IN2VWS Samba Member
Joined: January 29, 2006 Posts: 2557 Location: Australia
Posted: Tue Dec 05, 2006 2:34 am Post subject: MotoMeter Rally Set |
I was just looking through some old catalogs, and I found a listing for the MotoMeter set for Ovals.
They list 2 models, one for Beetles upto August 1955, and the other for Beetles after August 1955.
Does anyone know what the difference is?
Then in another catalog, you could order 3 options. They were:
one with a clock,
one with Ammeter instead of the clock
one with a motor-therm instead of the clock (not sure what motortherm means, catalog is in German). Why would it have this motor-therm when there is an oil temp gauge already. |
Kais Collection  vintage treasures
Joined: February 18, 2005 Posts: 1570 Location: Rotterdam, The Netherlands
Posted: Tue Dec 05, 2006 3:56 am Post subject: |
Here you can see the 2 versions compared:
The early version (up to '55) has the warning lights in the gauges, and the gauges say Motest.
The later version ('55 and up) has the warning lights in the panel, and the gauges say Motometer.
I believe the Ammeter always says Motometer?
If anyone has a 60mm clock or Ammeter for sale, let me know, I need one for my set. Thanks.
(Did the clocks come in 2 versions as well? Motest /Motometer?)
Don't know about the motor-therm, but I'm sure Bob can help you out!
**edited: spelling errors** _________________ Insta: @kaiscollectionvt
Fb: @KaisCollectionVT
Please check my ads: https://www.thesamba.com/vw/classifieds/search.php?username=Kais+Collection
Kai's Collection - vintage treasures
Last edited by Kais Collection on Tue Dec 05, 2006 8:18 am; edited 1 time in total |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Tue Dec 05, 2006 7:57 am Post subject: |
I think the fuel gauge sending units are different on each version as well to compensate for the different tank shapes.
I believe the earlier gauges read MotoMeter & the later versions read Motest though. Sort of like the Perhaus clock (early) vs the VDO clock (late). All the same company, but a higher subsidiary department. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
53 0val Samba Professor
Joined: July 03, 2003 Posts: 11396 Location: Irvine, CA
Posted: Tue Dec 05, 2006 9:15 am Post subject: |
There are two different styles of panels. The first style requires the gauges to have warning lights and the gauges should be MotoMeter. The second panel has the warning lights in the panel itself and the gauges should not have any lights. The gauges could be MotoMeter or Motest but they should not have lights and should not be mixed...............either all MotoMeter or all Motest. The problem developes when you have an early panel and you want to run the Amp gauge in the center instead of the clock. All 60mm Amp gauges I have seen are Motest and not MotoMeter, so I don't believe that the early panels were ever the Rally gauge option. The later panel could have the Amp gauge in the center and all the fuel and oil gauges should then be Motest as well. One last little twist.......the gauges could be in German or English and they should not be mixed that way either. The fuel gauge is always on the left, the clock or amp gauge in the center and the oil gauge on the far right . The panels could be painted or chrome with the chrome almost always seen on the later panel.
I have seen most of the painted panels to be ivory in color but a flat black was also available for people who wanted to paint the panel to match their dash. All the gauges are date stamped so it makes it easy to figure out which gauges go with which panel but that's it in a nutshell, so to speak.
Here is my early panel with MotoMeter gauges with lights.............German script...........clock in center.
http://www.thesamba.com/vw/forum/album_page.php?pic_id=70919 _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Posted: Tue Dec 05, 2006 9:35 am Post subject: |
I've been trying to get Glenn to correct that for years.  _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Posted: Tue Dec 05, 2006 9:53 am Post subject: Re: MotoMeter Rally Set |
| IN2VWS wrote: |
one with a clock,
I have no idea what "motortherm" could be unless it was head temp. I have this gauge in my Porsche and it could fit in the center 60mm hole as well.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&...1&rd=1
I am also looking for the 60mm Amp gauge..............so if you get two Kai............send me one. You know the address.  _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Posted: Tue Dec 05, 2006 3:51 pm Post subject: |
| 53 0val wrote: |
| The first style requires the gauges to have warning lights and the gauges should be MotoMeter. |
Actually, the gauge set shown above (with the warning lights inside the gauge) all have the Motest script. So I guess Motest & MotoMeter were available both with & without warning lamps.
But much like the Perohaus/VDO dash clock debate, I'd rather have Motometer & Perohaus on my gauges  _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Posted: Tue Dec 05, 2006 4:47 pm Post subject: Re: MotoMeter Rally Set |
| 53 0val wrote: |
I am also looking for the 60mm Amp gauge..............so if you get two Kai............send me one. You know the address.  |
Offcourse I will, Bob!  _________________ Insta: @kaiscollectionvt
Kai's Collection - vintage treasures |
Posted: Wed Sep 24, 2008 12:03 pm Post subject: Re: MotoMeter Rally Set |
| kai wrote: |
| 53 0val wrote: |
Offcourse I will, Bob!  |
You can quit looking for me Kai.............
That only took two years to find. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Posted: Wed Sep 24, 2008 12:25 pm Post subject: Re: MotoMeter Rally Set |
| 53 0val wrote: |
| kai wrote: |
| 53 0val wrote: |
That only took two years to find. |
Congrats Bob. Another great addition to you oval! (and a lot better than 2 clocks in one car ) _________________ Insta: @kaiscollectionvt
Posted: Wed Sep 24, 2008 1:17 pm Post subject: Re: MotoMeter Rally Set |
| kai wrote: |
| 53 0val wrote: |
| kai wrote: |
| 53 0val wrote: |
Congrats Bob. Another great addition to you oval! (and a lot better than 2 clocks in one car ) |
I've been running an MotoMeter outside Porsche tempeture gauge............refaced by North Hollywood Speedometer to match the oval gauges.
jooles Samba Member
Joined: August 29, 2008 Posts: 235 Location: Bulgaria / France
Posted: Wed Sep 24, 2008 2:28 pm Post subject: |
Man, this is a gorgeous dash!!!
Nice little VW logo on the glovebox handle
Julien  |
Posted: Wed Sep 24, 2008 2:38 pm Post subject: |
| jooles wrote: |
Julien  |
Thanks..................(good eyes ) _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
ProjectX Accessory Nut
Posted: Wed Sep 24, 2008 4:39 pm Post subject: |
Now that's a dash  _________________ Even my nuts are plated.....
195? Project "X"
1954 Oval Convertible |
a-train Samba Member
Joined: October 11, 2003 Posts: 702 Location: Issaquah via Parkland, WA
Posted: Wed Dec 17, 2008 11:47 am Post subject: |
Yeah, sweet dash. I like the stop watches....nice.
Hey, does anyone know if there are replacement wire terminals for the back side of the rally gauge panel. They look like six terminal blocks on each side of the clock. For those whose are missing, what have y'all done in place of them? Or have you just left them out? If anyone knows a source for them, can you point me in the right direction?
Here's a pic of the back with the wire terminals I'm referring to. Mine are missing.
_________________ I like VWs |
Posted: Wed Dec 17, 2008 3:11 pm Post subject: |
| a-train wrote: |
Thanks...........Here is a link that will tell you all about the watches.
http://www.onthedash.com/Guide/_DashMounted/ _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
vwraymund Samba Member
Joined: October 31, 2006 Posts: 163 Location: Tilburg, The Netherlands
Posted: Fri Feb 08, 2013 10:06 am Post subject: |
Hey
Bought this set.
looks to be all correct.
Only the fuel gauge does not have an light in it.
maybe they replaced it?
Needs some polish work too.
_________________ Check out www.oldvw.nl
For parts and more. |
