split dimmer switch
slackin' at work
slackin' at work is offline
PostPosted: Mon Jul 24, 2006 2:41 pm    Post subject: split dimmer switch Reply with quote
is this a correct split dimmer switch?
thanks for your time and info.
-chris
`20 SQ5
`06 Z4M coupe
`04 R32
`84 MK1 GTI
`76 Brasilia
VWLady
Crazy VW Lady
VWLady is offline
PostPosted: Mon Jul 24, 2006 5:17 pm    Post subject: Reply with quote
I have the same question...
RareAir
RareAir is offline
PostPosted: Mon Jul 24, 2006 5:36 pm    Post subject: Reply with quote
The hi/lo switch on my car is round like the one shown above.
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
my3bugs
my3bugs is offline
PostPosted: Sat May 10, 2025 11:49 am    Post subject: Re: split dimmer switch Reply with quote
the OP photo is no longer . im just trying to confirm this is the proper Dimmer switch for a 51 split bug .......the reason i ask is most of the screw terminal switches im familiar with have a hole you insert the wire then the screw tightens down on the wire ......this is screw terminal but there is no hole .
like just put it under the screw n tighten it ?
i have the next generation dimmer that is more ovalish in shape where this is more round , are they just interchangeable ? i just bought this thinking its the early round split version ... i looked for some photos on the samba but i ddnt find much info here ?
mine s not like the photos above . maybe a replacement ? looks like it should work .
finster
finster is offline
PostPosted: Sun May 11, 2025 2:32 am    Post subject: Re: split dimmer switch Reply with quote
doing a google image search using the underside view brings up results indicating it was used on mercedes cars in the 50s...
https://www.mercedespartz.com/store/0005451212/
Zwitterkafer
Zwitterkafer is offline
PostPosted: Sun May 11, 2025 8:34 am    Post subject: Re: split dimmer switch Reply with quote
The early round dip switches that I have owned had connector screw access holes on the topside, and the screws were smaller than in these pics. There was also a VW emblem in the (bakelite?) on the underside.
- Zeuxius, 400 BC
my3bugs
my3bugs is offline
PostPosted: Sun May 11, 2025 8:40 am    Post subject: Re: split dimmer switch Reply with quote
ya , well now i feel pretty foolish ..........i spent a good part of yesterday examining / studying VW dimmer switches on the samba and got a little better understanding ..........Ya i looked up the switch i have it is indeed for a Mercedes .........that said , it might work as the wiring numbers are the same BUT im working on a 51 VW not a mercedes .......i wrote the seller but havent heard back yet ...... Sad
my3bugs
my3bugs is offline
PostPosted: Sun May 11, 2025 9:47 am    Post subject: Re: split dimmer switch Reply with quote
the samba seller is not happy with me . when i tell him its a mercedes part not VW after receiving the part , now he says i am wasting his time .
" I did not state this was for any specific vehicle nor year in my add. I came across it with 5 other dimmers. I asked around the VW community as to what it was and was told it was early beetle but did not state that in my add. All I ask from a customer is that they look at what their buying before having me a ship a part and to ask questions or for more pictures prior to shipping. I state this very clearly because I don't like wasting my time for people buying stuff for their cars who don't even know what it is their buying.
Please see attachment stating just this which is very clear to see in the add. Glad you did all this research, probably would be best to do the research before buying a part not afterwards? "
i read his fine print BUT the part was listed in the thru 1957 type 1 VW part section ........ so why misrepresent by putting a Mercedes part there ....
the part is indeed a Mercedes part NOT a VW at all .......
my3bugs
my3bugs is offline
PostPosted: Fri May 16, 2025 7:26 am    Post subject: Re: split dimmer switch Reply with quote
OK all is well , i got a full refund and an education of what a EARLY vw dimmer switch looks like . thanks !!!
