1990 Vanagon GL - Emergency Brake Cable Replacement
jdbs3
jdbs3 is offline
PostPosted: Thu Jun 01, 2006 9:10 am    Post subject: 1990 Vanagon GL - Emergency Brake Cable Replacement Reply with quote
From my mechanic - The steel sheathing on my emergency brake cable (right side) has rotteed away so the brake cable has collapsed on itself. It can not be adjusted any more.
When replacing the right cable, should I also replace the left cable even if it looks okay?
And, should I also replace the main tension cable from the hand brake to the emergency brake cables even if it looks okay?
Thanks!
