van died, now won’t start (solved! fuel pump connection)
Page: 1, 2, 3, 4  Next
chachi
chachi is offline
PostPosted: Mon Sep 22, 2025 11:39 am    Post subject: van died, now won’t start (solved! fuel pump connection) Reply with quote
van has been running well, but this morning I went to leave and it cranked but didn’t catch. tried that a couple times and then let it sit for a second, and it started and ran fine. I stopped for my appt, it started back up fine, stopped by a gas station and it started fine, but then died at an intersection and now will crank but not start. I tried to start it a few times and it finally would catch and run but rough and every time I tried to give it gas it died and now intermittently won’t even crank. I checked the fuel line at that tiny screw and there is gas there. it’s behaving like it did when I lost the coil some months back but…pretty fresh coil. is it possible for a coil to go bad again so soon? any other suggestions? thanks for any ideas!
'74 transporter panel
'91 vanagon carat NAHT
Xevin Premium Member
Xevin is offline
PostPosted: Mon Sep 22, 2025 11:46 am    Post subject: Re: van died, now won’t start Reply with quote
You need to drive the van more often and drink beer with me Wink Laughing
Keep on Busin'
67rustavenger wrote:
Clatter wrote:
skills@eurocarsplus wrote:
SGKent wrote:
chachi
chachi is offline
PostPosted: Mon Sep 22, 2025 11:48 am    Post subject: Re: van died, now won’t start Reply with quote
ha! I have been driving this sucker every day and it’s been great! come to the side of the road at 99th and division right now w a six pack you’re on!
Xevin is offline
PostPosted: Mon Sep 22, 2025 11:50 am    Post subject: Re: van died, now won’t start Reply with quote
You want me to grab a coil and bring it to you?
Keep on Busin'
SGKent wrote:
kamzcab86
kamzcab86 is offline
PostPosted: Mon Sep 22, 2025 12:00 pm    Post subject: Re: van died, now won’t start Reply with quote
It may not be the source of your problem, but to answer ^that question, yes, unfortunately.
~Kamz Anxious
2016 Golf GTI S
MarkWard
MarkWard is offline
PostPosted: Mon Sep 22, 2025 12:10 pm    Post subject: Re: van died, now won’t start Reply with quote
A timing light is the easiest way to check for spark.
chachi
chachi is offline
PostPosted: Mon Sep 22, 2025 12:36 pm    Post subject: Re: van died, now won’t start Reply with quote
if ever you had any doubts about Xevin being the most insanely good person on the planet he is indeed dropping everything and bringing me a coil. I am so incredibly grateful for him and honestly the whole PDX vw community. putting it in writing Xev, I owe you big beers.
jlrftype7
jlrftype7 is offline
PostPosted: Mon Sep 22, 2025 12:51 pm    Post subject: Re: van died, now won’t start Reply with quote
If it DOES turn out to be a coil, please post numbers of the fairly new one that died, and the one Xevin is lending you.
At this point, if it's the coil, we'd have to start a thread of WHY DOES THE DIGIFANT system eat coils... Rolling Eyes Rolling Eyes Brick wall Brick wall
‘84 Tin Top - Hilga....Auto
Xevin is offline
PostPosted: Mon Sep 22, 2025 3:54 pm    Post subject: Re: van died, now won’t start Reply with quote
Aww shucks! Helping out others is a classic VW virtue. Glad to assist.
Grabbed a coil from a VW parts house on the way.
Chachi stabbed it in and was on his way. It was less than an hour for me to grab a part and deliver it to Chachi and back home. So no big deal. Glad he made his other appointments.
Keep on Busin'
Xevin is offline
PostPosted: Mon Sep 22, 2025 3:57 pm    Post subject: Re: van died, now won’t start Reply with quote
For you chachi
Keep on Busin'
SGKent wrote:
DanHoug
DanHoug is offline
PostPosted: Mon Sep 22, 2025 4:11 pm    Post subject: Re: van died, now won’t start Reply with quote
we need photos and part numbers of the coil that was removed!!!
-dan
www.thefixitworkshop.com
Xevin is offline
PostPosted: Mon Sep 22, 2025 4:41 pm    Post subject: Re: van died, now won’t start Reply with quote
Bringing some heat Dan with all those exclamation points Laughing It’s 4:30 pacific time currently. He’s still working. jlrftype7 asked the for the same info already after I took off to assist.
The coil that was on there before I arrived appeared to be the same JP Group crap that I brought to him. JP Group in the aircooled world doesn’t have a great reputation but sometimes it’s the easiest to get. Maybe different in the more modern watercooled type 2s
Keep on Busin'
SGKent wrote:
DanHoug
DanHoug is offline
PostPosted: Mon Sep 22, 2025 6:01 pm    Post subject: Re: van died, now won’t start Reply with quote
ack. dint see jlrftype7's post!! apologies for the heat!!!!
in the aircooled BMW motorcycle world, they use the same type of control module for the ignition. different models were introduced to reduce coil failures, mostly from key-on time without the engine running. they incorporated a turn-off timer in the turquoise colored Telefunken one. not the same thing necessarily.
one thing i noticed with a cheap coil i was given that was supposedly correct for the Vanagon... it was oil-filled. oil filled coils have an air headspace to accommodate thermal expansion and need to be mounted vertically to ensure the windings are submerged in the oil. the true correct Bosch are specified as "bitumen filled" which to me says something like tar but that could be a language thing.
-dan
kamzcab86
PostPosted: Mon Sep 22, 2025 6:38 pm    Post subject: Re: van died, now won’t start Reply with quote
Bitumen is a dark, sticky substance that can be a liquid or semi-solid, formed from petroleum, and is primarily used as a binder in asphalt for road construction and roofing. It is also found naturally as asphalt deposits in the earth. Key characteristics include its adhesive and waterproofing qualities, its ability to soften when heated, and its high recyclability.
My Cabriolet's original Bosch coil leaked. Definitely would describe the substance like ^that... or tar-like.
JP Group/Dansk, and Meyle too, has the same reputation in the water-cooled world. Confused
~Kamz Anxious
2016 Golf GTI S
E1
E1 is offline
PostPosted: Mon Sep 22, 2025 6:58 pm    Post subject: Re: van died, now won’t start Reply with quote
I hadn’t heard of a “bituminous” road until a few years back, on a Gazetteer legend maybe, in describing a gravel-tar roadbase — like on very secondary country roads in the Midwest, or like so many we’ve seen in the way-remote desert.
Clues are road signs like “Stay back 1,000 feet.” Wink
If ever twice as rich, we’re gettin’ a double-wide
’84 “Westfailure”/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
Xevin is offline
PostPosted: Mon Sep 22, 2025 7:31 pm    Post subject: Re: van died, now won’t start Reply with quote
I haven’t dabbled into wbx coils much. Are VW OEM Vanagon coils oil filled or resin/epoxy filled? What are the JP group Vanagon coils? Just realized what Dan was describing as “ bitumen” would that be considered “epoxy or resin” filled as we do in the aircooled cars?
Keep on Busin'
SGKent wrote:
DanHoug
DanHoug is offline
PostPosted: Mon Sep 22, 2025 8:10 pm    Post subject: Re: van died, now won’t start Reply with quote
when i shake this cheapo VW coil, i can hear the oil sloshing. so go shake your coils!
-dan
Xevin is offline
PostPosted: Mon Sep 22, 2025 10:10 pm    Post subject: Re: van died, now won’t start Reply with quote
I can identify oil filled coils. Just not comfortable sharing my technique in public Embarassed
Wink
Keep on Busin'
SGKent wrote:
jlrftype7
PostPosted: Tue Sep 23, 2025 5:47 am    Post subject: Re: van died, now won’t start Reply with quote
" Quote" it was oil-filled. oil filled coils have an air headspace to accommodate thermal expansion and need to be mounted vertically to ensure the windings are submerged in the oil. Quote""
Well, if we could only go back in time to tell that to Land Rover.
They had a White , or was it Silver, Lucas ignition Coil they used on some models, these were firmly mounted horizontal in the engine compartment... Smile Smile
There was actually a Service Bulletin about them shorting out during turns.You'd make a sharp turn, and your ignition would cut out.
They leaked too. Pretty sure it was oil and not the tar like substance of Bitumen... Think Think
Fix was a different coil. I experienced it with a Customer's Defender first hand. Straight line driving, no issue, sharp turn, cough.... Rolling Eyes Rolling Eyes
Funny enough, the older Series vehicles DID have the coil mounted vertically on the Firewall. But on Defenders and other models, there wasn't really space to do that.
chachi
chachi is offline
PostPosted: Tue Sep 23, 2025 8:36 am    Post subject: Re: van died, now won’t start Reply with quote
sorry for the delay y’all, here’s the only identifying marks I can find on this thing so hopefully it’s what you’re hoping for. it definitely sloshes when I shake it. installed this in february of this year!!
Xevin IS the Demon Cleaner, but I can’t get the embed to work so just sing it to yourself
Page 1 of 4
