denwood Samba Member
Joined: July 29, 2012 Posts: 1047 Location: Thunder Bay, Ontario, Canada
Posted: Wed Oct 31, 2012 9:11 am Post subject: |
Audi gauges, WRX dash pod:
O2 sensor monitor:
Accusump oil pressure (charge=max cold oil pressure)
_________________ Cheers,
Dennis Wood
The Grape |
Zeitgeist 13 Samba Member
Posted: Wed Oct 31, 2012 9:25 am Post subject: |
Saab gauges and ambient temp/compass readout in self-dimming mirror
_________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
DAIZEE Samba Member
Joined: January 26, 2010 Posts: 7552 Location: Greater Toronto Area Ontario West Side
Posted: Wed Oct 31, 2012 12:43 pm Post subject: |
Cluster temp gauge, oil light, battery light now working so I'm just about ready to dump the on top gauges. Will keep added on tachometer for now and hopefully work out the fuel level gauge when I drop the fuel tank. I like the engine hours counter too. _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold) |
Witless Joe Samba Member
Posted: Wed Oct 31, 2012 1:27 pm Post subject: |
DAIZEE wrote: |
hopefully work out the fuel level gauge when I drop the fuel tank. I like the engine hours counter too. |
Did you test whether it's the gauge, or the sender, or some fault in the wire in between them?
Pull the 14-pin connector at the instrument cluster, and test the fuel sender wire there with an ohmmeter (ie. put the ohmmeter between this wire and ground). If you get 0 or infinite resistance, then your problem is somewhere between (and including) that 14-pin connector and the tank sender (0 resistance means the wire is frayed and grounding out on something, and infinite resistance means the wire is broken and completely disconnected). Bentley will tell you the official spec for ohms @full/half/empty tank, but if it's anything other than 0 or infinite, it's probably ok. (Actually, Bentley tells you to use a VW-spec tool with weird calibration, but search this forum and you'll get the ohm ranges used by that tool).
So if you get a good ohm reading there, the sender and its wire leading up to the 14-pin connector is fine. The trouble must lie between the 14-pin connector and the fuel gauge itself... maybe the 14-pin connector itself on the cluster side, or a break in the blue foil traces, or a bad voltage stabilizer (unlikely unless the coolant gauge is screwed, too), or the fuel gauge itself is bad.
Easy peasy to narrow the location of the fault before you go to the trouble of dropping the tank. |
joseph928 Samba Member
Joined: September 22, 2011 Posts: 2114 Location: flagstaff az.
Posted: Wed Oct 31, 2012 2:53 pm Post subject: Oil gauge-transmission gauge- oil temperature |
The top one is my Van Cafe oil pressure gauge, center one is my transmission temperature gauge, the bottom one is engine oil temperature gauge. The transmission temperature one has a high alarm that goes off with a light and sound. Everyone should at least have the oil pressure gauge! The digital gauge is $75 but will work with 9 different senders and can be used with oil pressure to. _________________ 1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug. |
akyrie Samba Member
Joined: March 24, 2010 Posts: 519 Location: Driftless, Wisco
Posted: Wed Oct 31, 2012 3:17 pm Post subject: |
Zeitgeist 13 wrote: |
How well can you see the pass/ side gauge? Gonna need an assistant driver to tell you when you lose oil pressure. _________________ Although I got a funny message from the Porsche guys, it read, "what a mighty ship that you must sail"
....has anyone else received that?
82 AHU DK, 1950's Puch-black |
Posted: Wed Oct 31, 2012 3:45 pm Post subject: |
akyrie wrote: |
How well can you see the pass/ side gauge? Gonna need an assistant driver to tell you when you lose oil pressure. |
Truthfully, I can't see the lowest registers, so it might make sense to rotate it a few degrees clockwise in order to see more sweep. I still need to install the sending unit on the engine, so its a moot point right now. _________________ Casey--
y u rune klassik? |
supdude Samba Member
Joined: February 02, 2012 Posts: 101 Location: San Luis Obispo, CA
Posted: Wed Dec 05, 2012 11:54 am Post subject: |
I haven't seen this setup yet. I bent some aluminum plate to mount my tach and oil pressure. The base plate is another sheet of 6061 that uses the existing holes in the dash. I used some RAM mount bases to mount my GPS and iPod. Good setup! Easy to modify without drilling or cutting holes in your dash.
_________________ ['83 EJ22]
LED LIGHT KITS! To illuminate your Vanagon or Westfalia!
The Rise of SURFMACHINE!
VanagonLEDs.com |
mammonista Samba Member
Joined: April 17, 2010 Posts: 10 Location: Chicago, Illinois
Posted: Wed Dec 05, 2012 12:22 pm Post subject: One of a kind |
This is a gauge cluster that I put together for 'Vanomo' a few years back. It has nine gauges in it: speedo, tach, fuel level, exhaust gas temp (1.9 td requires one of those things), volts, boost, oil pressure, water temp, and oil temp. All of the gauges just barely squeezed into the existing instrument cluster binnacle, and wiring was a bit of a challenge but I must say it works like a champ.
http://s1255.beta.photobucket.com/user/mammonista/media/vanagoninstrumentcluster.jpg.html |
Posted: Wed Dec 05, 2012 12:24 pm Post subject: One of a kind |
[/img] |
volkmar Samba Member
Joined: November 02, 2012 Posts: 39 Location: stuttgart.de
Posted: Wed Dec 05, 2012 1:46 pm Post subject: |
Volkmar _________________ 1989 Westy Syncro Hightop - mTDI ... klick for photo
1989 Doka Syncro Camper - eTDI ... klick for photo |
midmo81 Samba Member
Joined: September 23, 2012 Posts: 114 Location: Columbia, Missouri
Posted: Wed Dec 05, 2012 5:19 pm Post subject: |
From some old speaker boxes.
_________________ 1981 AC Westy |
Jake59 Samba Member
Joined: June 13, 2007 Posts: 179 Location: Seattle, WA
Posted: Wed Dec 05, 2012 6:20 pm Post subject: |
I like the stardard location for my volt & oil pressure gauges but did not like the "downward" viewing angle. So by cuting a piece of 2" ABS pipe at an angle from near nothing on the top of the dial to about .3" at the bottom it pitches the face up to be more visible to the driver. Also show are my budget coffee mug holders. I had the flip down plastic ones found on GW but they did not last long these bike water bottle holders are simple and very durable.
_________________ Curent ride: 87 2WD Westy, 2012 Jetta Sportwagon 2.5S
Past Rides: 62 (23 window) Bus, 64 Ghai convertable, 68 single cab, 72 Super Bettle, 78 Bay window Bus, 84 GTI. |
LemonCove Samba Member
Joined: July 29, 2010 Posts: 324 Location: Henderson, NV
Posted: Tue Feb 05, 2013 11:11 am Post subject: Simple and Effective |
VDO "cockpit international" gauges installed in dash using an aluminum plate. I used autometer slanted adapters to tilt the gauge faces towards driver. Gauges fit in recess where ash tray used to sit. VDO electric sender allows me to keep stock OP idiot lite.
88 Westy / Bostig Conversion
bac914 Samba Member
Posted: Sun Jun 16, 2013 11:06 am Post subject: |
I put mine on the A pillar. They illuminate blue as does the dash.
ragnarhairybreeks Samba Member
Joined: October 26, 2009 Posts: 1891 Location: Sidney B.C. Canada
Posted: Sun Jun 16, 2013 11:37 am Post subject: |
I installed 3 old VDO gauges (volts, oil press, oil temp) on top of dash. Mounts screwed to rectangle of black painted aluminum plate and plate double sided taped (the foam core type) to dash.
I used 6 wire (stranded) old computer cable to wire them up to a terminal strip attached under thew stock gauges.
alistair _________________ '86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com |
kuleinc Samba Member
Joined: August 10, 2007 Posts: 1604 Location: East Bay Area, California
Gruppe B Samba Member
Posted: Sun Jun 16, 2013 8:18 pm Post subject: |
Hey ragnarhairybreeks
What is the name of the gyroscope cup holder that is mounted to the dash?
I used to have one in my old Audio Quattro, great conversation piece |
