CamperVanMan Samba Member
Joined: February 17, 2005 Posts: 49 Location: Sunny Suffolk ENGLAND U.K.
Posted: Fri Sep 22, 2006 6:03 am Post subject: What to do with engine out? |
Hi ,currently having my -79 camper oil cooler seals replaced,couldn t manage myself as needengine out.What if anything would it pay me to have done,apart from cleaning it down? your recommendations would be appreciated.; I m thing;
clutch
rear main seal
front seal  _________________ "It will soon be Friday" |
themarshotel7 Samba Member
Joined: February 04, 2005 Posts: 336 Location: Valparaiso Indiana
Posted: Fri Sep 22, 2006 6:14 am Post subject: |
Yes, Iwould do all three of those things. Also maybe needle bearing too. _________________ 1971 Westy
1972 Super Beetle
2001 Eurovan
1991 Fox
"Going wrong this curve set up for that unless you got a flat or suspension change even but what I found out was I could throw anything into reverse under ten miles an hour aw gosh good old granny you can allways tell by the fear in your belly how limited y'ar."
-Neal Cassady |
Posted: Fri Sep 22, 2006 6:45 am Post subject: |
Where s the needle bearing ? whats its function? _________________ "It will soon be Friday" |
Duncwarw Samba Member
Posted: Fri Sep 22, 2006 6:56 am Post subject: |
Clean and re-line the fuel tank? At least pull the bulkhead cover and check and/or replace the rubber hoses.
While I had mine out, I also made a fuel sender access hatch. Very handy.
"Mars" did you mean clutch throw-out bearing or something else? _________________ “To find yourself, think for yourself”
Socrates, 470 BC - 399 BC |
Bleyseng Samba Member
Posted: Fri Sep 22, 2006 7:06 am Post subject: |
No, the needle bearing that fits into the flywheel.
front seal on the tranny _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
Randy in Maine Samba Member
If it is in a shop anyway, have them check the crankshaft endplay to ensure it is within spec and inspect the front oil crankshaft seal for any leakage. |
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9156 Location: Syracuse, NY
Posted: Fri Sep 22, 2006 8:10 am Post subject: |
Injector seals, clutch and accelerator cables, replace fuel lines, inspect, clean, and seal fuel tank, clean and paint engine compartment, new foam seal, new fuel sender if necessary, new temp sensor II.....I can't beleive Randy didn't suggest that one!! |
renobdarb Samba Member
Joined: September 13, 2005 Posts: 878 Location: Eastern Idaho
Posted: Fri Sep 22, 2006 10:38 am Post subject: |
yes, clean the engine compartment. it's a lot easier to do with the engine out. _________________ ----------
1978 Campmobile, 2000cc w/hydro lifters, dual Weber 44 IDF carbs (50 idle jets, 115 main jets), SVDA distributor w/Compufire. |
Posted: Fri Sep 22, 2006 12:25 pm Post subject: |
I meant the pilot bearing or whatever it's called- the bearing in the end of the crank. _________________ 1971 Westy
1972 Super Beetle
2001 Eurovan
1991 Fox
-Neal Cassady |
Posted: Fri Sep 22, 2006 3:57 pm Post subject: |
Pull the oil pump and replace the oil ring inside it, also check that the idler shaft in the pump has not worked out and is hitting the cam, if you see any problem with the Type 4 pump you might concider replacing it with a high volume Type 1 pump, you can get them premodified to fit your engine from the Type 4 Store. A new dipstick tube boot should be high on the list as well. Check all clutch parts for wear especially look for broken springs in the disc. I would have them check the rubber mounts on the moustache bar for seperation/cracking. Have them inspect the brushes in your alternator if it has high miles since its last replacement as it is a pain to remove with the engine in. I would have them peen over the oil galley plugs behind the flywheel if they are still the original pressed in ones, lossing one of these can ruin your whole week.
Be sure that it is your oil cooler seals that are leaking and not your oil pressure sending unit. The oil senders are notorious for leaking.
If I were doing the work myself and didn't have to pay I would also be doing the pushrod tube seals as well.
Let us know how many spark plugs are laying on top of your cylinders. I bet two. |
