Using a Solex 26VFIS on a 30hp(36hp) engine
52panelvan
52panelvan is offline
PostPosted: Wed Dec 06, 2006 8:47 am    Post subject: Using a Solex 26VFIS on a 30hp(36hp) engine Reply with quote
Hi,
Does anyone have any advise about using a 25 hp SOLEX 26VFIS carb on a 30(36)hp engine. Someone has confirmed it is possible, the idea is to use a 30hp block to replace the water damaged and very siezed 25hp from my van, but keep it visually correct, or correctish depending how you look at it. I would be using all the ancillaries, tin and distributor from the 25.
I believe i need to rejet the carb, if so where would i get a jet from, can the jet from the 30hp be used or are they different. Will i have any problem as it has no accelerator pump.
Any help or advise would be great
Thanks
Mark
BUCIOBATISTI
BUCIOBATISTI is offline
PostPosted: Wed Dec 06, 2006 11:00 am    Post subject: Reply with quote
The 25hp cylinder tin will not fit over the 36hp heads.
Please check us out on Instagram at @holygrailgarage
That's the best place to see the latest things we are up to as well as catch an occasional sneak peek of our latest car and parts listings!
52panelvan
PostPosted: Wed Dec 06, 2006 1:48 pm    Post subject: Reply with quote
Ok thanks,
To plan B
cheers
Spanish Flea
Spanish Flea is offline
PostPosted: Fri Dec 08, 2006 1:06 pm    Post subject: Reply with quote
If my memery serves me correct. The 26 and 28 pic solex carbs have the same venturi size, only real difference (yes i know there are many) is the jet size, which can be changed out easy.
Spanish Flea
P.S.- why do i feel i'm going to get flamed?
Alte Schule
"Mr. Ford, i don't think what we are being offered here is worth a damn!" - Ernest Breech (On buying VW, March 1948)
krusher
krusher is offline
PostPosted: Sat Dec 23, 2006 1:39 am    Post subject: Reply with quote
I guess you want it all to look correct, but the 26 does not have an accelerator jet, i would pick the 28 for better driving.
Very Happy
Tempie
Tempie is offline
PostPosted: Sat Dec 23, 2006 6:02 am    Post subject: Reply with quote
am i wrong , or mistaking, but i saw that my 30 hp, from a 54... features a lot of 25 hp parts... just not the sheet metal
26VFIS, split style pulleys...
[/img]
