3foldfolly Samba Member
Joined: March 08, 2009 Posts: 894 Location: Edwardsville, Il
Posted: Sun Sep 13, 2020 6:19 pm Post subject: 3m adhesive and por-15 |
| Does anyone know if 3m super 77 adhesive will adhere to a surface that has been coated with por-15? |
viiking Samba Member
Joined: May 10, 2013 Posts: 3435 Location: Sydney Australia
Posted: Tue Sep 15, 2020 4:01 pm Post subject: Re: 3m adhesive and por-15 |
I personally haven't used it but it says in their blurb that it works on "foils" which I would assume to be quite a slippery surface.
In absence on any other answers, I would just rough up the POR15 and do a test patch. I can't see why it won't work after getting a bit of key on the surface. That's POR15's recommendation when you overcoat with paint! _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18052 Location: Eugene, OR
Posted: Wed Sep 16, 2020 10:56 am Post subject: Re: 3m adhesive and por-15 |
I wouldn't be very worried about 3M adhesive, but POR 15 started to bubble up and flaked off after 6 months when I painted it on my pans.
Get your carpets glued down ASAP, so you can't see the pans!  _________________ 69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
