jspbtown Samba Member
Posted: Tue Apr 03, 2007 12:29 pm Post subject: Any machinists out there.....delrin? |
I need a bushing for a project that I am doing. I can't seem to find a bearing that will go into the stock steering tube (bushing would need to be 1.5" OD), and have a 7/8" ID hole in the middle for a steering shaft. Anybody have the tools to make me one? Maybe 2-3" long? |
bob cook Samba Member
Posted: Tue Apr 03, 2007 3:35 pm Post subject: |
I made mine using hole saws I may have an extra one if your interested I'll check email me if your interested |
Posted: Tue Apr 03, 2007 3:48 pm Post subject: |
I checked I do have an extra one it is made out of UHMW wich is just like delrin self lubricating it is white it is 1.5 dia 7/8" hole 1 " thick this is what I'm using in mine and know of others that are using the same thing if you want it I need a mailing address and it is your no charge just let me know !!!! |
darrenma Samba Member
Posted: Tue Apr 03, 2007 5:04 pm Post subject: |
Delrin is not as slippery as UHMW ,but is really nice to machine and harder than UHMW.Because UHMW is more slippery it will last longer than delrin,but either will work fine. |
lostinbaja Samba Member
Joined: December 19, 2004 Posts: 4036 Location: Frankfort, Illinois
Posted: Tue Apr 03, 2007 5:33 pm Post subject: |
Delrin is actually DuPont's name for UHMW (ultra high molecular weight)Nylon.
Granted there are various types of Delrin.
* Standard Delrin (Homopolymer)
* Delrin AF- Contains Teflon fibers and works very well for bushings but is a bit softer due to the TFE Teflon fibers.
* Delrin, Glass filled- Low deformation under load and good impact resistance. No creep under load.
There are more type but these are the most popular.
Jerry... |
desertwrx Samba Member
Joined: January 18, 2007 Posts: 366 Location: Borrego Springs, CA
Posted: Tue Apr 03, 2007 7:41 pm Post subject: |
Hate to be picky, but Delrin is actually Acetal. UHMW is something completly different. Much cheaper than Acetal and works good. Delrin/Acetal is used a lot for suspension bushings in race cars. |
Posted: Wed Apr 04, 2007 3:34 am Post subject: |
How picky do you want to be? Delrin is actually an Acetal Homopolymer which all shares the same basic molecular chain with what DuPont calls "Nylon".
Jerry... |
Posted: Wed Apr 04, 2007 6:28 am Post subject: |
Bob,
I sent you a PM. Thank you, thank you, thank you!
Jeff |
Posted: Wed Apr 04, 2007 7:10 am Post subject: |
put it in the mail this morning you should get it in a couple of days glad to help |
Posted: Mon Apr 09, 2007 8:16 am Post subject: |
Got it over the weekend Bob. It looks like it will work perfectly! Thank you! |
