba Member
Joined: March 18, 2008 Posts: 1147 Location: Tempe, AZ
Posted: Tue Apr 22, 2008 11:46 am Post subject: |
I'm no big fan of plastic. Even leaving the inserts kind of defeats the purpose. I think if I wanted to go for this kind of look, I'd look for custom fiberglass dashes, or fabricate one in metal/glass from scratch, and plant a PIMPED OUT gauge and radio/gps/dvd player set up in it, ala custom hot rod. Now THAT could look extremely cool, and would quickly knock yer teeth out in a hard stop. _________________ 1984 CABRIOLET 6spd, quaife diff, Neuspeed springs, sway bars, tie bar, short shift kit, bilstein shocks, 16X7 RSE 3pc wheels, BFG TA 205 40s
1972 tintop P30 CAMPMOBILE: M/T, 1.7L, dual kadrons, 019 diz. Sunny the S'kool Bus
You gotta know what you don't know. That's the key to wisdom. man. |
RZAR Samba Member
Posted: Wed Apr 23, 2008 5:19 am Post subject: |
VW Heritage also show VDO Cockpit accessory gauges on this page, but it's strange to see Imperial calibrated (e.g. PSI and ºF, instead of Bar and ºC) instruments on VDO gauges for the British market! _________________ Regards.
Nigel A. Skeet
Posted: Wed Apr 23, 2008 5:24 am Post subject: |
Clicking on this link, merely results in the following "Information" message:
No photos met your search criteria
That's quite a fresh-looking pre-1973 VW 16/1700 Type 2 dashboard, but why position those three switches so far away, just below the glove-box aperture, when you appear to have a few vacant positions on the driver's side?
What is the large black box, just below the steering-column support bracket, close to where the fuse & relay box would be?
I have two six-position, relay mounting cum connector blocks (dimensions 110 mm x 75 mm x 25 mm), suspended unobtrusively, using home-made aluminium adapter brackets, beneath the steering-column support bracket, of my British specification, 1973 VW Type 2, to make provision for, an additional twelve accessory relays, as shown removed from the vehicle for illustration purposes, in the following pictures:
http://www.thesamba.com/vw/forum/album_page.php?pic_id=327969 _________________ Regards.
Nigel A. Skeet
rjonas Samba Member
Posted: Wed Apr 23, 2008 5:49 am Post subject: |
| NASkeet wrote: |
Not my dash board so I have no answer, sorry. I found this picture on the www after I bought my 73 orange westy and I liked the euro dash look. Hmmm...maybe someday I will change it. _________________ 1979 Type-2 Westfalia “Sandy”
www.azbusclub.org |
fallinsquirrel Samba Member
Posted: Thu Sep 22, 2011 6:59 am Post subject: |
| What do you guys think is the best way to paint the metal dashes? |
dembus Samba Member
Joined: February 02, 2005 Posts: 1272 Location: Fleming Island, Florida
Posted: Thu Sep 22, 2011 11:26 am Post subject: Re: Metal-dash Bay Windows? |
| iprangen wrote: |
I asked this same question a few years back about metal dashes. I took a nasty one out of my first bus and stripped it down. I never sanded and painted it but it definitely can be done and then put the upper dash pad back on. I think they look awesome painted the same color as the bus.
Added this from my gallery...
_________________ "Want a little peace of mind, grab the lowest branch and start to climb"
JJ Grey
69 Westy (R.I.P.)
68 Kombi
70 Westy
68 Beetle Sedan
69 Beetle Sedan
68 Deluxe
71 Deluxe
71 HT Westy |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42949 Location: at the beach in Northern Wokistan
Posted: Thu Sep 22, 2011 11:50 am Post subject: |
Some day when good used dashes are available someone will say - It would have brought an extra $10,000 at the auction with the stock dash but some PO hacked it. Too bad.
1971 STOCK Westy top retail now is valued at $27,400 by NADA. A 1963 STOCK 23-window Split just sold at auction for $217,800. If you want to know what that dash will feel like in say 10 years, roll down the window and toss out a whole bunch of 20's today. That should be a pretty good test how much you'll love it then. _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
Daverham Samba Member
