heavy/hard clutch pedal
Forum Index -> Water-cooled VW Share: Facebook Twitter
aussie01
aussie01 is offline
PostPosted: Wed Jul 16, 2003 10:58 pm    Post subject: heavy/hard clutch pedal Reply with quote
my 89 cabriolet's clutch pedal has become very heavy/hard to push. I have been told that this is a sign of the clutch needing replacing. This is a mechanical clutch, so should I be able to adjust it manually and get some more life from it, or once the pedal goes hard, is that the indicator of time for a new clutch. If it can be adjusted, is this a simple task and if so any tips on where to look and what to look for.
thanks!
[email protected]
kutkontbaviaan@cs.com is offline
PostPosted: Thu Jul 17, 2003 2:16 pm    Post subject: heavy/hard clutch pedal Reply with quote
When the pedal goes hard, replace the clutch,it can not be adjusted, you can only adjust the free play on the pedal, so put in a new clutch and it rides like a new one again!(replace the complete clutch including pressure plate)good luck!
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
