bam Samba Member
Joined: April 28, 2004 Posts: 691 Location: Cameron park CA
Posted: Mon Aug 28, 2006 7:27 pm Post subject: CIP rubber????? |
yea....I bought some rubber from CIP for the rear glass about 10 months ago.... I tried to use it yesterday.....
THE RUBBER IS WAAAAAAAAAAAYYYYYYYYYYYYYYY TOOOOOO FRICKIN BIG!!!!!!!!!!!!!!
I AM SO MAD I COULD BREAK THE OG SEKURIT GLASS....
WTF??????????????
I HAVE INSTALLED glass on more than 50 VW's///.... I have had it come to small....that was ?OK..... at least I could make it work....try to get a seal thats too big in there.....I welcome anyone that thinks I am stupid/ retarded/ unaware of how to install glass/
If you can come here and get them installed correctly how they are....I will be impressed. _________________ hi |
bam Samba Member
Posted: Tue Aug 29, 2006 8:44 am Post subject: |
anybody ever have this problem?
to clarify its not the thickness but the length....
its like its an inch too long. I do not understand.
oh and please excuse the overillustrated frustration of the first post.
Is there anything I can do to get it to shrink?
all split glass is the same size correct? _________________ hi |
69judson Samba Member
Joined: October 04, 2005 Posts: 200 Location: Los Angeles Thousand Oaks
Posted: Tue Aug 29, 2006 9:11 am Post subject: |
Send that junk back to CIP and get new rubber from WCM or Wolfsberg West. I had the same problem with CIP. The stuff I got from WBW fit perfect. |
bam Samba Member
Posted: Tue Aug 29, 2006 9:31 am Post subject: |
69judson wrote: |
I bought it a year ago? will they still take it back?
so you got rubber that was too long? _________________ hi |
Yustrn JHC Controla
Joined: August 01, 2000 Posts: 5486 Location: Ovaland, CA
Posted: Tue Aug 29, 2006 9:42 am Post subject: |
I had the same problem from WBW, however I called and they sent me a new piece no problems....a year ago your probably S.O.L _________________ I own a copy of "The Car of the Century" by Garwood. This means I am authorized to act like a twat in thesamba forums. |
bam Samba Member
Posted: Tue Aug 29, 2006 9:58 am Post subject: |
Yustrn wrote: |
I had the same problem from WBW, however I called and they sent me a new piece no problems....a year ago your probably S.O.L |
thats what I figured Eric. . ...You should have seen me throwing a little crybaby fit yesterday. I even tried to freeze one...
yea....that didn't work. funny thing is I only bought them last year to get my order up high enough to get free shipping.... and the rear glass seal I bought with them for a 66 singlecab was too short..... but at least I was able to heat that one up and make it fit. I got a rear oval glass with a seal... maybe I'll just cut that stupid bar out  _________________ hi |
Yustrn JHC Controla
Posted: Tue Aug 29, 2006 10:03 am Post subject: |
Well since you are an OKIE now, you could just do what I did for when I need an emergency one, and cut the seal, wrap it around the window, put on a gang of super glue and let it dry...then install it....but that's some Folsom player shit right there. _________________ I own a copy of "The Car of the Century" by Garwood. This means I am authorized to act like a twat in thesamba forums. |
Splitdog Samba Split Personality
Joined: February 16, 2004 Posts: 4135 Location: Planet VW
Posted: Tue Aug 29, 2006 11:12 am Post subject: |
If you buy your rubber from WW, you will have no problems.  _________________ CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker |
Yustrn JHC Controla
Posted: Tue Aug 29, 2006 11:56 am Post subject: |
Splitdog wrote: |
If you buy your rubber from WW, you will have no problems.  |
If your dad would have bought a rubber I wouldn't have any problems either. _________________ I own a copy of "The Car of the Century" by Garwood. This means I am authorized to act like a twat in thesamba forums. |
DopeBeatDerrick Banned
Posted: Tue Aug 29, 2006 12:23 pm Post subject: |
Bam, give Wolfsburg West a call and ask for zwitter rubber. There is in fact a size difference between the early split and the zwitter rear glass. _________________ http://www.HoodRide.com |
Skim Rants Master
Joined: April 15, 2001 Posts: 17095 Location: GFK 31 Year Vet
Posted: Tue Aug 29, 2006 12:41 pm Post subject: |
DopeBeatDerrick wrote: |
Bam, give Wolfsburg West a call and ask for zwitter rubber. There is in fact a size difference between the early split and the zwitter rear glass. |
Yep, Zwitter back window rubber is the only split rubber with the groove for moulding. _________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
bam Samba Member
Posted: Tue Aug 29, 2006 1:00 pm Post subject: |
Skim wrote: |
Yep, Zwitter back window rubber is the only split rubber with the groove for moulding. |
.....yea I knew about the groove thing but the glass is a different size?
I don't care about the groove I'm not going to put the trim in the seals.
I thought all split glass was the same size though?
So Eric....doesn't that make you hindu now? _________________ hi |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17583 Location: Left coast, Canada
.... There is in fact a size difference between the early split and the zwitter rear glass. |
The glass is the same. |
Posted: Tue Aug 29, 2006 1:13 pm Post subject: |
Bruce wrote: |
No it's not. _________________ http://www.HoodRide.com |
Posted: Tue Aug 29, 2006 3:35 pm Post subject: |
Yustrn wrote: |
Splitdog wrote: |
If your dad would have bought a rubber I wouldn't have any problems either. |
Thank God WW didn't exist back then....  _________________ CH³NO²
Z = z² + C
#notacallooker |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9407 Location: Northwood, NH USA
Posted: Tue Aug 29, 2006 6:22 pm Post subject: |
Huh? You saying that zwitter rear glass and non-zwitter split rear glass is different? How can that be, the body stampings are the same??? _________________ John Henry
'57 Deluxe
'56 Single Cab |
Skim Rants Master
Posted: Tue Aug 29, 2006 8:38 pm Post subject: |
1953 Kabriolet
1954 Sunroof
Posted: Tue Aug 29, 2006 10:07 pm Post subject: |
I'm with the 'no' crowd. _________________ CH³NO²
Z = z² + C
#notacallooker |
Posted: Wed Aug 30, 2006 2:34 am Post subject: |
I tried to install the original zwitter small logo sekurit glass pieces that Bam has now in John's old '51 when we were putting it back together. I couldn't for the life of me figure out why the original glass wouldn't work with the brand new rubber. A quick phone call to WW and the difference was confirmed. "No" crowd? _________________ http://www.HoodRide.com |
bam Samba Member
Posted: Wed Aug 30, 2006 6:18 am Post subject: |
problem solved. i cut the stupid bar out...
this is interesting though....if Derrick is right thats something i didn't know.
I think I may do it the folsom way for now... _________________ hi |
