no fuel
VW_MAN_73
VW_MAN_73 is offline
PostPosted: Fri Apr 28, 2006 7:59 pm    Post subject: no fuel Reply with quote
Hi. Iam not getting fuel to my filter and carb. Iam leaking alittle fuel from my pump but don't know where. Is it the diaphram inside or do you think the whole unit is shot. It is a t3 motor setup like a beetle. It has a funky pump on it. Please help. Thanks. Craig.
’73 Beetle - My first car, owned 26+ yrs
’71 VW Westfalia - Road-tripping across the US
Rescued & restoring a ’61 Dove Blue SO23 Bus
Follow our journey!
View user's profile Send private message Visit poster's website Facebook Instagram YouTube Gallery Classifieds Feedback
Clara Premium Member
Clara is offline
PostPosted: Fri Apr 28, 2006 8:40 pm    Post subject: Reply with quote
are you getting fuel to the pump?
pull off the inlet to the pump and see if fuel comes out.
It doesn't? do you have gas in the tank? a clogged fuel line? dirty fuel sock filter?
Fuel does come out? okay.. put the line back on.
pull the fuel outlet line off the pump. Turn the engine round by hand, or have a friend crank the starter for just a couple seconds. Fuel comes out? good.
If not, it's your pump. What's the 'funky' thing about it?
VW_MAN_73
PostPosted: Sat Apr 29, 2006 6:54 am    Post subject: Reply with quote
Hi clara. I assume gas is going to the pump because gas is leaking from it somewhere. But absolutely no gas is coming out of it to the filter. Its not a regular beetle pump that looks like a mushroom head. It must be a T3 pump.
Follow our journey!
Clara is offline
PostPosted: Sat Apr 29, 2006 7:21 am    Post subject: Reply with quote
Check, don't assume.
A pic would help. There are different styles of pumps.
New 40hp/1600 fuel pumps are cheap (~ $20).
If yours is rebuildable, you can also go that route, WW sells rebuild kits.
Is this something that just started happening, or is it on a bus that sat for a while?
VW_MAN_73
PostPosted: Sat Apr 29, 2006 7:30 am    Post subject: Reply with quote
Hi. I will check it. Also the motor has been sitting for awhile and was very dry. Here is what my pump looks like. https://www.thesamba.com/vw/classifieds/pix/medium/1136408.jpg
Follow our journey!
Clara is offline
PostPosted: Sat Apr 29, 2006 7:51 am    Post subject: Reply with quote
That looks normal... it is an older fuel pump.
It is the rebuildable kind... you can unscrew all the screws and take the top off the base. I prefer that kind to the newer ones.
the bolt facing the camera is the cover for the 'fuel screen'.
