Jetta Electronic Distributor
Forum Index -> Water-cooled VW Share: Facebook Twitter
thatsnotstock
KKC-SawsAll Master
thatsnotstock is offline
PostPosted: Fri Mar 28, 2003 8:26 am    Post subject: Jetta Electronic Distributor Reply with quote
Does anyone know if the "computer" is needed for the electronic distributor to work. My distributor currently has points and I would like to replace it with the stock pointless distributor.
Thanks
Adam Vegas JHC
Adam Vegas JHC is offline
PostPosted: Tue Apr 01, 2003 6:27 am    Post subject: Jetta Electronic Distributor Reply with quote
what year Jetta do you have? Must be early if it has points...
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger Gallery Classifieds Feedback
thatsnotstock
KKC-SawsAll Master
PostPosted: Tue Apr 01, 2003 6:54 am    Post subject: Jetta Electronic Distributor Reply with quote
Wellllll, the engine is actually an 86 GTI w/ Holley 2bbl in a 65 Baja Bug. The Distributor is out of an early Sciracco. The Electronic setup I have is from an 87 "donor" Jetta.
Adam Vegas JHC
PostPosted: Wed Apr 02, 2003 9:30 pm    Post subject: Jetta Electronic Distributor Reply with quote
Can you say FRANKENSTEIN??!
I don't know what to tell you, bud. Try puttin the dizzy in and see what happens?
The 86 gti has a 1.8 8 valve motor, but which motor did the dizzy come off of in the Jetta? Was it the 8 valve or 16 valve?
What posessed you to make this conglomeration, anyway?
thatsnotstock
KKC-SawsAll Master
PostPosted: Mon Apr 07, 2003 4:18 am    Post subject: Jetta Electronic Distributor Reply with quote
Actually that is its name, FrankenBug. The Jetta has an 8 valve, a 16v wont fit. I was finally able to track down a mechanic that told me which wires go where, it shouldnt be a problem. HHMMM, what possessed me? The quest for something different and warm in the wintertime. Plus the cost, to put an aircooled 1800cc engine would have been about 1500 or more and without heat. This whole setup only cost 550, w/ heat.
thatsnotstock
KKC-SawsAll Master
PostPosted: Mon Apr 07, 2003 4:19 am    Post subject: Jetta Electronic Distributor Reply with quote
Goto my website: www.geocities.com/bugnut_1999
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
