LEJ Samba Member
Joined: May 13, 2006 Posts: 115 Location: Ontario, Calif.
Posted: Sat Jun 03, 2006 5:40 pm Post subject: Electric Fuel pump cut off Relay |
Somewhere else on this board, I posted a way to cut off your fuel pump using a brake light switch tied into your oil pressure sender.
I've come up with another simple way to install a fuel pump cut off system and it should cost about $4.00
Start by going to the auto parts store and buying a Bosch 20/30 amp lighting relay. It's the kind that's square and is black plastic.
It will have 5 terminals on the base.
Terminals 86 and 87a are wired together and they will attach to a """SWITCHED""" 12 volt positive wire. (Remember, it has to be switched))
Terminal 85 will go to your alternator light output located on your alternator or tap into the wire from beneath the dashboard.
Terminal 30 will go directly to the 12 volt positive side of your fuel pump. The ground wire from your fuel pump will remain grounded.
You may want to install a momentary switch someplace hidden and attach a 12 volt positive wire to one side of the switch and wire the other side of the switch to the postitive wire on your fuel pump.
If the alternator stops turning, the fuel pump will shut off.
!!!!This has a dual advantage, should your fan belt break and you're paying attention to lights or gauges, the fuel pump will turn off and hopefully, you'll stall the engine before you cook the cylinders.
The other advantage is a safety issue if you crash your car.
I'm not an artist but here's a wiring diagram
http://hometown.aol.com/ljowdy/myhomepage/sale.html _________________ The more you know, the more you know you don't know. |
kubelmann Samba Member
Posted: Sun Jun 04, 2006 10:01 pm Post subject: |
Hey.. We are very into the rotary electric fuel pumps and this circuit is very well thought out. Thanks. I am in the process of changine fuel delivery. This circuit is now a part of my plan. Again thanks. K-mann |
bugninva Samba Member
Joined: December 14, 2004 Posts: 8858 Location: sound it out.
LEJ Samba Member
Posted: Mon Jun 05, 2006 4:12 am Post subject: |
When I worked out the relay wiring, I thought to myself that someone out there has done this before, I just couldn't find a source.
sometimes we just keep re-inventing the wheel _________________ The more you know, the more you know you don't know. |
Captain Spalding Samba Member
Joined: February 19, 2005 Posts: 2519 Location: . . . in denial.
Posted: Mon Jun 05, 2006 8:41 am Post subject: |
LEJ wrote: |
sometimes we just keep re-inventing the wheel |
FWIW LEJ, I prefer your solution because it doesn't require running any wiring to the back of the car.
I totally trust your diagram, but I don't fully understand it. Terminals 85 and 86 power the relay coil. In your circuit, 86 is getting switched 12v+, so 85 has to find its way to ground.
If you connect 85 to the wire for the generator lamp, how does it find ground? If it is going through the generator lamp to ground, won't the lamp will be lit by the voltage coming from the relay coil?
Maybe a simpler question to ask is: what's happening at either end of that wire that 85 is tapping into?
The Bosch Relay Unraveled. |
germansupplyscott Samba Member
Posted: Mon Jun 05, 2006 8:55 am Post subject: |
there is a better circuit and relay that uses an early watercooled fuel pump relay.
http://www.dolphinsci.com/relay.html
the diagram on that page is MIA, but basically the relay senses the points opening (via the coil) and triggers, turing on the pump.
the problem with using the alternator blue light as the trigger is that if your alternator or generator cacks, your pump stops working too. not so good. the circuit above is 100% fail safe but will let you drive with no alternator, which if you think about, you want to be able to limp along even if your charging system is busted.
the relay is available at a junkyard or here;
http://germansupply.com/xcart/customer/product.php?productid=16928 _________________ SL |
LEJ Samba Member
Posted: Mon Jun 05, 2006 9:47 am Post subject: |
Captain,
Take a look at the relay drawing again, 86 and 87a are tied together and then both are connected to a switched 12 volt power source, in this case, the positive horn wire.
30 goes directly to the positive wire on your fuel pump and 85 is the "turn off" trigger obtained when the alternator light goes to ground. (this happens when the alternator quits working.
German,,,
I've seen and heard about the relay you're discussing. It too is a another great way to solve the "fuel pump" cutoff.
I'm not saying that my way is the only way, it's just another solution. _________________ The more you know, the more you know you don't know. |
Posted: Mon Jun 05, 2006 10:21 am Post subject: |
This is another thread that will be a great resource for future information sought. I would like to include these various circuits on the RoMTOC CD
If any of you who posted your circuit are willing to have that info included please send me your circuit information in a pmail ([email protected]) and I will add it to the CD and of course give you credit for the creation. Thanks
Posted: Mon Jun 05, 2006 10:59 am Post subject: |
Hella makes a relay with built in fuse. Might make for a tidier installation.
LEJ Samba Member
Posted: Mon Jun 05, 2006 11:03 am Post subject: |
That's trick, Can you tell which poles are fused??? _________________ The more you know, the more you know you don't know. |
Posted: Mon Jun 05, 2006 11:14 am Post subject: |
Great item!
http://www.expeditionexchange.com/xcart/customer/product.php?productid=18441&cat=249&page=1
I found the Hella Fused Relay H41510131 at the above web site
It says - Use this relay to create your own wiring harnesses. The integral fuse receptacle obviates the need to have a separate fuse holder in your wiring harness. The result is a simpler wiring harness and a cleaner appearance.
Price: $ 15.00 |
Posted: Thu Jul 20, 2006 8:59 pm Post subject: |
After much reflection and re-reading this thread, there is something that perplexes me regarding LEJ's relay circuit which uses the generator light as a turn-off trigger for the relay and pump. If the pump can't run when the GEN light is on, how do you start the car? The GEN light is on until the engine is running. . . |
Posted: Thu Jul 20, 2006 9:09 pm Post subject: |
Captain Spalding wrote: |
in a carburetted car you have fuel in the floatbowl available....a "bypass" button should be installed for those occassions where the car has sit long enough for the fuel to evaporate out of the bowl..... just for illustration, if i kill my fuelpump on the highway at 65 MPH i can still drive for almost a mile on the fuel in the carb bowls.(dual kadrons) |
LEJ Samba Member
Posted: Thu Jul 20, 2006 9:47 pm Post subject: |
He's correct, fuel in the bowl is sufficient to start the car. Look at my schematic and you'll also see a momentary switch. That switch is a bypass and allows you to fill the carb bowl should it run dry due to evaporation or if you should service the carb and drain the bowl. _________________ The more you know, the more you know you don't know. |
Heiferman Samba Member
Joined: February 28, 2024 Posts: 302 Location: Georgia, USA
Posted: Wed Jul 24, 2024 3:31 pm Post subject: Re: Electric Fuel pump cut off Relay |
LEJ wrote: |
http://hometown.aol.com/ljowdy/myhomepage/sale.html |
While a Rabbit is probably the best solution, I like this idea so one can keep from running a new wires between the pump at the front and the coil at the rear.
Looks like the PO is recommending using a changeover relay (a relay with five posts) but it would seem that would not be necessary. Too bad the image hosting is no more (AOL Hometown ) If you use a make & break or a standard relay (four posts) there is no 87a and no reason to wire 86 and 87a together. Just follow Jim's diagram with a standard relay and an inline fuse.
Looks like Summit still sells the fused relay from Hella:
https://www.summitracing.com/parts/hla-003530001?s...5QK6HpuGfA
lqqkatjon Samba Member
Joined: July 02, 2013 Posts: 64 Location: St. Cloud, MN
Posted: Mon Jul 29, 2024 1:05 pm Post subject: Re: Electric Fuel pump cut off Relay |
this is what we like to use on some electric fuel pump retrofitted engines:
https://www.revolutionelectronics.com/Products/Fuel_Pump.html
you can make your own stuff up cheaper, but this product works pretty well. I know a couple people who have been running this for about a year since they first discovered this product. |
madster Samba Member
Joined: November 01, 2006 Posts: 219 Location: Rio Grande Valley Texas
Posted: Mon Jul 29, 2024 6:04 pm Post subject: Re: Electric Fuel pump cut off Relay |
lqqkatjon wrote: |
 _________________ 1966 BEETLE @ 1973 THING |
Posted: Mon Aug 12, 2024 12:11 pm Post subject: Re: Electric Fuel pump cut off Relay |
LEJ wrote: |
Old thread I know but rookie question:
Where does 87 get hooked up in the above description?
I found a diagram but not sure it goes with the above instructions. I see:
86 alternator light
85 ground
87 pump
30 fused (switched) _________________ - 1973 Thing, 1970 Ghia, some LandCruisers and an old Ambulance
doublecanister Samba Member
Joined: September 23, 2008 Posts: 1214 Location: Richmond, Va
Posted: Mon Aug 12, 2024 1:42 pm Post subject: Re: Electric Fuel pump cut off Relay |
lqqkatjon wrote: |
I just installed one of these myself maybe a month or so ago. So far it works as designed, I'm still in the testing / tuning phase but so far so good.
I mounted it under the dash using the existing 2 of the 4 studs/nuts that hold the gas heater in (had to make an adapter plate so I didn't have to drill anything) and it's fairly easy to access just in case I have to muck with it.
T _________________ ****************************************
2020 - Mustang Eco Boost [High Performance]
1973 - Thing
1966 - Mustang GT- Fastback
1951 - Ford F1 pickup Flathead V8 |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2813 Location: The World's Motor Capital
Posted: Mon Aug 12, 2024 3:21 pm Post subject: Re: Electric Fuel pump cut off Relay |
Lqq and Double are correct.
The Revolution Electronics fuel pump controller is the right way to do this job.
It is superior to the "Rabbit" relay because the prime time is about double that of the "Rabbit" relay, and more importantly, the reliability is much better (for loads up to 7.5 amps, which is way more than enough for any electric pump fueling a carburetor).
Bite the bullet, and run a single "back to front" wire, (18-20 AWG would be plenty) to bring the tach signal (coil terminal 1) to the controller (or a dash tachometer, if you want one). The rest of the wiring is all "up front"; easy to access and close to the pump.
Here's an old post:
https://www.thesamba.com/vw/forum/viewtopic.php?t=757944
Good luck |
