68 front end on a 62 bug?
bustedtype2
bustedtype2 is offline
PostPosted: Tue Jul 11, 2006 12:35 am    Post subject: 68 front end on a 62 bug? Reply with quote
I was going to bring the bug to the paint shop and I found somthing odd. It seems my toe bar is to small for the front tube. It fits my 60 vert. Is it possible to put a later front end on an early car? Dues it matter ? The numbers match.
bill may
bill may is offline
PostPosted: Tue Jul 11, 2006 4:49 am    Post subject: Reply with quote
did you remove the zerk fittings? tubes diameter is same. your 62 should be a king pin / link pin front end. sometimes the zerks wont let tow bar go on.
Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
bustedtype2
PostPosted: Mon Jul 17, 2006 8:57 pm    Post subject: Reply with quote
Shocked What??? Can you explain?
bustedtype2
PostPosted: Mon Jul 17, 2006 8:58 pm    Post subject: Reply with quote
choppachris
choppachris is offline
PostPosted: Mon Jul 17, 2006 9:02 pm    Post subject: Reply with quote
zerk fittings are just the grease fittings on your beam tubes. check and see if the towbar is hitting them when you try and put it on. My towbar fits my '63 and a friends '70, and the '70 is a different beam.
dubless
KantDriveFast
KantDriveFast is offline
PostPosted: Mon Jul 17, 2006 9:37 pm    Post subject: Reply with quote
Tow bar should fit all Beetles, Ghias, and Things. Link pin or Ball joint, doesn't matter. Won't fit Super Beetle, Bus, or Type 3.
