hatch extension
vicali
vicali is offline
PostPosted: Thu Jul 20, 2006 8:06 am    Post subject: hatch extension Reply with quote
Looking for the rear hatch extension for my westy, GoWesty is out of stock and their source has dried up. anybody know another place that has them?
mike
[email protected]
mdetro4660@aol.com is offline
PostPosted: Thu Jul 20, 2006 8:46 am    Post subject: Reply with quote
EUROCAMPERS.COM
Markus
vicali
vicali is offline
PostPosted: Thu Jul 20, 2006 9:33 am    Post subject: Reply with quote
[email protected] wrote:
EUROCAMPERS.COM
10155A Airlock rear hatch lock extension $19.95 Out of Stock
any other ideas? Crying or Very sad
Thanks,
Mike
Yellow Rabbit
Yellow Rabbit is offline
PostPosted: Thu Jul 20, 2006 10:20 am    Post subject: Reply with quote
How soon do you need it? I was thinking of making myself one.
billybobrudebaga
billybobrudebaga is offline
PostPosted: Thu Jul 20, 2006 10:24 am    Post subject: HATCH STRUTS Reply with quote
I got mine at evwparts.com
Good people, and super fast shipping.
Check it out:
http://evwparts.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=VanagonBody
Good luck.
joetiger Premium Member
joetiger is offline
PostPosted: Thu Jul 20, 2006 10:58 am    Post subject: Reply with quote
I have one from Eurocampers and it's worth its weight in gold. I can understand why everybody's sold out.
Had they been sold out when I got mine, I had thought about making my own.
Somebody on the Vanagon list posted about it a while back, using a large turnbuckle with an eye on one end and hook on the other end. You could probably get all the stuff for it at the hardware store.
Hope that helps!
Joe T.
vicali
vicali is offline
PostPosted: Thu Jul 20, 2006 11:22 am    Post subject: Reply with quote
does that mean it's for sale? looking at my options that is almost tempting...
not finding alot of options other than DIY..
joetiger is offline
PostPosted: Thu Jul 20, 2006 11:30 am    Post subject: Reply with quote
No, not for sale yet. I've been looking for a picture of a homemade one...I know I've seen a picture on the web somewhere.
Here's a pic of a machined homemade one from this site:
http://www.mts.net/~rrh/WestyMods.html
amishman
amishman is offline
PostPosted: Thu Jul 20, 2006 11:33 am    Post subject: Reply with quote
What does this hatch extension do?
Question
tj
vicali
vicali is offline
PostPosted: Thu Jul 20, 2006 12:01 pm    Post subject: Reply with quote
to keep the hatch open and allow for airflow when you are PARKED.
or like in Winstons case, to keep the black fuzzies out of your camper while your sleeping inside with the back door open.
mike
msinabottle
msinabottle is offline
PostPosted: Thu Jul 20, 2006 12:43 pm    Post subject: I am not a Pic-nic Basket. Yogi Reply with quote
I'll take a picture of Winston's hatch extender this weekend and post it. I don't think it'd be that hard to make. Drat it, the parts are getting cheap but a lot of sources for good aftermarket are starting to dry up!
It really does make a difference in how much air you have back there.
Best!
amishman
amishman is offline
PostPosted: Thu Jul 20, 2006 12:55 pm    Post subject: Re: HATCH STRUTS Reply with quote
Check it out:
Good luck.
I am not seeing it from your link above...
tj
vicali
vicali is offline
PostPosted: Thu Jul 20, 2006 2:07 pm    Post subject: Re: HATCH STRUTS Reply with quote
tj
they don't sell them,
just got an email back...
Crying or Very sad
mike
Muskrat
Muskrat is offline
PostPosted: Thu Jul 20, 2006 2:45 pm    Post subject: Reply with quote
howdy, first time post.i found an item at my local hdw store for 3 bucks that does the same thing as all those fancy hatch extensions. unfortunatly i dont know how to post picks so bear with me while i try to explain what it is. its called a turnbuckle. it has a hook on 1 end and a loop on the other, there threaded into an aluminum rectangular connector that when rotated will shorten or lengthen the assembly. this alternative is cheap, readily available at any hdw store and adjustable( turn it all the way out on those hot nights or closer in when leaving the vehicle unatended. i got the 3/8"x8". to install it just slide the hook around the post on the vanagon body then close the door on the loop. give it a try.
thanks, keith
vicali
vicali is offline
PostPosted: Thu Jul 20, 2006 3:25 pm    Post subject: Reply with quote
hmm interesting..
good for camping, I like the adjustable idea.
not all that secure though, if the middle is unscrewed the buckle would come apart. but for $3 it might do the trick until the real thing becomes available again..
Muskrat
Muskrat is offline
PostPosted: Thu Jul 20, 2006 4:44 pm    Post subject: Reply with quote
thanks for the pic,vic . i only use mine when camping so not too worried about the security part. unless someone knows its there they probably wouldnt know to do that. however fort knox it is not. good point
thanks,keith
noganav
noganav is offline
PostPosted: Thu Jul 20, 2006 5:48 pm    Post subject: Reply with quote
Just got a 3/8' x 8' turnbuckle from the local hardware giant. I flattened the last 1/4 inch of each set of threads with a set of vice grips so that they can't be unscrewed. Works great, thanks for the tip!
vicali
vicali is offline
PostPosted: Thu Jul 20, 2006 9:47 pm    Post subject: Reply with quote
beat me to it, but I did pick one up on the way home,
note the mangles threads.. to keep it from opening. But it would be used for camping when we are in there so I'm not too worried.
adjusted to the smallest gap;
adjusted to the largest gap;
and what it looks like underneath;
so grknvgn, cheers for your first post, I can't wait to read more...
Mike
billybobrudebaga
PostPosted: Fri Jul 21, 2006 4:33 am    Post subject: Hatch Extension Reply with quote
I'm sorry, I thought you were look for hatch struts that have the abilty to stay open at various intervals.
Sorry about that.
-Billybob
peruvian
peruvian is offline
PostPosted: Sat Jul 22, 2006 10:26 am    Post subject: Reply with quote
I just bought a turnbuckle at my local hardware store. Best $2.99 mod I've done to my van!
Thanks grknvgn, vicali, etc.
