hose that connects fan shroud to air cleaner
FreakCitySF
FreakCitySF is offline
PostPosted: Wed Mar 05, 2008 12:17 pm    Post subject: hose that connects fan shroud to air cleaner Reply with quote
I was wondering if anyone knew off hand the vacuum hose that came off the right side of the fan shroud and connected to the top of the stock air filter.
It's thicker than the 2 smaller hoses. Does anyone carry those? What's the size on those?
Thanks!
FreakCitySF
PostPosted: Wed Mar 05, 2008 4:04 pm    Post subject: Reply with quote
I used a caliper and I got 12mm or 1/2 an inch. Sound about right?
While I was back there I noticed another hose , on the air cleaner side, that comes out the firewall and goes back into the firewall. Mine was snapped in half and looked dry. Critical to replace that?
Thanks
chris
Woreign
Woreign is offline
PostPosted: Wed Mar 05, 2008 4:52 pm    Post subject: Reply with quote
These hoses provide the air pressure to purge the gas vapors from the carbon canister and force them into the engine where they are burned. Not critical, but they may aid in reducing fuel tank pressure and the resulting gas smell in the trunk and car.
Ian Epperson
Ian Epperson is offline
PostPosted: Wed Mar 05, 2008 6:49 pm    Post subject: Reply with quote
As Woreign implied, that hose does not connect directly from the fan shroud to the air cleaner. The hose from the shroud goes into the canister located near the starter, then goes from that canister to the air cleaner. That canister has a thin hose that snakes around the right side of the car to another charcoal canister in the boot, then into the gas tank.
Usually, the long run from the front to the rear is clogged and/or cut or broken and the entire system is no longer functional. If that's the case, you should just plug the hole in the shroud and in the air cleaner as it's just wasting cooling air and blowing unfiltered air into your intake. Not a good setup.
VW-181 shirts and stickers.
http://ian.epperson.com/vw
FreakCitySF
PostPosted: Fri Mar 07, 2008 3:25 pm    Post subject: Reply with quote
Thanks for responding!
I hope to fix it soon!
Regarding the hoses coming out of the firewall to the upper right of the fan shroud, does the left hose go to the fan shroud, right hose to the air cleaner?
I'm going to cap both the fan shroud and air cleaner for now though.
I found this pic posted by Glenn
Original forum post
http://www.actop20.com/forums/viewtopic.php?t=535&...a73fe9de60
I'm curious what do you call that rubber plug? a cap or plug
Glenn mentioned a part #
030-133-335A
But CIP1.com didn't seem to have it,
any where I can find that rubber plug, that would be perfect, two of em.
Thanks again
chris
Ferretkona
Ferretkona is offline
PostPosted: Fri Mar 07, 2008 5:09 pm    Post subject: Reply with quote
FreakCitySF wrote:
,,,any where I can find that rubber plug, that would be perfect, two of em.,,,
You can get them at the Home Depot or Lowes, Kragen Auto.
Probably have to get a 6 pack of different sizes.
74 181 Thing
2008 Ford Sport Trac V8 4x4
2008 Ford Escape V6
crofty
Judas of the North
crofty is offline
PostPosted: Fri Mar 07, 2008 10:16 pm    Post subject: Reply with quote
now THATS a crusty shroud!
HamburgerBrad wrote:
Ian Epperson
PostPosted: Sat Mar 08, 2008 10:40 am    Post subject: Reply with quote
I think that's correct - that's the position mine was frozen in before I snapped the tubes off. Very Happy They were kinda old.
7thing3
7thing3 is offline
PostPosted: Fri Apr 24, 2009 11:28 am    Post subject: Reply with quote
I have dual carbs with no provision to hook up hose from charcoal canister. The rear canister just has a big hose that is looped from the in port to the out port. Would it do any good to cap one of the ports (assume there is no difference) and run the hose up to the shroud?
