gregg4president Samba Member
Joined: May 11, 2006 Posts: 25 Location: myrtle beach, sc
Posted: Sat Mar 10, 2007 2:44 pm Post subject: Oil leak from drain plug |
| I am having a pretty good drip from my drainplug, i dont know if the gasket might have been paper and got wet when the oil got changed and is no longer holding, but it is a 1973. Which gasket would be best replacement CORK, PAPER, METAL? |
racer122 Samba Member
Joined: December 06, 2006 Posts: 102 Location: Aspen, Colorado
Posted: Sat Mar 10, 2007 2:49 pm Post subject: |
I have only ever seen the gaskets in paper. Of course, your "drainplug" should have a copper crush washer on it too.
Unless you have a late '73, which might not have the removable center bolt "drainplug" which needs the copper crush washer. It's hard to say by your question, but rest assured, the only gaskets are paper. _________________ Past: '73 SB, '73 Type II, '76 Rabbit, '77 Sciroco, '86 GTI
Now: '73 SB -- the past returns! |
Posted: Sun Mar 11, 2007 8:07 am Post subject: |
| yes it has the center drain plug and i think it has the copper crusher and paper, although i think only the paper gasket is on....i found the copper one in my glovebox. I must have forgot to put it on. So i should put the copper ring on the plug then the paper and then i should put it in? |
Posted: Sun Mar 11, 2007 9:25 am Post subject: |
OK, first, there is a plate, which the center bolt screws into. This is held in place by six or so small bolts...
The paper gasket goes under that plate, between the plate and the oil screen, which also has a paper gasket between it and the oil sump. This stuff is all bolted down (gently) with the six or so small bolts.
Then the center bolt screws into the plate, with a copper crush washer between it and the plate. This is the "gasket" for the bolt. There is no other paper gasket for the bolt.
If this is not clear or complete enough, please see...
http://www.vw-resource.com/oil-chng.html _________________ Past: '73 SB, '73 Type II, '76 Rabbit, '77 Sciroco, '86 GTI
nc68bugman Samba Member
Joined: August 12, 2006 Posts: 681 Location: Beaufort, NC
Posted: Sun Mar 11, 2007 9:36 am Post subject: |
| Also copper crush washers for those little nuts on sump plate. Never re-use them, use new ones with oil change kit! Scott |
buggyrider Samba Member
Joined: November 03, 2013 Posts: 62 Location: Danville, CA
Posted: Wed May 12, 2021 7:44 am Post subject: Re: Oil leak from drain plug |
| I found this old thread because I too was having a bad oil leak from the oil drain plug after changing the oil. My contribution is that not all copper washers are created equal. First, I replaced the copper washer with a new one from a Harbor Freight kit, and that leaked. It was looser and thicker than what was there before, but it seemed to fit well enough to do the job. Then I replaced it with a copper washer that had been on a magnetic drain plug I'd had in there previously, and that also leaked. Finally, I re-installed the copper washer that had been present prior to changing the oil. I first sanded the grooves out of it with 220-grit sandpaper. Now it no longer leaks. |
glutamodo  The Android
Joined: July 13, 2004 Posts: 26632 Location: Douglas, WY
Posted: Fri May 14, 2021 7:53 am Post subject: Re: Oil leak from drain plug |
The original oil drain plug crush seal is a "one-time-only" sort of a seal. In other words, once it gets crushed, you don't re-use it.
Lots of people call these copper, they might be, but might just be copper plated, or you might see them without any copper plating at all. but still they are one-shot gaskets. The last time I bought new crush M14 crush seals they were silver toned, not copper. Flat seals are just a solid disc of metal. Crush seals are tubular, (hollow). And some companies make them beefier than others
Oh, and Harbor Freight probably sold you a flat gasket, not a crush seal. Again, these are two different types of drain plug seals. _________________ Andy T.
"What is Glutamodo, Horror of Toyko, besides total, fiendish, quality-a-you brain!" |
whobba Samba Member
Posted: Fri May 14, 2021 9:25 am Post subject: Re: Oil leak from drain plug |
Also, try the silicone gasket for the oil drain plate, they work great. Keep a little hoard of new copper crush gaskets for the drain plate screws and drain bolt, you'll need 'em. _________________ **SUPPORT THE SAMBA**
http://www.thesamba.com/vw/donate.php
http://www.thesamba.com/vw/products/ |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16766 Location: North Florida, USA
Posted: Fri May 14, 2021 10:46 am Post subject: Re: Oil leak from drain plug |
The last drain plate I purchased came with a magnetic drain plug. The seal for that plug was rubber (nitrile?) and I never had a problem with leaks from the drain plug. The seal/gasket was reusable which is one thing I liked over the stock copper seal. Do not reuse copper/crush washers.
Make sure the sealing surfaces on the drain plug and the plate are clean and smooth to allow the best seal. If the sealing surface is 40yrs old and pitted from corrosion... consider a new drain plate.
See if your FLAPS can find you a square nitrile gasket or o-ring of the proper size to fit the drain plug. Drain plug seals used to be a commonly used part and the FLAPS would have a box with common size drain plug washers/seals. Hopefully your FLAPS has them. _________________ AshMan40
Cusser Samba Member
Joined: October 02, 2006 Posts: 33450 Location: Hot Arizona
Posted: Fri May 14, 2021 12:42 pm Post subject: Re: Oil leak from drain plug |
| ashman40 wrote: |
| Drain plug seals used to be a commonly used part and the FLAPS would have a box with common size drain plug washers/seals. Hopefully your FLAPS has them. |
Also have seen various drain plug gaskets of various materials in the little drawers at my local Ace Hardware. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 2186 Location: Wichita, KS
Posted: Sat May 15, 2021 8:32 am Post subject: Re: Oil leak from drain plug |
| buggyrider wrote: |
I’ve personally had pretty good luck in reusing “standard” copper washers (i.e. not hollow or “crush” type) for sump nuts and oil drain plug by annealing them prior to reinstallation. Just line them up on a piece of wire or nail, heat them w/ propane torch until they glow brightly, and then let them air cool. They’ll be nice and soft again, and should seal well when sump nuts & drain plug are torqued down correctly.
Beware copper-plated steel washers, though — you don’t want those. Just use pure copper washers. You can use a magnet to check them. _________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
