1961 One-Year-Onlies...
scottyhoffo
scottyhoffo is offline
PostPosted: Sun May 21, 2006 11:51 pm    Post subject: 1961 One-Year-Onlies... Reply with quote
Greetings,
Could anyone shed some light on some of those 1961-only odds'n'ends which would make my period-correct restoration difficult? (besides potentially not having a vehicle to work on?)
I mean something along the lines of the windshield wiper switch having a bellows on the back or the horn ring being of a different internal design than some other ones. I've read the turn signal switch is different too.
Thanks,
Scott Hoffman
1961 Beetle sedan
"You've been Volkswagened- passed by 40 hp!"
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Mon May 22, 2006 2:57 am    Post subject: Reply with quote
What is the chassis number? The front hood went from 4-tab to the early 3-post midway through the year, at chassis number 3 551 045.
The turn signal switch is mechanically the same for 1960 and 1961, but in 1961 they went to push-on spade terminals for the first time instead of screw-terminals. They both have 6 wires as the switch sends a combined signal to the rear for the brake lights and the rear turn signals.
The steering wheel's horn setup is a bit more primitive, with three spring loaded brass pins under the horn ring that make the contact. The horn ring itself is shaped a bit different too, although I've seen later rings on there and be made to work.
I gotta run so I'll let others add to this discussion...
-Andy
bill may
bill may is offline
PostPosted: Mon May 22, 2006 6:07 am    Post subject: Reply with quote
gas tank is 62-67 style ,but no cutout for gas guage.
Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
RareAir
RareAir is offline
PostPosted: Mon May 22, 2006 7:22 am    Post subject: Reply with quote
Windscreen washer bottle & plastic brake reservoir is also special to the 1961 model.
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
sixfootdan
Samba Smartass
Location: \Lo*ca"tion\, n. 1. The act or process of locating.
sixfootdan is offline
PostPosted: Mon May 22, 2006 8:53 am    Post subject: Reply with quote
60 or 61 had a one off steering wheel, It had notches where the horn ring went into the half ring.
Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!!
KantDriveFast
KantDriveFast is offline
PostPosted: Mon May 22, 2006 6:41 pm    Post subject: Reply with quote
Wasn't that the only year for the stainless"teardrop" washer nozzle? Confused
Teeroy Premium Member
Teeroy is offline
PostPosted: Mon May 22, 2006 6:45 pm    Post subject: 1961 One-Year-Onlies Reply with quote
Rear bulb holders . TROY
Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org
RareAir
RareAir is offline
PostPosted: Mon May 22, 2006 7:34 pm    Post subject: Reply with quote
1960-62 all had the nothes in the steering wheel for the horn ring. As Glutamodo pointed out, 1960-61 & 1962-63 carry different part numbers.
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
scottyhoffo
PostPosted: Tue May 23, 2006 7:39 pm    Post subject: Chassis No. Reply with quote
Greetings -
Thank you all for your time!
My chassis number is 3377705, and according to the BC was built on 18 October 1960.
Side note - when I got Waltraud, there was a 1600 in her... according to my BC the engine serial number wasn't recorded. I was interested in doing as "period correct" a restoration as possible, so I bought a 1200 long block serial number 5221881 - according to what's posted on the website, that would be close, right? That would make it a 40hp huh? Don't all the 36hp blocks have the integrated generator stand?
What sort of different wiper bottles do you mean? I have a snap-cap non-pressurized VDO I'd obtained a couple of years ago.
Troy, what is the difference in the bulb holders? '61 was the last year for the "snowflakes" I know, but how could I find out which ones I have?
I have the correct steering wheel, but what about color? The BC says "radscheibe" but that means "wheel disk"... my wheel is painted what appears to be the original L390 golfblau.
Again, thank you all very much for your help!
Scott Hoffman
1961 Beetle sedan
RareAir
RareAir is offline
PostPosted: Tue May 23, 2006 9:50 pm    Post subject: Re: Chassis No. Reply with quote
1961-only bulb holders are spade terminals. 1955-60 would have screw terminals. Luckily, the repro's are spade so it's easy to relace.
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
RareAir
RareAir is offline
PostPosted: Tue May 23, 2006 9:51 pm    Post subject: Re: Chassis No. Reply with quote
Your steering wheel is painted L390 Gulf Blue? Hmmm Confused I thought only convertibles were equipped with color-matched steering wheels.
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
RareAir
RareAir is offline
PostPosted: Tue May 23, 2006 9:54 pm    Post subject: Reply with quote
Hey Scott,
Did you ever recover your '61 after returning back to the States?
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
bill may
bill may is offline
PostPosted: Wed May 24, 2006 6:16 am    Post subject: Reply with quote
RareAir wrote:
Hey Scott,
what Glenn said^^^ where is it???
www.sv2s.com
SBS #100
Teeroy is offline
PostPosted: Wed May 24, 2006 7:10 am    Post subject: 1961 One-Year-Onlies Reply with quote
Oct 60 is a 61 model year and will have a non fresh air 40hp 1200cc , all 36hp had the integrated gen stand . TROY
ARR #3
Downtown Brown
Downtown Brown is offline
PostPosted: Wed May 24, 2006 9:26 am    Post subject: Re: Chassis No. Reply with quote
scottyhoffo wrote:
Greetings -
That's the one ! from the top, looking down looks like 1/2 of a banana. Another good thing to save would be the grill and trim from the right side of the speedo, 60 had the pointed heavy trim, 62 gas gauge.
RareAir
RareAir is offline
PostPosted: Wed May 24, 2006 3:11 pm    Post subject: Reply with quote
bill may wrote:
RareAir wrote:
Hey Scott,
Examining the only pic that Scott posted of his Beetle, it looks like it's within a mile of the Linda Vista area. See the freeway signs? That's got to be the I-163 heading South near Kearny High School Wink
That means it's in your neighborhood Bill.
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
scottyhoffo
PostPosted: Wed May 24, 2006 7:28 pm    Post subject: You guys are awesome! Reply with quote
Thank you SO much for your help!
Now the car... *sigh*
Here's the scoop: Jose says he has it but seems to have some trouble getting pictures emailed to me to prove it. The police have been notified and they said they'd spoken with his wife and they do indeed have my car and would have pictures AND my updated invoice sent to me today. Amazing - it seems like the only way I can get him to tell me anything about the car is by calling the sheriff's department there getting involved. Grrrr...
You're right! The picture of my car was taken from the front of my old apartment on Kearny Villa Ln - the Cabrillo Palisades Townhome complex. Yeah that darn 163... Smile It was nice to be able to make it home from work in less than 15 minutes and not even get on the highway... I wouldn't trade living in Rancho Bernardo for much though - expensive but beautiful.
I'll post some other pictures which I have as soon as I get them processed.
BTW I think my steering wheel is L390 - it's a '61 for sure. Maybe someone put a convertible part on the car at one time. I have a picture but it doesn't show the wheel closely.
...trying to remain optimistic about the car...
Scott Hoffman
1961 Beetle sedan
scottyhoffo
PostPosted: Wed May 24, 2006 7:41 pm    Post subject: Re: Chassis No. Reply with quote
Mine were pretty rough - definitely not belonging to the car as they were black and pretty rusty... so they may even be the earlier ones.
Good to know that all replacements are patterned after the '61s! Smile
Scott Hoffman
1961 Beetle sedan
bill may
bill may is offline
PostPosted: Thu May 25, 2006 5:50 am    Post subject: Reply with quote
i live 10 blocks from kearney high school.
www.sv2s.com
SBS #100
gt1953
gt1953 is offline
PostPosted: Thu May 25, 2006 6:52 am    Post subject: Reply with quote
I am SOOO glad you are one who is restoring your car correctly GREAT.
Keep it stock and don't drop or any of the other junked up stuff people do.
Thanks
72 type 1
72 Squareback
Page 1 of 9
