randywebb Samba Member
Posted: Thu May 23, 2013 4:01 pm Post subject: Compilation on the "early" 1986 Vanagon |
I am the often confused owner of an early 1986 Westy and thought it would be useful to collect all the oddities about this partial model year in one place for others who suffer. (I also own a 1973.5 Pooschey 911, and it has all sorts of weird things on it too.)
my VIN = WV2ZB0257GH 025 811 - early ’86
It has all sorts of wiring that does not match the Bentley manual fuse listing; e.g. on page 97.67 is a notation re (very early) 1986 “up to VIN G 055 689”
I've heard that a 1986 Vanagon with a VIN in the 028xxx to 029xxx should be around August to September production, so mine was manufactured much earlier, but I'm not sure when.
I also discovered that the relays in the engine compartment for the fuel pump and engine ECU are different from everyone else's relays.
What else is different? _________________ 1986 2.1L Westy 2wd Auto Trans. |
t3 kopf Samba Member
Joined: October 22, 2012 Posts: 1125 Location: over by 'der
Posted: Thu May 23, 2013 4:38 pm Post subject: |
does that model not say what year and month it was manufactured on the upper aft driver door frame? mine says 01/84 there. _________________ '90 Carat w/ '95 phase 1 EJ22 OBD2 conversion |
Sir Sam Samba Member
Joined: July 19, 2009 Posts: 1724 Location: Fort Collins Colorado!
Posted: Thu May 23, 2013 6:51 pm Post subject: |
| NavyVW wrote: |
| does that model not say what year and month it was manufactured on the upper aft driver door frame? mine says 01/84 there. |
It should. _________________ '91 Carat Westy
87' Syncro + '87 Westy conversion coming soon |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8487 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Thu May 23, 2013 6:56 pm Post subject: |
Mine (1/86 build date) got the '85 AC system: different reciever/drier & expansion valve... _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Fri May 24, 2013 1:26 pm Post subject: |
any other electrical oddities? _________________ 1986 2.1L Westy 2wd Auto Trans. |
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1741 Location: Budapest Hungary, Europe
Posted: Sat May 25, 2013 9:12 am Post subject: Re: Compilation on the "early" 1986 Vanagon |
| randywebb wrote: |
Mine VIN is around GH125000 and was manufactured in juni of '86. As I know the model year stamp was changes in every august. The 25000th should be manufactured in september. _________________ Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008 |
Posted: Sat May 25, 2013 3:48 pm Post subject: |
manf. date 10/85 on my door post sticker - ugh _________________ 1986 2.1L Westy 2wd Auto Trans. |
ZsZ Samba Member
Posted: Sat May 25, 2013 10:10 pm Post subject: |
| randywebb wrote: |
| manf. date 10/85 on my door post sticker - ugh |
then it must be correct
You never know what the previous owners changed/repaired in an old car. I think in the factory they changed the old/new parts when the stocked ones were out. But neihter the official VW repair books are correct in some times. _________________ Zoltan
