scarybuggy Samba Member
Joined: April 05, 2006 Posts: 495 Location: Northern Neck, Virginia
Posted: Wed Jun 07, 2006 4:11 am Post subject: 3" lift kit modification |
I need to raise my body a bit off the pan, and have been looking at the 3" lift kit. However, I don't need that large of a lift. A lot of folks here have given me some good advice on fabricating a lift section for the buggy, but I'm wondering how feasible it would be to take a 3" lift kit and cut it down? Has anyone ever done this? And is the kit a true 3"? I'm thinking about putting it on a band saw and sawing it in half horizontally to get a lower profile. Didn't know how well it might work... _________________ Jay
'67 Manx Clone |
seabeebuggy Samba Member
Joined: October 03, 2005 Posts: 2395 Location: NM, CA, UT and now NV
Posted: Wed Jun 07, 2006 8:23 am Post subject: |
it will not work unless you remove steel and weld t back together. it is a [ channel like that " [ ". have you sat in a 3'' lift? it is great. but would be better to build one than cut that one down. _________________ Seabee turbo buggy build
(Quote Runslikeapenguin said)
so to everyone else whos not a retarded butt pirate marine with an tacky ugly ass car covered in auto zone bolt and stick on s**t. (end quote)
A better place to talk offroad |
Posted: Wed Jun 07, 2006 9:46 am Post subject: |
Ahhh... thanks. Didn't realize how the steel was shaped. The problem is that I have side pods molded into the body, and if it's raised too high, I'm afraid it would lose it's ultra-cool sleek and lowered look That's why I was trying to get it lifted just enough to stop hitting my rear shock towers, but not enough to show a lot of pan on the side. I'll try some 1" box tubing. Thanks again! _________________ Jay
'67 Manx Clone |
Yellermanx Samba Member
Joined: November 04, 2004 Posts: 1242 Location: Florida
Posted: Wed Jun 07, 2006 10:58 am Post subject: |
Here is what 2" lift with side pods looks like on a Berrien chassis. It made plenty of head room as well as clearance for IRS in a Manx 1. There is plenty of room to lower the buggy if I wanted to.
viperbgy Samba Member
Joined: March 15, 2006 Posts: 195 Location: Spokane,WA
Posted: Wed Jun 07, 2006 12:57 pm Post subject: |
Yea but you don't want to lower it, RIGHT CHUCK  _________________ Mr. B
viper dune buggy
Dune Buggies are unequaled in "smiles per mile"
Posted: Wed Jun 07, 2006 1:05 pm Post subject: |
[quote="viperbgy"]
Yellermanx wrote: |
Yea but you don't want to lower it, RIGHT CHUCK  |
RIGHT DARREN, Plenty of room to raise it too.  |
Posted: Wed Jun 07, 2006 1:14 pm Post subject: |
RIGHT DARREN, Plenty of room to raise it too. [/quote]
No need for that.  _________________ Mr. B
viper dune buggy
Dune Buggies are unequaled in "smiles per mile" |
Posted: Wed Jun 07, 2006 5:22 pm Post subject: |
Thanks, Yellermanx. It doesn't look quite like I thought it would. Still sits nice on the chassis, without looking like it's really been raised. _________________ Jay
'67 Manx Clone |
EZGZ Samba Member
Joined: October 10, 2005 Posts: 923 Location: Loveland, Colorado
Posted: Wed Jun 07, 2006 7:59 pm Post subject: |
I had the same thoughts on my new kit with side pods.
I used 2" square down both sides. I welded the peaces that angle in for the front behind the wheel.
I felt it was strong enough like that so that I left the 2 inch slot across the front and back over the hump. I filled the front with a peace of pipe insulation and left the rear open. Handy to run wires and brake lines through. Might run hearter boxes some day and can run my own tubes from the back through there too.
The nice thing about the 2inch lift is the bottom of the side pods are sandwhiched between metal the full length of the pods. Only had to use one bolt on each up front corner. Very secure.
https://www.thesamba.com/vw/gallery/pix/279336.jpg _________________ 64 custom Ghia, 66 Bug, Sandrail, Barrien tub |
speedbuggy Samba Member
Joined: June 06, 2006 Posts: 20 Location: San Dimas, CA
Posted: Wed Jun 07, 2006 9:00 pm Post subject: |
If you use the 3 inch "C" channel lift kit I would highly recomend additional support tubing spacers inside the channel and run the bolts thru them as the kit is very flimsy. |
joemama Samba Member
Joined: February 09, 2006 Posts: 1667 Location: La Crescenta, California
Posted: Fri Jun 09, 2006 3:21 pm Post subject: |
I dont remember where I saw this, might of been the Manx Club site, or RBC, but anyways, someone built a lift kit out of synthetic wood, like Trex, cuts like wood, sands like wood, can glue it, he even bent it to go over the hump in the pan. Will not rot. Seems like the guy was very happy with it. |
Fireguy Samba Member
Joined: October 25, 2005 Posts: 169 Location: Lehi, Utah
Posted: Fri Jun 09, 2006 3:25 pm Post subject: |
joemama wrote: |
It was our very own yellermanx.
